Tamiya TB-Evolution IV
#3376
i always stripped my Evo III SE front ring gear when running mod motor, only twice i pull the throttle and those gear stripped make a annoying noise...what should i do to make my Evo III can run mod motor. if i have to use shim on those gear, where should i place those shim???
#3377
Hi everyone im looking at getting an evo, just sold my T2 as couldn't afford the part bills.
ive got a friend with an evo V and its a rocket but wat are the advantages of the V over the IV.
and does anyone know wher the cheapest place to buy an evo 5 (15yearold budget)
thx for your help in advance
#3380
hi everyone
well I bought An EVO 5
Are there any good build tips i should Know(besides spend a long time shimming it right)
also a friend has been experimenting with the bevel gears, he reckons that if you dont grease the gears it will lessen wear. Because less dust and little rocks/sand wont get stuck on them.( i race on a very dusty track). so grease vs non grease?
Any help is appreciated
#3382
Hi guys, It's about gearings ...
Hi all,
I have a question regarding the gearing for a Tb EVO IV
What kind of pinions should i use ? 0.4 or 0.6 module ?
Indeed i have no idea which pinions to buy
Thanks for all ur help, answers and advices
Nikko
Nikko
#3384
Thanks for answering me, rc touring racer.
Hopefully i already got the answer. I bought some pinions that range from 31 th to 41 teeth.
Since I got the 2 spurs (90 and 96 teeth) i think i will have enough gearings possibilities to use my 17 turns Corally motors at its best potential.
#3385
Hi all,
Can anyone give me a good Evo IV set up sheet for small/mid sized carpet track. On rubber tires.
I am sure it is in this thread somewhere but the search capabilities of this site suk and I don't have 10 hours to search 113 pages.
Thanks in advance!
Thanks in advance!
#3386
Chamber: 1,5° all around,
Caster: 4°
Toe in rear between 2° (Stock Motors till 17T) 2,5°-3° for Modified.
Ride height: 5 front, 5,5 rear ground clearance
Droop: front 6mm rear 5mm (meassured from the bottom of the lower deck to the under surface of the suspension arm.
Sway Bars: You have to try. Test the soft ones.
Dampers: White spring front, blue spring rear, 50 or 40oil, 3 hole, no bushing or o ring). If there is low grip then use the blue spring front and the yellow spring rear.
The Damper, and upper arm positions all stock. maybee you can try to use the inner hole from the bulkhead upperarmmount.
I hope it works well, because it is my setup for my Evo5 on Carpet Tracks.
I also run harder swaybars sometimes. (depends on the griplevel)
#3387
hi everyone
This response is prolly a bit late and you have most likely already built the car .. but .... on the tamiya website in the articles section there is a long article on a "preoffesional build" of the evo 5 by one of the TRF drivers. Its pretty good, sorry no link.
#3388
Hy !
Caster: 4°
Caster: 4°
#3390
Front Spool
Hi everyone, just got an Evo IV and was wondering is there any one who manufactures a front spool.
Thanks Dave.
Thanks Dave.
