Team PRP racing components
#91
Re: One way plate
Originally posted by TeamPRP
Hey Lem, did you send an email- I don't think I received it. thanks.
Anyways, more power and God Bless!
Peace and Happy Racing!
Lemuel Pia
#92
Thanks for the update, Lem. If you'd like anything else, please feel free to send me an email.
Kevin, thanks for the comments - looking forward to hearing about this weekend!
Doug, glad they are working in those cases! The roll center plates will be shipping the same time as the chassis- June.
#94
JD, it will be around the general pricing of other chassis upgrades. I don't have a set price yet because I am still finalizing the design.
Thanks!
Thanks!
#96
dont hate me here brother i know i might be in the lions den,.. but ..is there anywhere that i can still get a TeamPRP Pro 3 upper deck? I would put my LRP through the dishwasher if i had to...
Tthey are always sold out and noone Ebays them ever..
and the PRO 4 stff looks GREAT.. i hope i get one soon before i start getting lapped on the carpet..
#97
Hey masterjr33, we sold out of our Pro 3 upper decks around December. At that time I was going to discontinue it, but I have had many requests for the Pro 3 upper decks again. So I might do a limited run of them again this summer. I'll post info on the site and on here once I have more details ready.
Thanks!
Ben
Thanks!
Ben
#98
you sir are a god.. i know im out dated.. but i still drive a Big Block convertible mustang in traffic next to all these civics.. it might not be the best thing to have out there. but it gets me going.. kinda like my little pro 3.
i cant wait for my pro 4 these parts are a MUST!!!.
they look great.. and im sure they help stability and consistancy . im glad to see the aftermarket picking up on the new chassis so fast..
#99
Trader Rating: 32 (100%+)
Ben......I raced the chassis this weekend on asphalt with foam tires and in the open electric class so needless to say we were racing with 8 turns. I ended up Tq with two wins in the triple A main securing my overall victory and my Tq time was faster then the Nitro 200mm Tq time by a few seconds....also my fastest lap was almost a second faster then the fastest nitro lap. The car was very good all day and I never struggled with the car at all. The track was in a parking-lot its about 185ft x 100ft and it wasnt the smoothest and the track temp was around 110 to 90 deg. This was also the first leg of a 6 race point serries that runs all summer so we are off to a good start. I think next weekend I will get some time with rubber tires and see how the car works with them.
I will post my setup later today.....
#100
Set up
HTS Chassis setup
Front
#5 HPI piston
40wt oil
Losi Black Spring 25lbs
inside hole on the lower arm
one hole in on the shock tower
1deg toe block used in front
2mm spacer under front block
2.5mm spacers under the rear block(this give a little antidive)
1 hole on steering plate
forward hole on steering knuckle
inside hole on diff case
3mm spacing under inside ball stud
Black Sway bar (1.6mm)
5mm ride height
3mm of droop over ride height
1deg camber
Jaco Plaid tires
Rear
#3 HPI piston
40wt oil
Losi Purple Spring 20lbs
Middle hole on lower arm
Outside hole on the shock tower
Inside hole on hub
Hub spaced full back(long wheel base)
Inside hole on diff case
1.5mm spacers under inner ball stud
2.5 deg block used
no spacers under front block
.5mm spacer under the rear block(this gives a little pro-squat)
5mm ride height
3.5mm of droop over ride height
silver sway bar used (1.4mm)
1.5 deg camber
Jaco Purple tires
Body
Losi Skoda with stock wing
Notes.....
This was on the PRP soon to be released HTS 3mm chassis and top plate. Also no center post was used. I ran a D5 series 8x1 and geared it 33/100. The track was about 185ft by 100ft and a little rough in places but had VERY good traction. If you have any questions on anything please feel free to ask.
Front
#5 HPI piston
40wt oil
5mm ride height
1deg camber
Jaco Plaid tires
Rear
#3 HPI piston
40wt oil
Inside hole on hub
2.5 deg block used
5mm ride height
1.5 deg camber
Jaco Purple tires
Body
Notes.....
#102
Originally posted by Super Steve
wow!
you gearing is crazy!
wow!
#103
ONE WAY PLATE UPDATE
The brace plate is being anodized this week and will ship out next week. I'll send everyone that placed an order an email tomorrow (Tuesday, May 18th).
I was hoping to have it ready this week but I decided to go with a different anodizing company.
Thanks again to everyone that has pre ordered, it really has helped out!
Ben
Ben
#104
Asphalt
Great news again, Kevin. Thank you for the great job!!!
#105
Kevin-Curious what size your tires were.
I run on a 180x80 track. With rubber and a 9 double Ti.
I dumped with a 32/98. But that is on 63 mm tires.
Needs to go down to a 29 or 30 with that big of tire.
How much weight did you add and where?
I had to add 49 grams to get it to balance Left to Right.
Or 7 of the 1/4 oz weights. Seems like alot.
Bear
Bear
