BMI Racing "Copperhead 10" Support and Discussion
For more pics feel free to see our album on facebook. Here is the link.
http://www.facebook.com/album.php?ai...7&l=104ea343ed
Jason, I saw that you stated earlier that it should fit 2S saddle, but from the pictures I just can not figure out how? Are the cutouts for 1S lipo made actually wider to make also the 2S saddle fit? My saddle lipos are 46mm x 63mm x 23mm each and they fitted perfectly in the lipo trau for the DB10R (offcourse I had to shim the batery posts up). I guess with the weight of 2S lipo (our weight limit is 1050g) we should also use some stiffer side flexplates than the ones used with 1S lipos..?
If you shim the battery plate up you can tape a stick or saddlepack lipo in the car. It was based on a single cell lipo in mind as that really is what the majority of people run in WGT. I had to make a decision whether to make it handle better with single cell(light weight) or stick with the setup we had that worked extremely well for the 4 cell and 2 cell lipo. To do both equally well was not possible. I made the decision to go with the majority. This doesnt say that the car will not work extremely well with 2S LiPo. It will work very well. It will just need a setup change to accomodate the increase in weight.
How much will the 10 and the 12 cost?
I like the collar of the car.
Are the black flex bars from the same material as the old ones?
Or is it from other material.
are you interested to buy and drive a pancar emiel?
I had a 1:10 F1 Corally.
I think that the car with a 1 cell lipo and a 17,5T motor will be a nice speed on ERCE.
I'm also thinking of buying a 1:12 and that one looks good. I looked ad the DB12RR also. I like the concept.
This car just looks good and also strong.
I like the collar. It's something different.
The only thing i don't like are the tires. I don't like foam tires.
But I think that 1:12 is a must have next winter. You see it grow an grow. Also by the club in Belgium and 1 cell lipo is here also growing.
