BMI Racing "Copperhead 10" Support and Discussion
#201
Front:
Stock flex plates in soft postion
#6 shurlube on the tube
4mm ride height
6 degrees caster
1mm shim under hinge pin block
1.5 degrees camber
2mm shim behind front axles
.75mm droop
0 toe
Spec tire cut to 2.08
Rear:
Stock center spring and middle hole on shock mount/battery plate
45 wt. oil in shock
Stock flex plates mounted long
4mm ride height
1mm pod droop
#4 shurlube in the tubes
Pod level
Electronics behind battery and battery across the chassis
4mm ride height
6 degrees caster
1.5 degrees camber
.75mm droop
0 toe
Rear:
45 wt. oil in shock
4mm ride height
1mm pod droop
Pod level
#204
A guy at our local track also broke 2 of them in 2 races in a row, never seen them break before
#206
#208
The cars looked very good at the birds, joe could have easily won that 13.5 main. Both cars were very smooth. Good job bmi. And Joe is a great guy to talk with!!!!
