First 1/12 pan car.
Follow Up
I would suggest taking a look at the 1/12 scale forums on here as well as I think there is one specific to the 12R5.1.
I would also take a look at www.rc10.com I found a great list of setups at the following link: http://67.199.85.166/racing/setups.php
The link above is direclty from www.rc10.com. There is a ton of setups and I am sure you will find one that would be a great starting point...
I current race CRC cars so I do not specifically know the setups of the AE stuff at this point. But I was wanting to at least point you in the best direction.
Good Luck!
http://www.petitrc.com/reglages/asso...tedRC12R5.html
dude, another thing we have in common... I have the exact same car....! wicked little machine and tons of fun to drive....not to mention they are as tough as nails !
The Futaba 9650 servo is a drop in fit. I know you need to drill new holes for JR but not sure for others.
I use mostly Futaba so it was a no-brainer for me.
Pointers? Try not to turn too hard and scrub off speed in the corners. For 4 cell you could try the red spring to increase the stiffness.
Trader Rating: 25 (100%+)
it is the same size as that futaba and the same speks. alittle better actually and 15 bucks less. the output on it is just in a little bit diffrent place. I would just think they would give you some options seeing as how servo's are all a little diffrent.
