Old 04-05-2012, 05:48 AM   #886
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by theatriks View Post
Anybody ever run a 4.5 turn motor off this speed control
Originally Posted by jono1982 View Post
You should have no problem running 4.5t on this speedy just make sure you check temps after 2 minutes when practicing to be safe and dont overgear the motor. I have seen these speedy been used and I am going to be using this speedy in australia where the weather is hot with no major problems. Plus they are weapon fast
Nearly all BD's out there are LV's and will need a fan to be able to run Mod TC. 4.5 will be pushing it for a LV. Jono yours is a TC version with fan and larger heatsink and is fine for most 4.5 motors. A 4.5 on a LV even with a fan is going to depend on ambient temps.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 04-05-2012, 05:51 AM   #887
PDR TOO's Avatar
Trader Rating: 24 (100%+)
Default BD
Paul,
You have PM.
Regards,
Brent
SMA .....The Track.
Previously Raced Vehicles keep me on the track - sort of.
PDR TOO is offline   Reply With Quote
Old 04-05-2012, 07:10 PM   #888
syndr0me's Avatar
Trader Rating: 32 (100%+)
The Side Piece "Seis" fan fits on the ESC perfect. It's 25x25x15 and moves a lot of air when you plug it into the receiver. I picked up some 16mm M2 screws from McMaster Carr, and they have plenty of thread to hold the fan in place.
I'm gonna give it a go in mod in a couple of weeks, I'll report back with temps using the fan.
syndr0me is offline   Reply With Quote
Old 04-06-2012, 03:42 AM   #889
hana166's Avatar
This page says 2S down to 7.5T
http://www.modeltech.co.uk/catalog/p...6cba2418a1209c
However the speedo has two layers of Mil spec FET's which are directly against the inside faces of the case and is rated constant current of 150A, extremely high for such a small speedo.
For the sake of an email it seems sensible to contact Per first before strapping in the 4.5
hana166 is offline   Reply With Quote
Old 04-06-2012, 06:19 AM   #890
theatriks's Avatar
Ive been running a reedy 4.5 turn on my BD (no timing, no boost) and let me tell you after a 10 minute run i could use this speedy as an ice cub for a drink thats how cool it runs.
theatriks is offline   Reply With Quote
Old 04-06-2012, 06:40 AM   #891
Skiddins's Avatar
Doug, did you say at WLRC use motor timing for mid or top end?
I moved the start timing to 7000rpm and it did help with low end torque but didn't seem to make any difference to temps.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-06-2012, 12:29 PM   #892
hana166's Avatar
The can timing affects the entire rev range so lifting the start rpm allows the can timing to take care of the bottom end without being overtimed, and you can add an appropriate amount for the midrange.
I'm going to try start 12500-14000 next time, and add a further 5 degrees to the can to compensate, effectively adding 5 to the top but hopefully avoiding heat issues as the start is so high. Alternatively might add this to top timing over 19600 instead
At the moment its +10 from default (40 on the can) FDR 6.4 (to get the brake), 50deg mid starting at 7000 no turbo. Its competitive right now, but have a feeling it could be devastating if exactly the magic set up can be found
Old 04-07-2012, 04:23 AM   #893
Skiddins's Avatar
Unfortunately the high torque rotors didn't arrive this week so will have to test at WLRC next weekend.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-07-2012, 05:53 AM   #894
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Hi Guys,
Could someone give me a starting figure for rollout or fdr for an 17.5 X12 with a BD... will save me time I don't have atm..
Many Thanks in advance
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 04-07-2012, 07:54 AM   #895
syndr0me's Avatar
I'm underwhelmed by the brakes in 13.5 sedan.
Old 04-07-2012, 09:22 AM   #896
Skiddins's Avatar
Originally Posted by FK05 lover View Post
Hi Guys,
I can't help with specifics for 17.5 but if on the old software, run it in profile 4 or you'll cook the motor.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-07-2012, 09:23 AM   #897
Skiddins's Avatar
Brakes seem to be very much dependant on the amount of timing, the FDR and the specific motor.
How much are you using on the ESC?
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-07-2012, 09:35 AM   #898
A setup to get the best of both worlds, bottom and top end, would be to run 30 from 0 to 19600rpm and 50 past 19600 ramped evenly to 36000rpm.... You can even gear lower, around 7.6FDR to get more punch out of the corners, and reduce heating issues.....
bertrandsv87 is offline   Reply With Quote
Old 04-07-2012, 09:41 AM   #899
By the way , if you switch to 3.5t or 2.5t motor and use the same concept but only cranking the timing to 45 , you will be uncatchable...
Old 04-07-2012, 11:34 AM   #900
syndr0me's Avatar
Profile 1 (2.1 software) for "blinky." FDR is 5ish. Motor is a TP with physical timing around 40.
