Old 03-13-2012, 09:18 AM   #871
hana166's Avatar
Try this
http://www.modeltech.co.uk/catalog/p...f0d0e9665bcfae
hana166 is offline   Reply With Quote
Old 03-13-2012, 04:01 PM   #872
ropezz's Avatar
Default Help for ESC settings
Hello everibody,
i will shortly be a Black Diamond owner and before i get started with testing the speedo, i wish to ask for some advice with the settings.
Which are the values to set as a good starting point in order to stay on the safe side ?
Motor used LRP 4.5 Octawind on a very long and fast asphalt track.
Thank you.
ropezz is offline   Reply With Quote
Old 03-13-2012, 04:06 PM   #873
Skiddins's Avatar
Originally Posted by ropezz View Post
Hello everibody,
Thank you.
Does it have the new software 3.01, and do you have the programme for you computer to make changes?
I ask as the help file/manual mentions a few settings with regard to mod.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-13-2012, 05:08 PM   #874
ropezz's Avatar
I am not sure which SW release the speedo will arrive with.
I have received in advance the program and help file/manual.
Still i have a few doubts on correct settings for:
Minimum and maximum values for Start RPM
Minimum and maximum values for Mid TIM
Minimum and maximum values for Top Timing
Old 03-13-2012, 05:35 PM   #875
Skiddins's Avatar
Don't use top timing, you have a mod so get it working correctly first.
Start rpm, 2000 and low mid timing, 10 or something.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-14-2012, 10:38 AM   #876
theatriks's Avatar
Anybody ever run a 4.5 turn motor off this speed control
theatriks is offline   Reply With Quote
Old 03-28-2012, 04:08 PM   #877
jono1982's Avatar
You should have no problem running 4.5t on this speedy just make sure you check temps after 2 minutes when practicing to be safe and dont overgear the motor. I have seen these speedy been used and I am going to be using this speedy in australia where the weather is hot with no major problems. Plus they are weapon fast
|Hearns Hobbies|G-Force Electrics|
jono1982 is offline   Reply With Quote
Old 03-28-2012, 04:13 PM   #878
jono1982's Avatar
Anyone got any setups for the BD when running 1s lipo's in either a 1/12 or WGT?
Skiddins
Depends on what you are running in 1/12th if you are running 10.5 or 13.5 1s
then you sould be able to use profile 5 just make sure you have the right roll out and always and i cant stress this enough do some practice before you race with the setting to make sure you temps are ok and your comfertable with the speed and aceleration. If your running Mod 1/12th or Pro 10 then i would start at Profile 3 and go from there depending on track,temp and skill ect.
Old 03-28-2012, 04:20 PM   #879
jono1982's Avatar
Originally Posted by martin660 View Post
Black Diamond speed controls were an interesting experiment. Was frustrating to passed on the straightway by cheaper speed controls. It was probable my fault. Would have been easier to live if I hadn't spent $300 on the 5 that I had purchased. Live and learn.
Hey man if you still have the speedies i wouldnt get rid of them if you need help with set up let me knpw I have seen these things really get up and move so maby you just need a little guidence.
Old 03-28-2012, 04:49 PM   #880
Jono you are the man
ps - check the spelling in your signature ???
Mike Schroder is offline   Reply With Quote
Old 03-28-2012, 07:39 PM   #881
nashrcracer's Avatar
R/C Tech Charter Subscriber
ran my BD with a trinity duo3 5.0 in my CRC GEN Xi at the carpet nats in Texas and started out at profile 4 with a 39.6" RO and was debonding the Buds DBL stick and getting to about 140 on the temp with no fan. stupid fast and I couldn't drive it only turned a 9.7 sec lap. lemuiex and Hebert were tapping 8.8 8.9 kicked it back to 3 and was working on setup and got to a 9.4 lap not bad for the first time driving mod at a big race since 2004 with a 9x2 brushed motor back in the day. going to the region 5 race in cleveland next month to work it out some more. will update when I get back. love the smoothness and even I can't blow it up!
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 03-28-2012, 07:50 PM   #882
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is it slow in blinky?
syndr0me is offline   Reply With Quote
Old 03-28-2012, 08:46 PM   #883
everything is slow in blinky.... but it is at no disadvantage in blinky and might be better on a slick track as it's still smoother then a tekin. I ran both tekin and bd in my tc and couldn't tell the diff on a high bite track. same laptime for both.
Old 03-29-2012, 11:19 PM   #884
syndr0me's Avatar
Yeah, this ESC felt fantastic in blinky 13.5 sedan.
What's the deal with the drag brake. Is 4 really the least (other than none?) It seemed rather strong. Do other versions give you more flexibility with drag brake? I'm on 2.1.
Old 03-29-2012, 11:26 PM   #885
Magnet Top's Avatar
Has anyone used the BD in mod TC ? I'm considering a 10.5 motor with some mild timing ? Are the brakes adjustable enough for a semi mod wind like 7.5 ?
Magnet Top is offline   Reply With Quote
