Old 11-12-2011, 12:56 AM   #826
Smile
Originally Posted by theatriks View Post
Hey guys im running my black diamond with a corally pro red 17.5 ...now i know you guys run this motor here so i figured i would ask ...ny corallly motor is kinda grinding at startup and after i let off the throttle and rite before it stops it makes a grinding noise...is this normal for the corally ?...and i know its the motor because i swapped motors and it didnt make that sound at all.
Rob
Your find that all pro red motors make that noise, it's because the strength of the rotor magnet, try turning the rotor by hand then try the other one and the other will turn easier.
matt prigmore is offline   Reply With Quote
Old 11-12-2011, 08:58 AM   #827
theatriks's Avatar
Ok so is that why it even makes a terrible grinding noise under hard breaking ....
theatriks is offline   Reply With Quote
Old 11-12-2011, 11:40 AM   #828
is it the same noise when you accelorate, then let off the throttle and coast?
Old 11-12-2011, 01:18 PM   #829
theatriks's Avatar
no when its on full throttle or during acceration it sounds smooth and good but just when u left off rite before it comes to a stop it sounds awful...and a bit rite when u start to throttle up and large grinding under hard braking ....and only does it with this motor....the manual reccomends to have your fdr between 4.0 to 5.5 ....mines at 3.7 ....does that have anything to do with it you think?
Rob
Old 11-12-2011, 01:34 PM   #830
Skiddins's Avatar
Rob
My 13.5's and 10.5 Corally's all sounded terrible just before coming to a stop, particularly noticable whening pulling up the the line before the start of a race.
The sound might be due to the gearing, try gearing lower around 4.5 and see if it makes any difference.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-12-2011, 03:02 PM   #831
theatriks's Avatar
Skiddins
ya changed my fdr to a 4.4 and no noise under breaking and sounds a lot smoother but the grinding when slowing down stays but you can tell its the strength of the motor because even when it comes too a stop it still wobbles back and forth for a second or sooo
Old 11-29-2011, 12:07 PM   #832
CFR
CFR's Avatar
How does the USB hook up to the esc?
Anyone care to post a picture?
CFR is offline   Reply With Quote
Old 11-29-2011, 12:19 PM   #833
well you have to buy the specific USB cable from Advanced Electronics (usb connector at one side and a sensor connector at the other)
do you have this cable ?
Ralf is offline   Reply With Quote
Old 11-29-2011, 12:31 PM   #834
Hi fellas, there is a BD with cable on fleabay at the mo, whats a fair price second hand?
Bb
bucketboy is offline   Reply With Quote
Old 11-29-2011, 01:43 PM   #835
joeymdz's Avatar
Send a message via MSN to joeymdz
Bb
its a newer item so i doubt it will be on ebay. email Per and paypal it
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 11-29-2011, 02:53 PM   #836
http://www.ebay.co.uk/itm/Black-Diam...item1c215c7aa2
Bb
Old 11-29-2011, 02:59 PM   #837
joeymdz's Avatar
its in the UK... i thought you meant the US
Old 11-30-2011, 01:05 AM   #838
CFR
CFR's Avatar
so the usb cable has a sensor connector on it that plugs into the sensor port on the esc, thanks
picture on ebay is not very clear
where can you but the cable? link please
Old 11-30-2011, 01:54 AM   #839
Its mine!! cable plugs into sensor port, I'll post to the US for 10.
Its in perfect condition, new sponsorship so can't use it anymore
Mb3195 is offline   Reply With Quote
Old 11-30-2011, 02:59 AM   #840
yes, correct.
send an email to Per Bengtzohn from Advanced Electronics he will assist you
demon@advanced-electronics.se
