Old 04-13-2011, 04:01 PM   #646
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by matt prigmore View Post
The car with the quickest top speed at the stcc at moto arena was running the prototype software and this was by 2 mph and i was speed gunning them too.
since i have been using the bd esc by driving has got a lot more consistent,
the only place the bd lets me down is at the end of the main straight but it pulls very hard out of corner with out any sudden rush of uncontrolable power.(mid corner) so what i might be losing at the end of the straight i gain at the start and i'm looking forward for the update.
im not bashing the BD... i love mine
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 04-20-2011, 06:27 AM   #647
Any news on the V3 ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 04-20-2011, 09:37 AM   #648
Default i given up waiting
did have three 2 sold and last one for sale inc a special RCDYNAMICS BOOSTER these cost 35 on there own. 125 inc postage Uk Extra if posting overseas.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 04-30-2011, 12:21 AM   #649
boy racer's Avatar
I have a BD thats only a few months old and has had very little use (maybe 30 packs tops).
I'm running 1/12 with a 1 cell Lipo and have been using the internal boster from the beginning without issues.
Last night in the final I got about 2/3rds into a race and my AMBrc transponder stopped working and the little light will not come on.
I have two transponders and tried the second one and had the same result.
Both transponders have been tested in ch1, ch3 & ch4 and still no light.
If I plug a 6V battery into the receiver it all works fine.
The servo also works fine from the power supplied by the BD.
It would seem that the AMB transponder needs more voltage to function than the servo and for some reason the BD is no longer able to supply this.
Some of you are going to say run a booster or a receiver battery etc however, I don't understand why it's been working and all of a sudden stopped working.
I have never adjusted any of the settings within the BD since the day I first ran it so I'm stumped on what the problem could be.
If anybody has any suggestions I would really like to hear from you?
Thanks,
boy racer is offline   Reply With Quote
Old 04-30-2011, 05:19 AM   #650
Skiddins's Avatar
Thanks,
I've been trying to remember what the minimum voltage is for the original AMB transponders.
You might want to consider getting an MRT clone of your PT which can work at much lower voltages.
Is running a receiver pack of some sort out of the question?
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-30-2011, 06:13 AM   #651
boy racer's Avatar
Thanks for the reply skiddins,
I just pulled a 4.8V Ni-MH 150mah battery from a Losi Micro T.
Plugged it into the BD (pins 4 & 5).
Problem solved and everything working fine.
But!!!!
I still don't understand why I have to do this in the first place because it's been working perfectly up until last night?
I noticed when connecting everything up using the internal booster the transponder light comes on but it's really hard to see and fades away to nothing.
The AMB transponder requires between 4 - 8VDC
Short term I'm going to have to use the Losi battery if I want my laps counted but would really prefer to run a booster, what's everybody using these days?
Maybe a small 7.4V Lipo would work well?
Old 04-30-2011, 07:35 AM   #652
Is the jumper plug still ok? The little plug you use instead of a booster/receiver pack. My bd always worked fine with the transponder with no boosters ect!
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 04-30-2011, 07:55 AM   #653
boy racer's Avatar
Thanks Jas1,
I removed the little jumper that shorts 6 & 5 so that I could get the Losi mico T battery onto it and it was on firmly.
I noticed after I pulled the jumper that nothing worked until the little battery was fitted so that wasn't the problem.
Worth a shot though.
Thanks.
Old 04-30-2011, 11:34 AM   #654
Trader Rating: 212 (100%+)
Thanks Jas1,
Thanks.
With 1 cell Lipo you have to use a receiver pack or booster. Sounds like your booster has taken a crap. I use my BD in pan car and have used a receiver pack with no issues! I've used both a 2 cell Lipo receiver pack and a LiFe receiver pack. Both work great!
Andy Koback is offline   Reply With Quote
Old 05-01-2011, 01:57 AM   #655
boy racer's Avatar
Thanks Andy,
I have a 7.4v 180mah Lipo on the way.
Fingers crossed this does the trick.
The battery in the Losi Micro T is a 4.8V 150mah Ni-MH and on the heavy side + the Lipo is slightly bigger in capacity.
What are you doing for a switch?
Old 05-01-2011, 10:31 AM   #656
Thanks Andy,
The Lipo pack I have (SMC) has the switch built-in. I also have a LiFe pack with built-in switch from Zipp Racing. Gotta get one with a switch!
Old 05-18-2011, 04:13 AM   #657
CFR
CFR's Avatar
ran mine with a RC Dynamics booster last night and had no issues at all
plugged into receiver and the jumper removed
esc on setting 5 with 10.5 Ballistic on 59.5mmpr
CFR is offline   Reply With Quote
Old 05-18-2011, 04:15 AM   #658
CFR
CFR's Avatar
Software / Firmware
any news on when this will be available for the end user to program the esc?
Old 05-31-2011, 08:54 AM   #659
spencehotbodies's Avatar
Default best spur size for bd
Hello
Am running the bd, love it, am running it with the graupner 13.5, what the best size of spur to run?
The motor is very torquey.
Cheers
Spencer
spencehotbodies is offline   Reply With Quote
Old 05-31-2011, 06:10 PM   #660
Originally Posted by spencehotbodies View Post
Hello
Cheers
Spencer
That would vary alot depending on your chassis. With the BD u need to find the magic FDR for your motor... that will give the best power and speed regardless of track size.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
SEO by vBSEO 3.5.0
