Old 11-19-2010, 01:35 PM   #511
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Originally Posted by Dragonfire View Post
If they release a profile 6 that will be all we need. Same bottom/mid power but slightly faster timing increase on top end for a bit more power there. That would mean no gearing up for top speed. This would easily make it THE ultimate spec speedy on the market.
What would also be nice is a release of the TC version for those that play with TC mod and also those who race in high temp climates.
Profile 6 definately needed...
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 12-11-2010, 03:43 PM   #512
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
any news?
OVA is offline   Reply With Quote
Old 12-13-2010, 04:41 AM   #513
Default up grades
Still in pipe line for a future release, might even be a link for home upgrade ?????.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 12-14-2010, 02:02 AM   #514
Default boosters
Ive now used the RC-Dynamics booster for the last 2 Uk nationals with out a glitch or problem.
This is a special booster plugs straight on to pins 4 and 5 So in affect it is a receiver pack sub with out the hassle of charging all the time.
Booster has a built in switch and is very small only 8 gms.
Old 12-14-2010, 02:16 AM   #515
Is that the 7.4v booster?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 12-14-2010, 07:11 PM   #516
Does anyone know of a single connector that will plug on to pins 4&5 that I can use for my reciever pack. Currently I am using some individual female connectors that I put some heat shrink around. However they don't fit very well.
1/12scale is offline   Reply With Quote
Old 12-14-2010, 07:20 PM   #517
it's not ideal, but I just used a fine point iron and soldered my switch harness to the little pins on the speedo. My receiver pack plugs into a little harness that also has a switch in it. To charge the receiver pack, I just unplug it from the harness, thereby avoiding the need to disconnect anything from the speedo.
vafactor is offline   Reply With Quote
Old 12-15-2010, 02:37 PM   #518
Trader Rating: 215 (100%+)
Some have been using the wires and pins from a motor harness that is no longer trustworthy. Remove a couple of wires from the harness and they plug onto the pins fairly nice. I put shrink wrap around them just to be safe. This has been working for me.
Andy Koback is offline   Reply With Quote
Old 12-16-2010, 12:51 AM   #519
radio_car_racer's Avatar
Originally Posted by Andy Koback View Post
Reove a couple of wires from the harness and they plug onto the pins fairly nice. I put shrink wrap around them just to be safe. This has been working for me.
Would a blob of Shoo Goo on the outside hold them just as well if folk don't want to solder to the pins?
radio_car_racer is offline   Reply With Quote
Old 12-16-2010, 02:21 AM   #520
Default Shoo Goo
Futaba pins and Shoo Goo work great.Been using it for a while now.
Old 12-16-2010, 01:36 PM   #521
You know this is a good idea! For some reason this never crossed my mind. I appreciate the help.
Old 12-29-2010, 09:20 AM   #522
joeymdz's Avatar
Send a message via MSN to joeymdz
Last night was my first time using my BD and must say it was an awesome start. it was VERY LINEAR and had tons of rip from corner to corner. won the first 2 races, tq, 3rd in the main due to lapped traffic and getting stuffed but had the fastest lap (my fault for not having passing patience.. lol) not too shabby for trying to figure out gearing the whole night
This is my issue... when I go through the profiles it will not get out of that mode. (basically Iím stuck unless I recalibrate the throttle, brake, and neutral then Iím good to go)
coming from the "land of tekins" i was really impressed with the BD and cant wait to race next week
thanks for any help
Joey
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-29-2010, 03:22 PM   #523
This is my issue... when I go through the profiles it will not get out of that mode. (basically I’m stuck unless I recalibrate the throttle, brake, and neutral then I’m good to go)
thanks for any help
Joey
You sound like most of the.people here locally who have tried.one....
When you go into the.profiles (hold button until.solid blue.light) you should be able to exit by simply holding down the button for more than.5 seconds. I.just hold it until the cycling.light display stops.
Big tip... The BD does its best to.operate the.motor as effexiently as.possible. Do not try to gear up and up to.match top end with fast tekins/hobbywing systems. You will already be matchng them.down the straight because you kill them initially onto the straight. Settle for a.little.less top end and you will have a frozen motor with faster lap pace.
Powered by Falco
Old 12-29-2010, 05:21 PM   #524
joeymdz's Avatar
thanks for the advice
well im running a genX10 with a boss 10.5 motor. due to the boss thats why i geared up. and by my lap times i did it correctly.
and i know exactly what you mean by killing them initially onto the straight.. i was the only BD car with a field of tekins
Old 12-31-2010, 01:15 AM   #525
joeymdz's Avatar
newbie figured it out.... low battery...then low receiver pack.... THEN LOW TRANSMITTER.... lol (i think i need to charge my stuff more!)
but had some more practice (on a low bite track) had great results and now I have some tekins for sale! **even in profile 3 it still has alot of rip**
