Old 11-12-2010, 03:28 AM   #496
Originally Posted by tellan View Post
Yes connectors straight on to pins 4 and 5. Also if using a 7.2volt booster this can also be plugged str8 in to Esc.
Thank to all of you for the advices
Julo is offline   Reply With Quote
Old 11-13-2010, 12:02 AM   #497
Tellan, i try to wire the booster on pins 4 et 5, it doesn't work. I wired on pin 4 and 6 (without bec) and it works. Don't know why, i have a laje booster.
Old 11-13-2010, 01:18 AM   #498
Default booster, here is the solution.
I mentioned in an earlier post that you need a booster that gives 7.2volts. Only one i know that does that is the RCDYNAMICS .Look at earlier posts.
I tried a novak and TQ and both of those didnt work.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 11-13-2010, 04:37 AM   #499
When i wire the laje booster on pin 4 and 6, it seems to work. I am going to try on the track this sunday.
Old 11-13-2010, 07:27 AM   #500
Dont know why it should work pin 6 is for a switch and pin 4 is the negative pin.
Would be careful what your doing might damage the Esc.
Old 11-13-2010, 12:31 PM   #501
Trader Rating: 216 (100%+)
I thought Per said the booster goes on pins 5 & 6 and receiver pack on pins 4 & 5? Only one of these is necessary.
Andy Koback is offline   Reply With Quote
Old 11-14-2010, 04:00 AM   #502
radio_car_racer's Avatar
Originally Posted by Julo View Post
the laje booster
how is this powered?
on their website you can only see the wires that got to the receiver plug
radio_car_racer is offline   Reply With Quote
Old 11-14-2010, 08:58 PM   #503
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I searched but didn't see anything.
A fellow racer has a V1 BDLV (I think this is the correct terminology. I had to sneak out of the Tekin thread to come over here to ask this. Shhhh...don't tell them I'm here,, lol)
He wants to race in our No timing 17.5 class, but it appears that he needs software the esc didn't come with. Can he have the new software with the spec profile flashed or down loaded some how?
If possible a PM would be great as I will probably forget to come back in here to see the answer...
Old 11-14-2010, 09:03 PM   #504
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
The V2 firmware has the spec(flashing) mode on it. A V1 needs to be sent to Advanced for an update. Assuming it was purchased locally, it could be sent back to the local distributor to be sent on.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 11-15-2010, 04:02 AM   #505
Regional Moderator
CarbonJoe's Avatar
It needs to be sent back to Sweden to be updated. CRC doesn't have the capability to do this.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-15-2010, 04:53 AM   #506
OK, thanks. I'll pass this on.
Old 11-17-2010, 12:02 PM   #507
Mr. MR4's Avatar
Default GM 13.5 with BD
Anyone got a motor setup for 1/10 onroad 2S Lipo for the BD V2 with a GM 13.5 Motor(97294)?
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 11-17-2010, 12:54 PM   #508
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Question between the V1 and the V2 firmware. Does the mean V1 out perform better than V2? Or just the 1s lipo thing!
OVA is offline   Reply With Quote
Old 11-17-2010, 10:54 PM   #509
Default versions
version 2.1 is the latest software, it is rumoured another version is being tested as we speak.
Better top end ,brakes ??????????
Old 11-18-2010, 02:08 AM   #510
If they release a profile 6 that will be all we need. Same bottom/mid power but slightly faster timing increase on top end for a bit more power there. That would mean no gearing up for top speed. This would easily make it THE ultimate spec speedy on the market.
What would also be nice is a release of the TC version for those that play with TC mod and also those who race in high temp climates.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
