Old 11-07-2010, 05:28 PM   #481
Korey Harbke's Avatar
I only saw the version with a 6.0v output. Do I just contact them directly for the 7.2v version?
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-07-2010, 05:56 PM   #482
Regional Moderator
CarbonJoe's Avatar
-Korey
I think he only makes one booster, the 6.0v one.
http://www.rcdynamics.co.uk/Products.html
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-08-2010, 12:33 AM   #483
Default booster, here is the solution.
That is not correct ,a new version for the Novak Kinetic and Black diamond is now available with a 7.2 volts output.
Bought direct from RCDYNAMICS.
CARBON JOE GET YOUR FACTS RIGHT BEFORE YOU POST
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 11-08-2010, 12:47 AM   #484
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
He did say "i think"
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 11-08-2010, 12:49 AM   #485
radio_car_racer's Avatar
RC Dynamics Booster
Is the new 7.2v version the same size as the 6v one?
Why does the BD need 7.2v over 6v. How does it improve the esc's performance?
Post a picture of the 7.2v version next to the 6v one if you can
radio_car_racer is offline   Reply With Quote
Old 11-08-2010, 02:59 AM   #486
Originally Posted by radio_car_racer View Post
RC Dynamics Booster
The only improvement it would make would be a faster servo if the BEC output is above 6.0v.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 11-08-2010, 03:36 AM   #487
whynot's Avatar
Trader Rating: 18 (100%+)
He said he "thinks" If you have it connected to the BD's bec pins maybe it is putting out 7.2v because of the BD. doesnt it convert 6v to 7.2?
whynot is offline   Reply With Quote
Old 11-08-2010, 03:55 AM   #488
Regional Moderator
CarbonJoe's Avatar
Then he should update his web site. There is only one product listed under the "Products" link, a 6.0v booster.
Old 11-09-2010, 01:24 AM   #489
I am going back to Mod for TC next year and have decided to see how far the BDv2 will go in this class (at least until AE gets the TC version 2 out). Added a decent fan and upped the wiring to a more serious gauge. Also added a switch to make life easy. Is anyone playing with modified motors in a TC with this ESC? What motors/FDR's/Profiles are you finding work the best?
Powered by Falco
Old 11-09-2010, 01:56 AM   #490
Default CARBON JOE
Of course your right, the web site should be updated and it will very soon,apoligies given.
The 7.2 booster looks exactly like the 6v version and is exactly the same size. Ive ran the new version for approx 2 hours of running in a 1/12th pan car without a hitch.
When i first bought the BD i tried a normal booster plugged direct in to Receiver .Didnt work well and direct in too Esc didnt work at all. So went down the track of lipo and life packs. Five packs later came up with the idea of a booster with a 7.2 output. Dont why this works but im sure some knows. But the BD is happy with this booster. So much more convienent .
Old 11-11-2010, 02:04 PM   #491
I need help ! I have a BD V2 - I practice 12th and i use a 10.5, 1S LIPO and a team laje booster.
I removed the plug on the pins and i put the + and the - of the team laje booster on the ESC : on the + and - wires.
Am i wrong ?
Julo is offline   Reply With Quote
Old 11-11-2010, 02:07 PM   #492
joeymdz's Avatar
Send a message via MSN to joeymdz
Am i wrong ?
here ya go:
Originally Posted by dumper View Post
You 100% have the newest software, as that is all we have in stock...
Now for the setup stuff...assuming you want to run an external receiver pack and run it through the internal BEC (which is what most people including all of us team guys do) follow these steps.
1-Pull off the "plastic piece", it slides right off with an x-acto knife or something small enough to get in there.
2- Find either a sensor wire, JST connector or extra servo lead that you are willing to sacrifice. Or if you have alot of confidence in your soldering skills, skip this and move to step 4.
3- Take the outer plug off of the sensor wire/plug you are using, you want to use what is inside. What you are going to do, is use the end that is already on the wire. For example, if you are using a JST connector, take an x-acto knife, lift up on the tab holding the connector in, and slide the wire out. Same for a servo lead or sensor wire. You need to get 2 pieces of wire.
4-Now slide the connector end of the wire over pins 4 and 5 remembering pin 4 is negative and pin 5 in positive. Usually using a connector and wire from a sensor wire fits the snuggest. A JST connector works well to, you might have to crimp the connector a little bit to get a nice snug fit. Basically what we are doing here is making leads for the receiver pack to plug into. The reason we do this is because we do not want to keep plugging and unplugging onto those pins everytime we need to charge the receiver pack. If you are very confident in your soldering skills, skip all the connector stuff and just solder a positive wire on pin 5 and a negative wire on pin 4 using a connector that matches up to whatever receiver pack you are using. I personally do not feel comfortable soldering on the pins that is why I came up with finding a piece of wire that already has a recepticle for the pin already on it.
5-Once the wire is on the pins, add a plug that matches your receiver pack and you are ready to go. Now one more thing I have done, is spliced in a switch in between the speed control and the receiver pack plug. Otherwise when you plug in, it is on.
This post makes it sound alot more complicated than it really is. The wiring of the speed control could stand to be a little more user friendly, but once it is done, it is done. The internal BEC is great beacause it eliminates another part of the wiring nightmare that is 1s lipo racing. Even for radio systems that can "handle" 7.4v, it is just less stress on the electronics to do it this way.
Brian Wynn
Team CRC
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 11-11-2010, 02:13 PM   #493
Default Black Diamond pin header option.
Hi Julien,
here are the information in attached document ... enjoy !
Ralf is offline   Reply With Quote
Old 11-11-2010, 03:27 PM   #494
Originally Posted by joeymdz View Post
here ya go:
thank you, That means i have to wire the booster on the BD like the battery receiver ?
Old 11-12-2010, 01:13 AM   #495
Default wiring
Yes connectors straight on to pins 4 and 5. Also if using a 7.2volt booster this can also be plugged str8 in to Esc.
