Advanced Electronics Black Diamond ESC >
Like Tree2Likes
Old 09-17-2010, 04:25 PM
  #406
Rod M's Avatar
my BD went up in smoke last night (only 2 meets old and only 17.5 motors)
connected the battery and off it went (yes it was connected the right way as my leads are different length)
bit if a suprise as this is my first fried ESC in probably 6 years,
what is the repair/warranty process?
Rod M is offline
Old 09-17-2010, 06:33 PM
  #407
FK05 lover's Avatar
Trader Rating: 147 (99%+)
YGPM Rod
FK05 lover is offline
Old 09-18-2010, 02:10 AM
  #408
Pablo Diablo's Avatar
First one I've ever heard of in the entire world. It will have to sent to Advanced, I'll PM you to organize this.
Pablo Diablo is offline
Old 09-24-2010, 03:42 PM
  #409
Default BD LIMITED PROFILE
I ran at the IIC in the 13.5 and 17.5 1/12th classes. Im afraid to say the BD in limited is slow compared to other Escs . I beleive there is not a level playing field as regards the limited profile out puts. I wasnt down on motor horse power in 17.5 as i was using Kenny Lamberts spare motor. When i tried a tekin in a practice run i was almost a second a lap faster.
Did any one else use a BD in limited profile 17.5 1/12th what is your opinion of the controler.
In 13.5 it was awsome.
tellan is offline
Old 09-24-2010, 04:11 PM
  #410
Brian Bodine was TQ and won the IIC 17.5 1/12th limited class using a Black Diamond. He turned consistant 10.5 lap times.
https://www.teamcrc.com/crc/modules....rder=0&thold=0
Crashby is offline
Old 09-25-2010, 02:18 AM
  #411
Can't really argue against that! To me it seems such a waste to use such a great ESC without the timing. The great thing about the BD is that you have the power of timing advance with the throttle control of an old school esc.
Old 09-25-2010, 03:06 AM
  #412
Sounds like someone got it right. I think you will find getting the best performance out of a non dynamic profile will take some work with both gearing and the motors fixed timing setting. Basically its back to school and if you haven't done your home work don't expect to get an A.
Dragonfire is offline
Old 09-25-2010, 06:26 AM
  #413
Default Im stumped
Certainely there was a desparity in speed with a number of cars in 17.5 limited. As regards motor and gearing etc.
I borrowed Kenny Lamberts spare motor ,rollout etc. So what else could i do. When i had a couple of practice runs with the a tekin i went almost 1 sec faster per lap and that equates to 3 laps plus on my time.
Having driven a faultless race in qualifying my best was only 41 laps.Well off the pace.
I still believe the limited profile is not a level playing field as regards performance and power out put.
tellan is offline
Old 09-25-2010, 07:36 AM
  #414
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Bummer
OVA is offline
Old 09-25-2010, 07:59 AM
  #415
Team EAM
Trader Rating: 79 (100%+)
If I get time I can sit down on the dyno and dyno all the speedo's I have or have access to and compare their limited profiles. Finding a V2 BD would be the problem here. I know someone who has the original but is profile 1 on it the same as the limited profile on the new one?
EA
EAMotorsports is offline
Old 09-25-2010, 04:32 PM
  #416
Kenny L's Avatar
Trader Rating: 16 (100%+)
He was running a Tekin
http://www.teamtekin.com/2010-vegas-iic.html
"Tekin also found the podium’s top spots:
Stock Rubber 17.5 Sedan 1st place Dustin Layne, 3rd Brian Stanton
World GT 13.5 1st place Brian Bodine, 4th Monte Hess, 5th Tim Copp
Expert WGT 10.5 2nd place Pete DAgnolo, 4th Donny Lia 17.5
1-12 GTP 1st place Brian Bodine, 2nd Mike Hanulec, 3rd , 4th Tim Pandiscio"
Hope that helps
Kenny L is offline
Old 09-25-2010, 06:02 PM
  #417
1-12 GTP 1st place Brian Bodine, 2nd Mike Hanulec, 3rd Kelly Bean, 4th Tim Pandiscio"
Hope that helps
Dear Tekin,
Please take my name off of you’re website and anything else you might use it for. I did not give you permission to use my name for any type of advertising. I did not put anything down on my sponsorship sheet nor did they announce the type of speed controller I was using.
Thank you,
Kelly Bean
windix606060 is offline
Old 09-25-2010, 06:59 PM
  #418
FK05 lover's Avatar
Yes, Much testing required!
It will be hardest for those who've come to rely on tekin type dial on power (LIKE ME..I still love it!)
Old 09-25-2010, 11:18 PM
  #419
Slapmaster6000's Avatar
Technically, I did have the Tekin in for the "spec" blinkly classes at IIC. My thinking that it was not going to matter who's speedo was in play for the no-timing classes. What I did like from Tekin was the push control setting in wgt 13.5 no time class. It kept the car rolling into the corners instead of dumping the throttle off. For what it's worth, Mario's wgt car had a BD in it only 2.4 seconds back.
I used the BD in 13.5 12th which was a timed class and I did have the current upgrade. The BD is quite strong out of the hole and through the middle. It did eventually finish 5th in the A, but I did have to drive through the back door to get there. I don't think that you will get any argument that Tekin wins the top fuel award down the straight. I had several Tekins put 3-5 car lengths on my BD in the last half of the straight for the first 4 minutes, then it was rather even. In the end, I would have to say the BD is .05/lap faster at the end. They are both outstanding products. They just preform slightly differently. You just need to decide which is best for your 8 minutes.
It's interesting that someone used a BD in spec mode and thought it was slower then Tekin. I took my boosted BD car to our home track for a 13.5 no-boost class. After switching it to spec mode, I was looking for more power all day. I tq'ed and won the main by 5 seconds over a very talented Sean Maybell, but I felt like there should have been more under the hood. I wont be back there for several more weeks, but I will test a Tekin vs BD in spec mode.
Kelly, I understand where you're coming from. I purchased all 3 of my Tekins. If Tekin helped me win a race, it's because I made the right purchase. For what it's worth, I purchased the BD too. They are both great speedo's.
Brian
Slapmaster6000 is offline
Old 09-25-2010, 11:42 PM
  #420
Originally Posted by whynot
Do you guys running the BD in 1s 12 scale use receiver batteries? does anyone use a booster. reason I am asking is cause I think I ruined my li-fe pack I charged it up and been playing around with the car setting up the radio and driving it around on my kitchen floor lol and it died on me. so I went to charge it and the charger is at 0.0 amps I have it set to .2 but it doesnt seem to want to charge it now.I have ready where your not supposed to discharger to low until it is broken in.I think it showed 3.2 volts when I started to charge it it went up to 4.3 and stopped. should I try charging it again? sorry for the long post and rambling lol
mike
I use a 180mah Losi 2s pack on mine. I really think that it would run 3 to 4 runs per charge, but I chicken out and bump it every time. I use the AC charger that comes with the pack; when the green light come "on", it's time to tear it up!
