Old 08-22-2010, 10:50 AM   #331
Originally Posted by whynot View Post
Hey Brian,dragonfire
will this adapter work
http://www.amainhobbies.com/product_...mitter-Adapter
and how about this reciever pack
http://www.amainhobbies.com/product_...ack-66V-200mAh
I do have a dynamite lipo reciever pack that is 180 mah but not sure what would be best.
what switch are you guys using? and since the esc doesnt have a main switch are you putting another one on for the main batt or are you just leaving the batt unplugged until you are ready to race?
sorry for all the questions just trying to get everything ordered for my son and I, he also will be buying the BD within the next week.
thanks
mike
Both of those look fine. You should be able to disassemble the white conecter on the adaptor, then heatshrink and plug into the BD. Stick the other end down to the deck and you have a neat system.
Craig: I just resoldered the wires into the BD, and as said above it comes with the heatshrink to do just that. I imagine we are going to go crazy playing with gearing this thursday! We did some playing today at SMA and Owen was going blow for blow with Demarco's 10.5! The difference on the straight was almost non exsistent.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-22-2010, 05:42 PM   #332
whynot's Avatar
Trader Rating: 18 (100%+)
I just ordered the dynamite passport charger just for charging my receiver pack it can charger from 1-6 amps will it be ok to charger a 200 mah li-fe pack at 1amp or will I fry it? not sure what other charger would be better.
mike
whynot is offline   Reply With Quote
Old 08-22-2010, 07:44 PM   #333
mike
LiFe packs are supposed to be very robust but you will only need to charge at 1c for about 30mins for every 3 runs. No need for more than that and it will last a very long time.
Powered by Falco
Old 08-23-2010, 12:53 AM   #334
Default charging rate for Li-Fe packs
Having fried 2 Li-Fe packs charging at 1amp it is imperative you charge at 0.2amp. I normally get 3 runs from my pack before a charge is needed. But does no harm to to top up as when you have the time.
I have now changed to the muchmore LIPO pack 7.4v it is very neat ,switched and has a seperate lead for charging with out disconnecting from the BD. As regards plugging in to the Esc just remove the wires from the futaba plug by lifting the tabs .Heat shrink the connectors and slightly crimp them for a good fit on the pins on the Esc and you have a nice system.
the lipo is also charged at 0.2amp.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 08-23-2010, 01:15 AM   #335
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Im using a small lipo as well. Theres not much point to a life pack on the BD when the speedie can regulate the voltage anyway
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 08-23-2010, 03:18 AM   #336
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Well, we'll soon see how it goes with a 21.5 in race set up
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 08-23-2010, 03:51 AM   #337
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
I am using a IP life 6.6 2s charging at .6 and all good no problems.. should be .2 but for $13 happy to replace every 6 months
Like the sound of the much more where did you get that from??
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 08-23-2010, 04:03 AM   #338
If I had the space I would get this....
https://www.ssl-stormerhobbies.com/c...s&pn=SMC450RCP
But my testing has shown me that I have no space for best performance so I have to stick with a LiFe pack. I was considering fitting two LiFe packs in my 12th to get even better run time between runs and also this would allow you to charge it faster.
Powered by Falco
Old 08-23-2010, 04:50 AM   #339
Default Dragon
Looks good but too big and too heavy. Why would you want to put too cells in your car i get 3 runs out of 1 .At a push could probably manage 4.
Old 08-23-2010, 04:54 AM   #340
Default Lipo pack this is about as good as it gets
Here is the link to the muchmore receiver lipo.Dont come much better than this. Switched, seperste charging lead and plugs straight in to BD.The one showing is the 300ma but available as a 200ma and 10 grams lighter.
http://www.muchmoreracing.com/index....oducts_id=2147
Old 08-23-2010, 05:32 AM   #341
Its the laziness factor.... I like the idea of running all day with less charging. Also the larger the rx pack, the faster you can safely charge it so the charging time for a couple of runs becomes less. This matters to me as I only use one rx pack. Also I have weight to spare on my chassis so more weight in something useful is a plus.
Powered by Falco
Old 08-23-2010, 06:26 AM   #342
That battery dosent work on BD. I tried it, wired as the instractions say and no dice. The speedie would not even turn on. I think the seperate charge lead or switch confused the speedie. I wired up my 2s lipo the same way, and hey presto, speedie came to life
Stick with a life or small 2s lipo
My 2c
Antoni
Troy check out my battery next week, its big 325 mah thunderpower. I use 32 mah a run, so i can get a fare few runs out of it
Antoni Caretti
Old 08-24-2010, 01:18 AM   #343
Default knocked these up
what do you think.
Advanced Electronics Black Diamond ESC-vdesign1back.gif   Advanced Electronics Black Diamond ESC-vdesign1front.gif   Advanced Electronics Black Diamond ESC-vdesign3back.gif
Old 08-24-2010, 01:43 AM   #344
Default AE BD rollouts for 17.5,13.5 and 10.5
Having tried various motors. LRP X12 all got too hot, Novak Ballastic were good. But the GM are just perfect, cool running and fast all over the track.I have tested over 4000 laps on a large carpet track 35mts X 16mts Ardent Raceway in the Uk.
Using BD on profile 5
17.5=110mm rollout
13.5=89.0mm rollout
10.5=56.8mm rollout
The GM V3 motors have fixed timing at 30 degree advance.
Old 08-24-2010, 06:48 AM   #345
Skiddins's Avatar
17.5=110mm rollout
13.5=89.0mm rollout
10.5=56.8mm rollout
Try the new Corally Red Series.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
SEO by vBSEO 3.5.0
