Old 08-02-2010, 09:58 AM   #301
Default Different motors
I totally agree with that , having done 3000 laps of testing with various motors.
The motor i found the best is the GM range. fast and punchy and low 60c degrees .
Novak are good but get very hot,
LRP and Nosram are none starters, melted the solder off the tabs.
Tekin Duo 2 just couldnt get them to perform,gave up on them.
Tekin redline Ok all round.
tellan is offline   Reply With Quote
Old 08-02-2010, 10:14 AM   #302
What do you think of the new Orion motors? So far I have found them to be the best but have not tried the GM.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-02-2010, 10:47 AM   #303
Default orion
Not a motor Ive tried or even contemplated buying. It will have to be good to be better than the GM V3 range.
Old 08-11-2010, 08:49 AM   #304
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hey Guys,
For those using receiver battery's, how are you wiring them? Using pin 4 and 5 on the speedie, or just directly into the receiver? Which way would be better? My SMC 7.4v 450mah hard cased dosent seem to work through the speedie, the switch must be confusing the speedie somehow Im going to get a life pack soon. What is everyone else using?
Thanks,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-11-2010, 05:03 PM   #305
Skiddins's Avatar
The LRP's and Nosrams seem to run a lot cooler with the Tekin's etc.
It just seems to be when used with the BD that they get very hot.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-11-2010, 05:34 PM   #306
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
If you are gearing the BD with the same gearing as Tekin I would expect it to be hot..
You would be reving the motor like anything.
What LRP x12 are you using?? 10.5, 17.5
I used a 5.5t at the weekend under geared a little and motor came off at like 25 degrees
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 08-13-2010, 02:01 PM   #307
whynot's Avatar
Trader Rating: 18 (100%+)
ordered me a BD today for my new copperhead 12
I will be running 1s 17.5 and I have a nemisis and a duo2.
what motor you guys running is 12 scale 1s 17.5? I also run with a booster I think it is a tq not sure it is lil white shrink wrapped.thinking about using a reciever pack but not sure which one. any help or suggestions would be greatly appreciated. thanks
mike
whynot is offline   Reply With Quote
Old 08-13-2010, 03:43 PM   #308
Is there a website for Advanced Electronics? Does anyone have the address of where to send a BD to get it up graded to the latest software?
Thanks!
Crashby is offline   Reply With Quote
Old 08-13-2010, 05:15 PM   #309
rocketron's Avatar
Trader Rating: 16 (100%+)
Thanks!
Hey Steve... send it to Calandra Racing
rocketron is offline   Reply With Quote
Old 08-13-2010, 07:03 PM   #310
Skiddins's Avatar
It was the 10.5 motors.
The Nosrams were on 6.4 (Tekin) while they are on 5.2 on the BD.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-14-2010, 07:43 AM   #311
Default upgrade to 2.1
Esc needs to go directly back to AE in Sweden free up grade but postage to pay. attention of Per. Address is on Esc box. HTH
Old 08-18-2010, 12:59 PM   #312
whynot's Avatar
How can I tell if I have the newest v2 speedo, it doesnt say anything in the instructions or on the speedo. I dont see where it has a setting for No timing spec class
Old 08-18-2010, 02:41 PM   #313
Set the speed controller to timing profile 1. If it is V2 software the light will flash in neutral.
How long ago did you get it, and where did you get it from? If you got it recently, more than likely it is V2 software.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 08-18-2010, 02:52 PM   #314
whynot's Avatar
Thanks dumper,I ordered it fri and received it today from CRC. Do I plug the receiver battery right behind the plug that is on the esc,if so there seems to be some kind of plastic piece on the pins.
thanks,
mike
Old 08-18-2010, 04:54 PM   #315
thanks,
mike
You 100% have the newest software, as that is all we have in stock...
Now for the setup stuff...assuming you want to run an external receiver pack and run it through the internal BEC (which is what most people including all of us team guys do) follow these steps.
1-Pull off the "plastic piece", it slides right off with an x-acto knife or something small enough to get in there.
2- Find either a sensor wire, JST connector or extra servo lead that you are willing to sacrifice. Or if you have alot of confidence in your soldering skills, skip this and move to step 4.
3- Take the outer plug off of the sensor wire/plug you are using, you want to use what is inside. What you are going to do, is use the end that is already on the wire. For example, if you are using a JST connector, take an x-acto knife, lift up on the tab holding the connector in, and slide the wire out. Same for a servo lead or sensor wire. You need to get 2 pieces of wire.
4-Now slide the connector end of the wire over pins 4 and 5 remembering pin 4 is negative and pin 5 in positive. Usually using a connector and wire from a sensor wire fits the snuggest. A JST connector works well to, you might have to crimp the connector a little bit to get a nice snug fit. Basically what we are doing here is making leads for the receiver pack to plug into. The reason we do this is because we do not want to keep plugging and unplugging onto those pins everytime we need to charge the receiver pack. If you are very confident in your soldering skills, skip all the connector stuff and just solder a positive wire on pin 5 and a negative wire on pin 4 using a connector that matches up to whatever receiver pack you are using. I personally do not feel comfortable soldering on the pins that is why I came up with finding a piece of wire that already has a recepticle for the pin already on it.
5-Once the wire is on the pins, add a plug that matches your receiver pack and you are ready to go. Now one more thing I have done, is spliced in a switch in between the speed control and the receiver pack plug. Otherwise when you plug in, it is on.
This post makes it sound alot more complicated than it really is. The wiring of the speed control could stand to be a little more user friendly, but once it is done, it is done. The internal BEC is great beacause it eliminates another part of the wiring nightmare that is 1s lipo racing. Even for radio systems that can "handle" 7.4v, it is just less stress on the electronics to do it this way.
Brian Wynn
Team CRC
