Old 07-21-2010, 02:31 PM   #286
Originally Posted by Skiddins View Post
Also forgot to mention I had cogging issues off the line.
Whenever I applied full throttle straight away the car would lurch then act like I had stabbed the brakes.
Provided I was a bit more progressive with the throttle the car was fine.
I did try a different sensor wire as well as the variety of gearing.
Skiddins
What motor were you using?
andrew188 is offline   Reply With Quote
Old 07-21-2010, 03:51 PM   #287
nashrcracer's Avatar
R/C Tech Charter Subscriber
anybody had issues with it going backwards on a start?
I have a lrp x12 17.5 -15 timing block and was holding the brake as it's a downhill straight and the car lurched a foot back, I let off and then gased it and it took off forward but by then it was too late and the guy behind me had crashed me into the wall. unfortunately for him he broke hitting me. funny enough he was the only other one out ther running a BD so that took both of us out of a chance to win as by the time I got going back again I was a lap down. I got back to the leader but by then it was too late to pressure him for the lead.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 07-21-2010, 07:33 PM   #288
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Andy Koback View Post
Ran the BD last night with 2 cell and still works fine! No harm! Will try and find some pins to fit the speedo and connect the receiver pack that way. Thanks for all the help!
Take a BL motor sensor harness apart and the small terminals in there fit perfect. Picked up on that when I ran the BD's.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-22-2010, 05:48 AM   #289
Skiddins's Avatar
It has happend with a Corally Red series 10.5 and a Nosram (LRP) x12 10.5
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-22-2010, 03:45 PM   #290
Trader Rating: 216 (100%+)
EA
Never thought of that connector. "Thanks EA"!
Andy Koback is online now   Reply With Quote
Old 07-22-2010, 03:54 PM   #291
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Going to be honest never heard of this one before...
As far as I was aware it was a forward only ESC ...
Saying that sounds like it would have been a good race to watch ... coming from last though the field.
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 07-23-2010, 10:10 AM   #292
I was able to replicate it in practice the other day so it's a weird repeatable issue. I'll see if I can get someone to vid it and post it.
Old 07-23-2010, 05:04 PM   #293
We had a guy at a local track here that had a problem similar to yours. Turned out the motor harness was not pushed into the motor far enough. Connections are very important!!! If nothing else, try a different harness.
Old 07-24-2010, 08:53 PM   #294
There seems to be some issue with the X-12 motors on the BDv2. I can't get either my 10.5 or 17.5 to work in my TC unless I run MAX timing on the motor. It works really well withe the new Orion motors though so give one of them a try if you like a motor with lots of rip.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-28-2010, 02:39 AM   #295
Default testing up date
Had a test day yesterday at the largest indoor permanant in the Uk.Testing with a GM 13.5 and BD esc.
Final run was rollout of 89.5mm using profile 5 and motor timing of 30 degrees advance. After an 8 minute run motor temp was a healthy 68c. Plenty top speed and punch.Tranny exp on plus 10 helps with rip out of corners.
On a direct comparison with a GM 10.5 best lap time was only adrift 0.20 of a sec.
Now too work on the 17.5 with limited profile. Sounds like rollout is going to be BIG BIG BIG. Any suggestions
tellan is offline   Reply With Quote
Old 07-29-2010, 05:03 PM   #296
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default Receiver pack
Just to clarify, if I'm running a little LiFe receiver pack with my BD (12th scale 1C-Lipo), which pins do I use for the wiring of the receiver pack?
Do people use the little plug included in the kit or is there a better method to wire to the pins?
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 07-29-2010, 05:09 PM   #297
Me_MrTyson's Avatar
Thanks Greg G
Greg,
Remove the jumper from 5 - 6
Insert the power cable into pins 5 (+) [top right pin] and pins 4 (-) [bottom right pin]
We have just been adapting an servo extention cable, the spare in the kit is just another jumper pin.
Old 07-30-2010, 10:06 PM   #298
Thanks Greg G
What I used was a small adaptor lead from Team Laser. It is called a "Futaba Female to JST Male" part No. LAH-452. I removed the pins from the JST end and just added heatshrink over the top. Then they plug perfectly into the pins on the BD and you can then stick down the Female Futaba plug onto your deck. This allows you to plug in the receiver pack (like a switch) for racing and unplug to turn the car off and plug the pack into your charger. This is actually a common trick the nitro boys use. You should get at least 3 runs off a standard 200mAh life pack with the BD even with a DP transponder. I have attached a picture so you can see what I have done.
Powered by Falco
Old 08-02-2010, 09:08 AM   #299
Skiddins's Avatar
Skiddins
I tried the Corally motor again yesterday having upped the gearing from 5.6 to 5.37, there was no cogging off the line at all
If anyone is having the same problem, try dropping the profile and upping the gearing and see what happens, would be interesting to see if it is to do with undergearing and too much timing.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-02-2010, 09:15 AM   #300
Skiddins
I don't think so. I tried that when my x-12 wouldn't work and it made no difference. I think the current BD v2 software simply doesn't work with all motors but works fantastic with most.
Powered by Falco
