Old 07-11-2010, 10:42 AM   #271
Trader Rating: 216 (100%+)
Will any receiver pack plug directly into the BD?
Andy Koback is offline   Reply With Quote
Old 07-15-2010, 07:55 AM   #272
Default receiver packs
Providing they are the correct voltage and plug ,why not.I use the Epic 220ma pack manages 3/4 8 minute races comfortable
tellan is offline   Reply With Quote
Old 07-15-2010, 04:48 PM   #273
That's what I'm wondering. Doesn't look like a standard plug will fit. Thought that maybe the BD Lipo came with the proper plug.
Old 07-16-2010, 02:19 AM   #274
Default plug
Use your imagination, just remove the plastic pin holder around the pins and heat shrink them and they work fine out of the black plastic holder.
Or just buy some pins and recrimp them to the wires and also work fine.
Old 07-16-2010, 05:46 AM   #275
The plug I have fits no worries, with a little bit of work initially. My receicer pack is just overkill though with a 500mah lipo. It doez a whole days racing. I want to get something smaller though but want to stick witha lipo due to the beter performance.
In theroy and pack higher than 6v but lower than 8.4v should work as a receicer pack plugged straight into the BEC.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-16-2010, 03:16 PM   #276
With other ESC's, the receiver battery plugs right into the receiver slot. Why can't this method be done with the BD? Does it have to plug into pins 4 & 5?
Old 07-17-2010, 05:35 AM   #277
As far as I know you can do this also. It just that plugging directly into the BEC will give you more life out of the same battery and also does not risk frying you receiver with to high voltage.
Powered by Falco
Old 07-17-2010, 02:33 PM   #278
radio_car_racer's Avatar
Boosters
do I need to run one when running 1s & 10.5?
if yes which pins do I plug it onto?
radio_car_racer is offline   Reply With Quote
Old 07-18-2010, 10:37 PM   #279
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Originally Posted by radio_car_racer View Post
Boosters
There is two ways this will go..
Have used a booster in the past to keep down on charging time.. the problems that caused really was not worth it in the end..
Run a life battery remove the pin and change the battery profile under the solid red light.
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 07-19-2010, 04:57 AM   #280
Boosters
As MrTyson said running a booster pack can cause problems. Even in 10.5 because of the very low motor temps you can run crazy settings on your speedy and not get hot. This means even with a 10.5 it IS possible to dump you main battery especially on a high grip track. For this reason I go down the road of a receiver pack. Using the BD you will find you can do at least two runs with the various 200mah LiFe packs around and never have any problems with your radio system and it is really is only a small inconvenience to charge a receiver pack between runs every now and then.
Powered by Falco
Old 07-19-2010, 03:09 PM   #281
Just for giggles, I plugged the receiver pack (Lipo-7.2 V) into the receiver and turned it on...all 3 lights came on on the BD, with the jumper removed or put back on. Turned it off right away. This can't be normal. No trouble- shooting for lights in the instructions. Would this set-up work?
Old 07-19-2010, 05:39 PM   #282
Me_MrTyson's Avatar
Whole new one on me.. maybe try a battery regulator to be sure not to blow up the BD..
All lights don't sound good for sure...
Old 07-19-2010, 10:55 PM   #283
I imagine the BD is getting power from your receiver. Don't know if it works but why would you bother? The BD offers THE BEST SYSTEM for using a receiver pack of any ESC on the market... Its just seems so much smarter to use it.
Powered by Falco
Old 07-20-2010, 03:29 PM   #284
Ran the BD last night with 2 cell and still works fine! No harm! Will try and find some pins to fit the speedo and connect the receiver pack that way. Thanks for all the help!
Old 07-21-2010, 05:18 AM   #285
Personally I'll be amazed if you manage to blow it up. I have not heard of even a single failure of this ESC to date... Although I'm sure someone out there is trying hard and will succeed.
Powered by Falco
