Old 06-28-2010, 01:47 PM   #256
Default Novak Ballastic 13.5 testing
Got the 10.5 sussed now , Plan to test my 13.5 and BD tomorrow in my 1/12th.
Starting point is retard motor timing 10 degrees from factory setting. BD on profile 5 and rollout at 75mm.
Will checking out temps and see where im at and where i need to be. Ive also sent my other BD back to Sweden to be upgraded with profile 2.1 which is the limited stock profile. Intend to run 17.5 at the IIC. Will post results wednesday .
Final setting for the Ballastic 10.5 in 1/12th is
1.profile5
2.rollout 65mm
3.Motor timing 20 degrees
4.Brake profile 2 (useless)
5.Lipo cut off switched off.
Motor runs at approx 74c after 8 mins
tellan is offline   Reply With Quote
Old 06-29-2010, 09:09 PM   #257
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Dragonfire View Post
If you think you had something broken at moorebank you should see all the bits I pulled out of my car when I rebuilt it last week! And thats not counting the performance three wheel drive rubber! Anyway sometimes things just don't go your way...
Anyway BD went surprisingly well.... The best attribute was the throttle characteristics. The motor follows throttle inputs much like an old style speedo so you have the ability to alter your cars attitude in and out of corners far more than the "traction control" or "switch" behavior of every other speedy I have run (except senna's tekin cause it is "special"). Use is fairly simple to as you gear for speed or grunt. From my days exp I found just gear to match or be slightly slower than who ever you are racing... you will come off stone cold and decimate them out of every turn. The brakes lacked strength but I have not played with brake profiles yet so I may be missing something. Might go do some laps out the front now and work on that...
I think the reason I had problems with it first time I used it was the motor was dead so I had no chance getting anything useful out of the testing.
Good to hear it went well Troy, I'm trying the BD out this weekend with the SP10.5, looking forward to it... I need big brakes tho
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-29-2010, 09:36 PM   #258
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
SP v3 has good brakes, Christian said as good as DUO2 he is using with his LRP so you will be in a good territory
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 06-30-2010, 12:56 AM   #259
Default up date on Novak Ballastic 13.5
Nothing to report ,test was a dud. What i did learn car is dog slow, was almost 1 sec off the pace of my 10.5 and 2 laps.Now this might be the norm but was expecting the car to be fairly close to my 10.5.
I was the only 13.5 running amongst the 10.5 so was hard to compare.
Old 06-30-2010, 09:00 AM   #260
The Roll-out is a little low from what I run. I am closer to 3.0
Steve Dunn
sdunnmcp is offline   Reply With Quote
Old 06-30-2010, 10:02 AM   #261
Default 3.0 rollout
3.0 rollout
I assume that is 75mm so it was exactly what i was running.
Old 07-04-2010, 04:07 AM   #262
CraigM's Avatar
I had the BD on the track today for the first time and was really happy with how it went. Running the speedpassion v3 10.5 motor with can timing maxed and the speedie on profile 5, I started the day at 5.5fdr and ended up at 5.3 with good top and bottom end. Even with drag brake on the temps were well in check so I could probably go another tooth or two next time out. I've run both tekin and venom (hobbywing) recently and the BD held it's own, and all without a laptop
Old 07-10-2010, 09:50 AM   #263
Super Moderator
Funkymojo's Avatar
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 75 (100%+)
Hi guys, i'm looking for a good condition BD with V2 firmware (not the low profile version). If anyone is selling, do drop me a pm. This esc looks really good and would love to try one.
WANKING - Extreme agitation and arousal - usually south of Nanking and short of Farking.
I'm neither a Mod nor a Rocker. I'm a Mocker.
Viper R/C Solutions | Atomic Carbon CR2 LWB | Darth Tray | Losi 8IGHT 2.0-E | Tamiya TRF801X-E
Funkymojo is offline   Reply With Quote
Old 07-11-2010, 05:32 AM   #264
anyone ran this speedo with a Nosram X12 10.5?
how did you find it?
chris_blakey is offline   Reply With Quote
Old 07-11-2010, 05:48 AM   #265
Me_MrTyson's Avatar
Chris,
are you running 12th scale or TC??
x12 10.5, run profile 4 over 5 and 00 or 0000 and gear high seems to work good.
Old 07-11-2010, 06:58 AM   #266
Originally Posted by Me_MrTyson View Post
Chris,
I have a x 12 lrp 10.5 but finding it dies 6 mins in the run cells are good as i can run a gm 10.5 with no problems bar it being a little slower tried the above inserts geared on 47-60 no difference other people are having no probs but they are running the lrp esc mine is the v2 version.Sent the motor back to the distributer to check it but they say no problems.Best run was +5 timing gave the punch back to it on 0000 no punch even in mode 5.
Any ideas
Quietman is offline   Reply With Quote
Old 07-11-2010, 07:19 AM   #267
Any ideas
I have a BD in my TC as well as my 12th. I can not get either my x-12 10.5 or 17.5 to work unless I ran max timing. With max timing you get stupid temps. My tip is sell your x-12 motors and get something wih better top end. The BD with give you the same bottom end of the x-12 with any motor bit you will have more top end. Try the SP if you can live with the plugs but the Novak or Duo are good. Also the new orion is very nice.
Of note I ran 10.5 today in my 12th against a 4.5 and of course he had more punch but the same top speed on a big straight. I ran 65mm on profile 5 with a duo 1 with 10 degrees on the motor. I don't bother temping 12th scale but I could hold onto the motor for as long as I like after a run. I also managed more than a full second a lap quicker lap time over a 21.5sec average lap.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-11-2010, 09:13 AM   #268
Chris,
I will be running in 1/12 with lipo.
Havent bought one yet but I am looking at all the various speedos.
cheers for the input guys
Old 07-11-2010, 10:26 AM   #269
Trader Rating: 213 (100%+)
Has anyone tried the AE Lipo receiver pack with this speedo? Where can a guy get one?
Andy Koback is offline   Reply With Quote
Old 07-11-2010, 10:36 AM   #270
Default AE BD Esc Receiver packs and motors
Ive done intesive testing in 1/12th with a 10.5 and a 13.5 .Tried various motors.
GM ,LRP X12 and Novak Ballastic. I found the Novak was the best for the BD.
As regard receiver pack i use the epic 220ma life cell and its excellent can do 3-4 runs of 8 minutes comfortable and still have power to spare..
