Old 06-17-2010, 12:47 PM   #226
Default Profile 5
Its ok to use in stock racing but if motor climbs above 75c suggest retarding motor timing 5 degrees a pop. Till you have a working temp .Also try rollout reduction till it affects performance.
If all this fails back to where you started and run profile 4. Which in effect reduces timing by 10 degrees.
tellan is offline   Reply With Quote
Old 06-17-2010, 07:34 PM   #227
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Originally Posted by Jochim_18 View Post
Trying to pic up a BD (LV Ver.) for my TC... Any suggestion guys what profile to use?
As everyone is saying Power Profile 5 (blue flashing light) is good in stock..
If you give me a little more info could help you out little more, re gearing etc.
motors you plan to use
track size
verison 1 and version 2 gear a little diffrent.
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 06-18-2010, 06:01 AM   #228
Skiddins's Avatar
Can you give us any more info about how many degrees of timing is added in each profile?
I'm having trouble keeping the temps down at any gearing.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-18-2010, 06:03 AM   #229
Skiddins's Avatar
Originally Posted by tellan View Post
Solved the lag off the line by just advancing the Throttle profile on tranny to +5.Lag solved.
What do you mean by adjusting the throttle profile by +5?
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 06-18-2010, 06:53 AM   #230
Jochim_18's Avatar
If you got older motor no matter what you do it seems like they run hotter than when they are new. Unless you are running LRP X12 line of motors they like it hot
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-18-2010, 06:56 AM   #231
I think i may be the only runner in the Uk in 1/12th racing , it just hasnt caught on . Supply was the initial problem, then price was an issue . Now that is available its kind of missed the boat.
Tekin Rs is the hot baby to have in the Uk. Ive just sold all mine and moved to BD I have 2.
Nope i have one too
Quietman is offline   Reply With Quote
Old 06-18-2010, 11:00 AM   #232
Me_MrTyson's Avatar
Skiddins
There are 5 profiles on the software used by BD..
1 - Stock Spec 0 degree timing
2 - 10 degrees Timing
3 - 20 degrees Timing
4 - 30 degrees Timing
5 - 40 degrees Timing
personally am using the sp V3 17.5 with about 4.5 fdr max timing on the motor.
this comes off at 62degrees after 5 minutes and no Fan..
This is based on my local track which has a big amount of grip.
Outside again depends on the track, could run from anything from 3.9-4.3 FDR
Old 06-18-2010, 11:49 AM   #233
Smile
Hi
Anyone know what to use a lv bd in a 1/12th lipo 10.5 x12 gearing would be and what profile on the esc think 4 or five and should i retard the timing ? Any
Thoughts ?
Old 06-18-2010, 12:25 PM   #234
Skiddins's Avatar
I hope so, mine comes off at 90degC almost every run!
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 06-21-2010, 04:21 PM   #235
Me_MrTyson's Avatar
Originally Posted by Quietman View Post
Hi
Thoughts ?
Setup for x12 10.5,
Run 0000 timing, power profile 4 and start at 54 rollout (track depending) but good ish starting point.
if you are making 8 min runs and not over heating you have 2 options up the rollout or move to oo.
Based on the track this would be my direction.
Did test on profile 5 and X timing, the power was wild but thing overheated quickly made it hard to drive so much torque out of corners..
Old 06-22-2010, 02:49 AM   #236
Default timing and rollout
Novak Ballastic 10.5
Settled for 10 degrees retarded from factory setting and rollout of 62mm and profile 5.
Temperature usually about 70c. Would like lower.
If I ran on profile 4 and moved timing on motor up 10 degrees what would be the effect or nothing.
Ive only ran on profile 5 but now dont have the time for testing .Differcult to do on race days as time is precious.
Old 06-22-2010, 02:57 PM   #237
Default lost my instruction sheet
Stupid me. I've lost the little instruction and setup booklet that came with my AE speedo. Can someone please direct me to a site where I can access and download the instructions?
vafactor is offline   Reply With Quote
Old 06-22-2010, 03:26 PM   #238
nevermind. I found the setup sheet.
Old 06-23-2010, 07:52 AM   #239
Default VER 2.1 Limited stock profile
Any one used this profile with a 17.5 yet. See it is a 1/12th class at the forth coming IIC in vegas.
BD will now be allowed thanks to Frank at CRC.Looking for some info on using a Novak 17.5 with the limited profile. Motor timing and rollout.
Old 06-23-2010, 09:07 AM   #240
Skiddins's Avatar
Anyone run the LRP X12 10.5 with the BD and what difference in gearing /profile you used.
I tried profile 5 for the first time with 6.77FDR on this track;
With this layout;
The car was very fast but the motor came off at 107degC (225degF)
On profile 4 the motor was coming off around 75-80degC on the same FDR
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
