Old 04-10-2004, 12:02 PM   #1
bballer's Avatar
Unhappy Ko Mars Problems
AHHHHHH!! I just bought a used ko propo mars radio and the instructions were sent seperately and haven't come yet. anyway, i can't figure out how to set the steering and throttle travel to be equal. I reach the steering travel menu and then if i press and hold the m. select/select (top right) button, it shows the other side's travel, which is 45 clicks less. How do i set them to be equal? Thanks
bballer is offline   Reply With Quote
Old 04-10-2004, 12:17 PM   #2
SlobbaTech's Avatar
You need to go into system mode first I think to make sure the system level is on 4 which has the most options to change stuff. There are 2 ways to get into it; 1: Turn radio off, hold down +, -, & select buttons then turn radio on. 2: With radio on push up and down button at same time and hold for maybe 2 seconds until LCD says system mode. Once in there scroll around until it says System Level and turn it so says 4, then turn radio off then back on or hit direct mode button twice to get out of system mode.
Then scroll up to steering travel for max steering throw, then one after that should be steering balance, you have to turn wheel on radio to right or left for the number % to pop up, then +/- number until your car is set right. Scroll up little more and you're at throttle and brake epa.
SlobbaTech is offline   Reply With Quote
Old 04-10-2004, 01:12 PM   #3
bballer's Avatar
sorry, im not sure i understand. Is there a specific menu for epa? Ive looked for one but i can't find it. Thanks
Old 04-10-2004, 07:38 PM   #4
Speedie's Avatar
When you first turn on the controler. Hit up once to set the steering travel, up twice sets the steering travel right to left just turn wheel all the way right and use the +- keys to adjust then do same with turning left. up 3 times seth the throttle Hipot.
I think thats what your asking.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
KO EX10/Mars S/Mars R Spectrum Module & Receiver Crawler R/C Items: For Sale/Trade 7 01-26-2008 07:08 AM
KO MARS AND MARS R 40MHZ MODULE(RF103F) WITH RECEIVER KR-301F AND CRYSTAL SET (RARE) Sigearhead R/C Items: For Sale/Trade 2 05-03-2007 05:19 PM
spektrum pro system for Ex-1, Mars, Mars R, Ko propo willabong Australia For Sale/Trade 1 03-18-2007 08:15 PM
mrx3, ko mars r special edition , ko mars brooklynrc R/C Items: For Sale/Trade 9 08-26-2005 05:47 PM
does the mars r rcvr work with the standard mars? VenomWorldOrder Electric On-Road 10 07-02-2003 11:09 AM
SEO by vBSEO 3.5.0
