Old 12-17-2010, 11:42 AM   #1456
Trader Rating: 22 (100%+)
Originally Posted by phattyphatty4x2 View Post
Fair enough. So, if I am correct, the db12rr used the old style center pivot(according to my eyeballing). Is there any of these available? I would like to get some spares for my son's car too. Or is it a dinosaur now?
Stormer Hobbies has a few instock.
bjspinner is offline   Reply With Quote
Old 12-17-2010, 11:53 AM   #1457
JayBee's Avatar
Trader Rating: 31 (100%+)
I miss my car
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-17-2010, 11:57 AM   #1458
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
Originally Posted by JayBee View Post
I miss my car
you sold your 12th
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-17-2010, 11:59 AM   #1459
JayBee's Avatar
Nahh.....I just don't have it right now
Old 12-17-2010, 12:02 PM   #1460
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
OVA is offline   Reply With Quote
Old 12-17-2010, 12:06 PM   #1461
JayBee's Avatar
What are you doing posting on this thread Franko....
Old 12-17-2010, 01:39 PM   #1462
OVA
OVA's Avatar
I'm making sure that you don't get too far ahead of me
Old 12-20-2010, 11:20 AM   #1463
Trader Rating: 43 (100%+)
Anyone else having issues with IRS rear ride height inserts? I keep breaking the left side in half.
biz77 is offline   Reply With Quote
Old 12-20-2010, 11:26 AM   #1464
20 SMOKE's Avatar
they may be weak,i broke the right hub yesterday and nothing else
Jamie W
Old 12-20-2010, 11:48 AM   #1465
JayBee's Avatar
No...not at all. And I've had all of mine for several years now.
Old 12-20-2010, 12:16 PM   #1466
Trader Rating: 36 (100%+)
IRS ride height adjusters suck, they're very brittle plastic. Check out CRCs ride height adjusters, they have .25 increments and the plastic is softer and hold up much better.
EVILGRAFX is offline   Reply With Quote
Old 12-20-2010, 12:39 PM   #1467
pmes's Avatar
I broke a few different sizes of the IRS spacers that came with my CH12, but I was just getting back into the groove after a 20 year break from 1/12th. However, I got the CRC spacer set and have not broken one since. I can also keep my rear ride height dialed in much more closely as my tires wear.
pmes is offline   Reply With Quote
Old 12-20-2010, 01:53 PM   #1468
Never had the issue on my DB12R or DB12RR either, but I've broken two now in the last three race events. Thanks for the tips on the CRCs.
Old 12-21-2010, 04:37 AM   #1469
speed-e's Avatar
Trader Rating: 28 (100%+)
Default front flex plate fatigue
On both of my cars with the new front end, it felt like the front flex plates fatigued and needed replacement quicker than a set of springs would require. I think the reason was that the NFE has a huge amount of travel. Even after limiting the droop to .5mm the up travel was still some 10mm beyond where the chassis bottomed out. I suspected that running over dots, rubbing barriers, and wrecks would cause the arm to move up to it's full range placing a huge strain on the flex plate. This would lead to premature fatigue and delamination.
I made an up travel limiter and installed new flex plates. The car was consistent and turned some of the fastest laps of the race day without demonstrating any signs of flex plate fatigue.
What do you think Jason, can you engineer in an up-stop for guys like me who occasionally drive into things fast?
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 12-21-2010, 05:29 AM   #1470
protc3's Avatar
Very interesting buddy. Shoot a pic and post it. If i can make it or modify the existing setup, i will use it. Its nice to see you guys using your creative minds.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
SEO by vBSEO 3.5.0
