Old 12-04-2010, 10:43 AM   #1396
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Joost K. View Post
What are you Yeehaa-ing for then?
it was from a show called crank yankers and every time special ed got mail he would say yea.
+ YouTube Video
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-06-2010, 07:13 AM   #1397
Edgar_P's Avatar
Can somebody tell me the size of e-clip for silva shock shaft?
BMI COPPERHEAD 12
Edgar_P is offline   Reply With Quote
Old 12-06-2010, 07:23 AM   #1398
Joost K.'s Avatar
OMG that's irritating!!! I don't know that show... I'm dutch
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 12-07-2010, 02:21 AM   #1399
Edgar_P's Avatar
Nobody?
BMI COPPERHEAD 12
Old 12-07-2010, 06:10 AM   #1400
protc3's Avatar
I will pull one out and measure it. I will get back to you.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-07-2010, 06:13 AM   #1401
20 SMOKE's Avatar
we don't want you to pull it out a measure,thats for the GF
Jamie W
Old 12-07-2010, 06:29 AM   #1402
pmes's Avatar
What size are the e-clips for the hinge pin on the NFE?
pmes is offline   Reply With Quote
Old 12-07-2010, 10:10 AM   #1403
protc3's Avatar
It looks like the shock e clip is one for a 2mm shaft. The front end ones look to be the same but the shock on is a smaller diameter. Im not sure where silva gets them in such a small diameter. They are usually standard sizes for each shaft size. Best bet would be to contact them. If you are in need of them, i do have them in stock. There is just no size description on the bag from silva.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-07-2010, 10:32 AM   #1404
Trader Rating: 44 (100%+)
RC4less.com sells the silva rebuild kit, which comes with many new o-rings and a bunch of new e-clips.
biz77 is offline   Reply With Quote
Old 12-07-2010, 11:13 AM   #1405
protc3's Avatar
We have the rebuild kits as well. I will need to check the website to make sure they are on there.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-07-2010, 11:23 AM   #1406
20 SMOKE's Avatar
J,did you see superior is using K-raceway for its club racing know.one word Pro 10
Jamie W
Old 12-07-2010, 11:34 AM   #1407
I found the e-clips for the HB shock fit a bit better. On my DB12RR I lost the Silva e-clips so used the ones from my HB shock. They fit better and got rid of the small amount of movement of the piston on the shaft.
Old 12-07-2010, 11:54 AM   #1408
Default front droop?
How are you guys setting droop on the new front?
I'm currently using a single ride height gauge (going to purchase another) and placing directly in center at front of chassis at .5mm (or whatever the desired droop is) higher than my ride height setting. I then adjust the droop screws until tires on both sides just touch the ground. I figure one gauge on either side will give me a little more accuracy.
Old 12-07-2010, 12:15 PM   #1409
20 SMOKE's Avatar
use two ride height cauges and measure the movement over the ride height
Jamie W
Old 12-07-2010, 12:46 PM   #1410
JayBee's Avatar
Trader Rating: 31 (100%+)
Yes, as 20 SMOKE has said use two (stepped) ride height gauges at each of the corners on the front end of the chassis and continue to do it the way you have described. Pretty stinking accurate this way.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
