Old 12-01-2010, 08:54 AM   #1366
Joost K.'s Avatar
Towards the front...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 12-01-2010, 10:28 AM   #1367
Trader Rating: 44 (100%+)
Also running 15K in side tubes and 20K up front. Does that sound correct?
biz77 is offline   Reply With Quote
Old 12-01-2010, 10:32 AM   #1368
Joost K.'s Avatar
Anyone know with what oil you could compare the SurLube's? They come in numbers 1 to 6 what how thick is that comparing to a 10.000, 20.000 etc.???
Anyone?
Old 12-01-2010, 10:35 AM   #1369
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
4-5 is around the 10-20k,some where in there
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-01-2010, 10:48 AM   #1370
I always assumed, perhaps foolishly, that they were in 5K increments, starting at 5K.
1: 5K
2: 10K
3: 15K
4: 20K
5: 25K
6: 30K
Old 12-01-2010, 10:50 AM   #1371
Joost K.'s Avatar
And assumption is the mother of all FU's
Although it sounds logical what you have just posted, can somebody confirm this please?
Old 12-01-2010, 10:54 AM   #1372
I don't think anyone knows for SHUR
I've scoured the internet and there only seems to be conjecture.
Old 12-01-2010, 11:13 AM   #1373
Joost K.'s Avatar
Correct! Not even ShurLube gives out this info... Not even sure they have a website anyway...
Old 12-02-2010, 08:12 AM   #1374
pmes's Avatar
As far as I can tell Shur Lube is made and distributed by Rob Murdock, 1504 320th Street, Sloan, Iowa 51055. phone: 712-428-4679 email: rob@windtunnelracingproducts.com
pmes is offline   Reply With Quote
Old 12-02-2010, 08:37 AM   #1375
2wdrive's Avatar
Or use the serpent or any other 1/8 oils. They have oils up to 200.000 if 50.000 isn't stiff enough for ya
I use corally damper syrup and it's exactly the same thing, no way of knowing what exactly the thickness is. Next time i wil go for the 1/8 brands, at least then it is clear what it is.
2wdrive is offline   Reply With Quote
Old 12-02-2010, 09:10 AM   #1376
Guys,
I (and a fellow club member with a BMI) had the same question last winter as I wanted to have an accurate weight on the Shur Lube kit #1 - #6 before spending $$ on the whole kit. I didn't find an answer very quickly and switched over to the Mugen 1/8th scale diff lubes. They work fine and have a good selection of incremental steps. Much after the fact, I'm SHUR we came across the info a month or two after we needed it. One of us has it filed away in our notes someplace - hold on and I'll see if I can track it down in the next day or two, hopefully.
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 12-02-2010, 09:18 AM   #1377
Joost K.'s Avatar
That is not the problem Alexander, al lot of set-ups here are assigned with ShurLube numbers and if people have a reference to this they can more easily use other lubes since ShurLube is not available everywhere as easy as in the states...
Old 12-02-2010, 09:27 AM   #1378
2wdrive's Avatar
ah, on that bicycle
Ok, yeah then it would be indeed handy to know..
Old 12-02-2010, 10:09 AM   #1379
well if you do use sure lube makes sure to store the bottles upright or they will leak.
Old 12-02-2010, 07:22 PM   #1380
Trader Rating: 34 (100%+)
Josh Keller is offline   Reply With Quote
