Old 11-11-2010, 11:16 PM   #1276
As soon as I get my DB10R back and make sure both cars are cleaned up I will have my DB12RR and DB10R available for sale. I don't need to keep those around now that I have both of the Copperheads
Old 11-12-2010, 01:24 PM   #1277
JayBee's Avatar
Trader Rating: 31 (100%+)
Can't wait to try that change. And it goes right under the arm. Thanks Jason.
BMI Racing "Copperhead 12" discussion and support-db12rr-17.jpg   BMI Racing "Copperhead 12" discussion and support-db12rr-19.jpg   BMI Racing "Copperhead 12" discussion and support-db12rr-18.jpg
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-12-2010, 01:33 PM   #1278
protc3's Avatar
Let me know how it goes buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-13-2010, 06:05 AM   #1279
Hi Jason!
There is "any" chance for your front end to 12R5.1 ?
Thank you!
Michal
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 11-13-2010, 06:30 AM   #1280
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
what did you do
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-13-2010, 10:26 AM   #1281
JayBee's Avatar
Check out the servo saver Gives a bit more Ackerman...
I was worried about the tbuckle hitting the arm.
Old 11-13-2010, 11:48 AM   #1282
protc3's Avatar
Originally Posted by M.Abramowicz View Post
Hi Jason!
Thank you!
Michal
At this time there is no plans. Originally, i was going to but with it being in such high demand for our car, i want to make sure i can keep up and support my customers. If i get things to where i can fully support the front ends for our car without any problems, i will look into making it for other cars. Sorry for the inconvenience.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-13-2010, 12:18 PM   #1283
20 SMOKE's Avatar
i did see it
Jamie W
Old 11-13-2010, 12:27 PM   #1284
Thanks for replay!
So I will try order front end kit and put it by myself ;P
Regards!
m.
Michal Abramowicz
Old 11-13-2010, 01:22 PM   #1285
speed-e's Avatar
Trader Rating: 28 (100%+)
Thanks for replay!
Regards!
m.
That's what I did some four weeks ago on both of my 12r5is. Not very difficult to mount the front end. Be sure to order the 1.8 mm flex plates too.
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 11-13-2010, 05:52 PM   #1286
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Well, my practice from Thursday paid off today.
Only change I made from Thursday was going to the 1.8 flex plates in the front, in the soft position, replacing my stock 1.5's that were pretty abused and fatigued to the point that I had a real tough time getting ride height with 42mm front tires. The 1.8's settled after the first 2 runs today, needing a little adjustment between rounds to bring the front ride height back up, and then held solid the rest of the day, no issues and a ride height close enough to my start setting that tire wear would account for the difference.
Speaking of tire wear, I saw right at 1mm on the day, front and rear, rotating the tires only once, after the second qualifier, and the tires are even left to right.
The car was predictable with a very slight high speed push and only a brief hint at double steer mid-sweeper, neutral off-power, and I'm pretty happy with the steering and stability at corner exit.
That said, the car was definitely better than I am with it at the moment. We didn't have a bad turnout today, but not huge either, 8 guys running boosted 10.5 today, which was split into 2 mains, but I made the cut to start last in the A And turned nearly double the amount of laps on the day than I was able to manage last week with the spin-o-matic car I had last week.
So again, for the guys that gave me suggestions to try, thank you, the car is good enough to make me learn to drive it mistake free, and then worry about finding the extra 3-5 tenths of lap time I'm still lacking.
Unfortunately, I didn't finish the A-main due to an exploded rear axle bearing, but I'm still grinning from having such a fun car to wheel, and seeing improvement each time on the track, bot from the car and myself.
Thanks again guys.
I won't be able to race due to work for a month, but I do have one question.
When I get overly aggressive on steering and throttle, typically on a 180 turn, I'm sometimes lifting the inside rear tire and diffing out, making for a somewhat adventurous corner exit. I learned to open my line up and take smoother arcs around the track, but is this a setup issue, or driving issue?
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 11-13-2010, 06:34 PM   #1287
LonnyJ1950's Avatar
I would suspect a set up issue, though you may be just snapping the car into the turn too hard. I would try gray rears, or if you're not gluing your rears, you could try that. A firmer front may also help. If it's fairly extreme you may need a firmer side spring, but before you go that far, use heavier spooge in the dampers, which should also help with the double steer. Congrats and good luck.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 11-13-2010, 06:47 PM   #1288
JayBee's Avatar
Yes I would try heavier damper spooge first....sounds like there's too chassis movement.
Old 11-13-2010, 07:18 PM   #1289
20 SMOKE's Avatar
+3 n the heavy spoooooooge,ok got a little carried away
Jamie W
Old 11-13-2010, 07:36 PM   #1290
avs
avs's Avatar
how is this different? i thought the inside wheel diffing out was a sign of too heavy lube?
Tony Shimko
avs is offline   Reply With Quote
