Old 04-07-2010, 11:23 AM   #106
Did you check the balance of the car left to right? Looks like it would be heavy on one side with the ESC and servo being on the same side.
Old 04-07-2010, 01:29 PM   #107
schmutz's Avatar
Send a message via ICQ to schmutz
Hey Guys,
new Setupsheet for the Copperhead Cars is on work now.
At time you can use the latest Version of (editable) DB12RR / DB10R Setup Sheet.
The Sheet you can find in Download Area at raceport.net
Sorry i cant post a direct link.
Keep Racing.
Marcel Schmutzler
Raceport / TEAM-POWERS / T.O.P. Racing
http://www.youtube.com/user/Raceport
www.raceport.net
schmutz is offline   Reply With Quote
Old 04-07-2010, 04:17 PM   #108
HarryLeach's Avatar
Send a message via AIM to HarryLeach
I did a rough balance when I put all the electronics in place and it didn't look like it would take much to finish balancing.
But, this morning, I discovered I was going to need around 27 grams on the left side to get it to balance
A little testing shows the RS is a tiny bit heavier than the RX/TQ booster, and of course the servo is a bit heavy on the end opposite the output shaft. The surprising bit is that the CRC battery is a bit heavier on the side opposite the bullets. So, I had all the heavy stuff on the right.
Corrected now. Not as pretty on the wire layout, but should work, and only took 3g to balance.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 04-07-2010, 08:17 PM   #109
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
harry I'm running asphalt
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-07-2010, 08:19 PM   #110
20 SMOKE's Avatar
Originally Posted by schmutz View Post
Hey Guys,
Keep Racing.
to help you out
http://www.petitrc.com/reglages/bmi/...SetupSheet.pdf
Jamie W
Old 04-07-2010, 08:47 PM   #111
HarryLeach's Avatar
Alright, so up about 1.5 mm on the ride height compared to what was recommended to me on carpet. Thanks for the info.
Old 04-08-2010, 02:02 AM   #112
H I
H I's Avatar
Trader Rating: 18 (100%+)
I see you are running Tekin solder posts on inside. You should face posts on out side as they use them as heat sink. Not sure how hot your ESC gets but it should help balance your car with out adding weight as well. Mine gets pretty hot running mod here in Australia.
Is it better to fit turnbuckle ball caps on front of servo saver?
Iíve been running behind servo saver on my both DB12R and DB12RR.
Does it make difference?
H I is offline   Reply With Quote
Old 04-08-2010, 02:51 AM   #113
In 1/12th scale running anywhere from 17.5 to 10.5 I haven't had my RS even really get warm. On my TC I plan to turn the posts to the outside because I'm getting some fade which may be heat related.
Old 04-08-2010, 04:19 AM   #114
20 SMOKE's Avatar
HI,add another cap this will help with heat in mod,with the ballcups going in front or back of the saver is changing the ackermann but the servo will have to be spaced out,mine is in the front i don't think i can get it behind the saver as the servo may have to be spaced out to far and may not work with the angle mount
can some one take a pick of the lipo rx pack,just curious to the size
Jamie W
Old 04-08-2010, 07:45 AM   #115
HarryLeach's Avatar
I'm running 10.5, and the qualifiers can get pretty crazy at my local track with a wide range of skill levels. I'm not new to the RS, but I decided to put the posts inboard to protect the posts against possible impact damage. I haven't seen or heard anyone that I'll be racing with complain about the RS heating up too much.
If I were running mod, I would do something to get more airflow across the posts.
Old 04-08-2010, 02:42 PM   #116
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guy's,
Here's some pictures of mine from my iPhone. I purchased the upgrade kit, don't mind the Blue anodize that's from my DB12RR. The Copperhead 12 been really great!!!
BMI Racing "Copperhead 12" discussion and support-photo1.jpg   BMI Racing "Copperhead 12" discussion and support-photo2.jpg   BMI Racing "Copperhead 12" discussion and support-photo0.jpg   BMI Racing "Copperhead 12" discussion and support-photo3.jpg
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 04-08-2010, 04:48 PM   #117
20 SMOKE's Avatar
holly wires batman j/k,how does the car work from the rr to the CH
Jamie W
Old 04-09-2010, 02:05 AM   #118
schmutz's Avatar
Hey Guys,
the Copperhead Setup Sheets have finished.
Please find them at Raceport.net (in Download Area) also at PetitiRC.
Please help me somebody to post a directlink
Keep racing.
Marcel Schmutzler
www.raceport.net
Old 04-09-2010, 04:48 AM   #119
20 SMOKE's Avatar
Jamie W
Old 04-09-2010, 07:30 AM   #120
AdrianM's Avatar
Copperhead 10 and 12 assembly manuals and editable blank setup sheets are now in the Technical info section of the website.
http://bmiracing.com/bmiv4/index.php...id=4&Itemid=28
Adrian Martinez
