Old 10-27-2010, 07:12 AM   #1156
protc3's Avatar
Originally Posted by avs View Post
hi Jason,
can you clarify the part #'s for the pivot ball assemblies?
CH3029 is listed as the 'single mount pivot ball housing'. i presume this is the new style housing but with one fastener hole for the new front end outer pivot.
i think DB3029 is the multiple piece pivot ball from the db12.
so what is the part number for the '2 point mount pivot ball' that replaces DB3029?
DB3029 is the part number. The new pivots replace the old ones and function the same. The difference is that we now press the pivot balls in for you.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-27-2010, 09:27 AM   #1157
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
J,all good now
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-27-2010, 11:29 AM   #1158
protc3's Avatar
Cool
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-27-2010, 09:41 PM   #1159
c-lyon's Avatar
JayBee pm. Thanks.
c-lyon is offline   Reply With Quote
Old 10-29-2010, 02:18 PM   #1160
EricF's Avatar
Jason-
What do I need to go from a DB12R to CH12 with out buying a complete kit, can it be done?
Would it be less $$ to udate to the RR with the new FE?
Should I just call the shop?
Thanks,
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 10-29-2010, 02:23 PM   #1161
protc3's Avatar
Let me look and see what would be needed. I will get back with you on monday on that
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-29-2010, 02:30 PM   #1162
EricF's Avatar
ok, thank you.
E
Old 10-29-2010, 03:37 PM   #1163
Lee_123's Avatar
Originally Posted by 20 SMOKE View Post
f1 with the new style front end,not until the 235 is done
+1
Member of "The Seldom Seen R/C Racing Team"
RC10L (Pro 10, WGT), TC4, BMI DB12RR, Scalpel
Lee_123 is offline   Reply With Quote
Old 11-01-2010, 02:37 AM   #1164
Joost K.'s Avatar
Yesterday I had the first race with the CH12 and I can say, the car went very well... I made it into the A final and qualified 5th. All three qualifications went great and the car handeled very good! In the first final I jumped from 5th to 3th place in the first lap and everything was going okay but because of a steering mistake followed by some rubbing with another car it set me back to 7th
The second final started well and again I was able to gain some places from 5th to 2nd & 3rd but halfway down the final the car was again touched by another car and went airborne which resulted in a broken cross-brace
That lead to the fact that I couldn't drive the 3rd final.
Overall I can say that the race was very good but I did notice that the CH12 is a very aggressive cornering car and you really need those tune-up parts for the front end...
All in all I was really exited about the CH12 and the only thing you do when you get off the track is clean the car, change the tires and charge the cells and wait fot the next heat to come. There is no extra wrench-time needed between the heats, the diff stays as it is the whole day as well as the settings... Great day for me and the CH12!!!
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 11-01-2010, 09:16 AM   #1165
pmes's Avatar
Here's a list of parts I have compiled that one should have to maintain their Copperhead 12:
CH1041 - Copperhead 12 Chassis Brace
CH1071 - 7075 2MM FRONT AXLE SPACERS
CH1070 - FRONT STANDOFF SET (2mm extended)
CH2001 - 1.8 MM FRONT FLEX PLATES PAIR
CH2002 - 1.5 MM FRONT FLEX PLATES PAIR
CH2010 - COPPERHEAD NEW LOWER FRONT ARMS
CH2060 - STEERING BLOCK WITH HELICOIL
CH3017 - Copperhead 1.2 Carbon Fiber Flex Links
CH3018 - Copperhead 1.5 Carbon Fiber Flex Links
CH3019 - Copperhead Fiberglass Flex Links
CH3025 - FRONT UPPER EYELETS WITH PIVOT BALL
CH3029 - SINGLE MOUNT PIVOT BALL HOUSING WITH PIVOT BALL PAIR
DB1080 - Body Mounts
DB1081 - Body Mount Pivot
DB1093 - ball cups
DB3020 - Center Pivot Ball Housing and Ball, Delrin/Alloy
DB3029 - Flex Plate Pivot Ball Housings Complete
DB3055 - Center Shock Spring, Blue 10lb.
DB3056 - Center Shock Spring, Gold 12lb.
DB3057 - Center Shock Spring, Red 14lb.
DB4050 - Rear Axle Shim, Alloy 3mm
DB5305 - Carbon Servo Saver Brace
DB5401 - Bumper, DB12R, High Density Foam
DB6495 - Standard Nickel Teflon Ball Studs
pmes is offline   Reply With Quote
Old 11-01-2010, 09:22 AM   #1166
20 SMOKE's Avatar
thats almost a hole car
Jamie W
Old 11-01-2010, 09:24 AM   #1167
pmes's Avatar
many of those parts don't come with the kit.
Old 11-01-2010, 10:00 AM   #1168
JayBee's Avatar
Trader Rating: 31 (100%+)
Not a good raceday yesterday My car wasn't up to speed....wanted to 'donkey-flip' the first couple of laps then got really good for the first half of the race, then it was dumptruck city Barely squeaked into the A; a few of the guys in front of me should've been owned Even though frustration set in early....we had nothing but laughs where I was pittin'
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-01-2010, 11:48 AM   #1169
First race after IIC yesterday with my Copperheads I think the grip level at our track has been slowly changing as with my normal tire of choice the car was a bit loose. I noticed the same thing with my old car as well but I thought it was setup back then. Even with the car being a tad loose it was very drivable and I had the lead for quite awhile before I brain farted and fell back to 3rd. Quite happy with the car but am going to have to try working with different tire choices in the next race.
Old 11-01-2010, 03:52 PM   #1170
2wdrive's Avatar
yeah, i saw it flying. I was like ouch. It was a good race to watch though, seeing you fight back through the ranks.
Considering the opposition i had i was pleased with my final position in the WGT 17.5t 2s class last sunday. I had a lot of understeer with my DB10RR because of the wrong tire choice. I had pink back and purple fronts and had to apply 100% on the front and had to apply it twice on the front including almost 100% steering throw to let it turn at the speeds we were going haha. I didn't want to put other tires on cause i could not test it duing the race (at least i knew how it steered with this tire choice) But all in all quite a nice race. Next time some harder back tires will do the trick. The pinks were just too much glued to the track.
2wdrive is offline   Reply With Quote
