Old 10-11-2010, 11:14 AM   #1036
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
Originally Posted by protc3 View Post
I dont shim my WGT.
Are they done
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-11-2010, 11:39 AM   #1037
protc3's Avatar
This week they will be ready
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-11-2010, 12:05 PM   #1038
protc3's Avatar
Hey Guys,
I just finished making some optional standoffs for under the hinge pin block for high bite. Pretty much, it is 2mm taller than the stock ones. They are threaded standoffs. A set screw now will go into the pivot ball, the standoff threads onto the set screw and then you hold the hinge pin block on by threading the 2 4-40 screws into the standoffs. I figured it would be a nice option for those who want to shim high without stacking a bunch of shims. The new standoff kit will include the standoffs,2 4-40 x 5/16 set screws and 2 4-40 x 1/4 flathead screws. I will get them on the website today or tomorrow.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-11-2010, 06:27 PM   #1039
whynot's Avatar
Trader Rating: 18 (100%+)
Originally Posted by The Hawaiian View Post
aloha all, here's my CH12
NICE what body is that?
whynot is offline   Reply With Quote
Old 10-11-2010, 06:35 PM   #1040
avs
avs's Avatar
Hey Guys,
sounds good, i just cut screws to match up with 1, 2, and 3mm shims. but i found that with 2 or 3 mm there is a tendency for the pivot hinge to get clocked when tightening the screws, producing more caster on the right side compared to left. this new arrangement sounds better in that the spacer is threaded tight to the pivot ball, or am i the only one with caster mismatch?
to avoid the usual questions, i swapped upper arms and lower arms to identify the source of the caster variation, and i ended up tracing to the upper hinge fitting getting clocked when tightening it down.
Tony Shimko
avs is offline   Reply With Quote
Old 10-11-2010, 06:36 PM   #1041
I believe it is this one:
http://racepf.com/on-road-1-10-1-12/...ht-clear-body/
Old 10-11-2010, 07:09 PM   #1042
20 SMOKE's Avatar
can i swing by thursday
Jamie W
Old 10-11-2010, 08:28 PM   #1043
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
yeah InspGadgt got it on the nail...sorry I don't like purple
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 10-12-2010, 08:32 AM   #1044
protc3's Avatar
This pic isnt the greatest but you get the idea. This is the raised standoff kit.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-12-2010, 09:00 AM   #1045
Joost K.'s Avatar
Here's a picture of my CH12 equipped with a...
- Graupner DES 676BB servo
- GM Genius 75 esc
- Spektrum SR3500 receiver
- Graupner LiFe 200Mah RX-pack
- Intellect 5600 / 50C LiPo
- GM Pro Stock 13.5 motor
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 10-12-2010, 11:09 AM   #1046
protc3's Avatar
Nice bro. Very clean.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-12-2010, 11:26 AM   #1047
2wdrive's Avatar
- GM Genius 75 esc
Looks very neat joost. Where did you buy that nano pinion?
2wdrive is offline   Reply With Quote
Old 10-12-2010, 11:29 AM   #1048
Joost K.'s Avatar
Thanx guys!
Alexander, I bought it at www.nano-rc-racing.com
Old 10-12-2010, 11:35 AM   #1049
protc3's Avatar
About zero rotating mass. Its gotta be fast
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-12-2010, 11:40 AM   #1050
Joost K.'s Avatar
Lightning fast!!!
Went from laptimes of 10,9sec. to 5,8sec. with these pinions... They are incredible and run really smooth!!!
SEO by vBSEO 3.5.0
