Old 10-10-2010, 09:30 AM   #1021
Originally Posted by HarryLeach View Post
I may have missed it, but what kind of shims are you using? Will you be selling a shim kit as well?
Should be ordering my new front end next week.
If you (or someone you know) have the shims for adjusting front ride-height on a 12R5 they fit PERFECTLY between the standoff and the upper arm mount!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 10-10-2010, 11:08 AM   #1022
Joost K.'s Avatar
Well... Today I finally had the time to take a complete day at the track and really do some testing with the CH12. Last week I was going to but I crashed a servo saver and offcoarse, nobody had one spare...
All I can say is... WOW!!! This car really rocks!!! Almost straight out of the box built and it was dead-on, super steady and more steering than I have ever seen on a 12th scale... Today I could find a basic tire setup on our track so coming week I will go on with setting the CH12 up further. I also will try the shims under the pivots & upper arms to make the car even better...
Damn Jason!!! What a CAR!!!
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 10-10-2010, 07:41 PM   #1023
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Cheers,
Mike
I don't have anything for a 12R5, but thanks for the info anyway.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 10-10-2010, 08:47 PM   #1024
JayBee's Avatar
Trader Rating: 31 (100%+)
Just got back from the TimezoneII GP and wow!! Friday was practice but I got there a day early on Thursday for the club race. I needed the extra time with the car (gotta knock off almost 1-1/2yrs of rust, lol) . After some ESC frustration (had to breakdown and buy a TekinRS Pro) and tire testing, I was fastest with CRC Black frts @ 1.65" & CRC Grlw or BSR GrWht @ 1.68". The car was very efficient with tire wear. Without detailing everything out- with one practice run, 2 Quals (there was 3 quals total but tried BSR Team Purple frts for one of them), and 2 Mains, tire wear was approx .008" per. Awesome!!
There's more to post but I'm mentally spent and just wanna veg. Talk to you peeps later.
BTW, with this new front-end, get yourself (2) 'stepped' ride height gauges for setting your droop alot faster & more accurately. More on that later....its really simple though and close to what most of us do already.
Oh and of course I glued the sidewalls of the front and rear....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-10-2010, 09:12 PM   #1025
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
did you use the murf 13.5
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-10-2010, 09:30 PM   #1026
JayBee's Avatar
Yep...sure did When I left the game, the LRP TC Spec and Speed Passion 1.0 was my last speedos. My last big race was the 2008 IIC. So this was my first time running a speedo waith all this boost/dynamic timing crap But Kenny Lambert (Tekin rep) was there and ALWAYS available to dial me in. It was fast but I don't think it's optimized yet Anything you need to know?
Old 10-10-2010, 10:05 PM   #1027
JayBee's Avatar
Hey guys this is a vid of one of the WGT A Mains at the TZII GP.... this track is about 2-1/2 hrs away from me. GOTZ to get up here more often
http://www.youtube.com/watch?v=XRnISCoWRc8
Old 10-11-2010, 07:16 AM   #1028
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
Default pic'sof my CH12
thats cool
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 10-11-2010, 07:54 AM   #1029
Default Copperhead12 pic's
aloha all, here's my CH12
BMI Racing "Copperhead 12" discussion and support-ch12-1.jpg   BMI Racing "Copperhead 12" discussion and support-ch12-2.jpg   BMI Racing "Copperhead 12" discussion and support-ch12-3.jpg   BMI Racing "Copperhead 12" discussion and support-ch12-4.jpg
Old 10-11-2010, 08:28 AM   #1030
protc3's Avatar
Here is the setup i ran yesterday. Car was the best so far.
Front:
1.8mm flex plate in soft position
3mm shims under front hinge pin block
#6 shurlube in center tube
3.5mm ride height
.5mm droop
1.5 degrees camber
6 degrees caster
1.5mm shims per side behind front axles
0 toe
Rear:
Gold center spring w/ 40 wt. oil
shock in short position
1.2mm c/f flex plates in soft position(long mount)
#4 shurlube in tubes
3.5mm ride height
1mm pod droop
172mm rear track width
I ran gray white rears cut to 1.670 and 2x pink cut to 1.620. Glued sidewalls front and rear. Sauce for 10 minutes and wipe off tires 5 minutes before run. I sauced the full rear and 1/3 of the inside of the front.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-11-2010, 09:28 AM   #1031
protc3's Avatar
I must say, after watching everyone dread setting ride height and scrambling for shims, it is really cool to be the only car on the market that doesnt need to do that. A small tweak on the set screws and your ride height and droop is adjusted. Im loving it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-11-2010, 09:53 AM   #1032
20 SMOKE's Avatar
yeah,now it would be nice to do that with a wgt
Jamie W
Old 10-11-2010, 10:32 AM   #1033
Trader Rating: 36 (100%+)
Jason, do your 1.2 cf flex links come in pairs or individually?
Also, what is the part number for the four screws that hold the front end to the chassis plate?
EVILGRAFX is offline   Reply With Quote
Old 10-11-2010, 10:44 AM   #1034
protc3's Avatar
I dont shim my WGT.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-11-2010, 10:45 AM   #1035
protc3's Avatar
The 1.2mm flex plates are sold as a pair. DB6488 is the part # for the 8-32 x 1/4 stainless steel screws.
Jason Breiner
BMI Racing
Team Associated
J Concepts
SEO by vBSEO 3.5.0
