Old 10-08-2010, 05:06 AM   #1006
protc3's Avatar
nut shot
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-08-2010, 11:27 AM   #1007
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
Originally Posted by 20 SMOKE View Post
cause washed out surfers cant race
with friends like you Jamie...who needs enemies...
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 10-08-2010, 11:52 AM   #1008
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
there is that saying keep your friends close and your enemies closer
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-08-2010, 02:08 PM   #1009
-showtime-'s Avatar
Finally got a chance to run my copperhead with the new front end at the Gate last week. I ran the setup that Jason posted a few pages ago for high bite and the car was great all day. Wish I could say the same about my driving, but I guess not running since March will do that. I was on a TQ run untill I blew out late in one qual. (had to do a little durability testing on the front end, it passed with flying colors) and I ended up second in the main even with the lousy driving. It was really cool being able to play with the ride height and droop without fiddleing with shims as well as playing with all the other new adjustments. As Jason said earlier the tire wear is amazing. I ran tires that had a couple runs on them from last year, put 4 practice runs, 3 quals, and the main on them and they are still runable. Over all, love the new car with the front end and it's only going to get better as we get more time on it.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 10-09-2010, 05:47 PM   #1010
protc3's Avatar
Had a great day of running with the car today. I took TQ but finished 2nd in the main. My nerves got to me. The car was absolutely amazing. I went with 3mm of shims under the hinge pin block this time. I had to run more static camber but the car really rolls through the corner fast. I was very pleased. I will post my new setup shortly. It wasnt much different other than the hinge pin block shims and increased static camber.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-09-2010, 05:59 PM   #1011
HarryLeach's Avatar
Send a message via AIM to HarryLeach
I may have missed it, but what kind of shims are you using? Will you be selling a shim kit as well?
Should be ordering my new front end next week.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 10-09-2010, 06:01 PM   #1012
protc3's Avatar
I think what i may do is have a taller standoff for high bite and the standard for low to medium bite. Right now i am just using TC hinge pin shims that i have in my box.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-09-2010, 06:07 PM   #1013
HarryLeach's Avatar
Sounds good.
Just standard 3mm ID shims for the time being?
Will you have a tuning guide ready in about 2 weeks? [when I'm due to get back home and can start testing again ]
Old 10-09-2010, 06:11 PM   #1014
Trader Rating: 36 (100%+)
So you are using the two standard stand offs and then a 3mm shim on top of those and then the hinge pin brace to raise the upper arms? When you say hinge pin block, you're talking about the copper piece?
I just want to make sure that I'm understanding you correctly.
EVILGRAFX is offline   Reply With Quote
Old 10-09-2010, 07:00 PM   #1015
avs
avs's Avatar
i have been setting up a new front end and was trying to get the servo position right. you showed your servo near the top of the posts.
but for me to get the turnbuckles parallel to the lower arm (with 3mm ride height and 1.65" front tires) and zero bumpsteer it looks like i want to move the servo down to at least the second hole.
does this seem reasonable, or am i off somewhere else?
Tony Shimko
avs is offline   Reply With Quote
Old 10-10-2010, 12:45 AM   #1016
H I
H I's Avatar
Trader Rating: 18 (100%+)
I got good run today with new front end. I got TQ with winning all 3 heats and got 2nd in final, beaten by another CH12 with NFE. Front tire wear was amazing! Less than 1mm after 4 runs in mod.
avs, you might be using different servo or servo saver. I got Futaba 9650 and Kimbrough small Futaba servo saver (white), and have to use top hole on servo mount.
Also you may be using different hole position to mount ball stud on servo saver. Mine is in middle.
H I is offline   Reply With Quote
Old 10-10-2010, 04:55 AM   #1017
I have hope that someday I will see front end for my 12R5
I still have hope
Regards and good luck!
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-10-2010, 05:29 AM   #1018
protc3's Avatar
That is correct.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-10-2010, 05:55 AM   #1019
20 SMOKE's Avatar
J,i want to see what you have done with the esc
Jamie W
Old 10-10-2010, 08:01 AM   #1020
lorider75's Avatar
jason u got pm
Team High Torque * Extremercmods.com
lorider75 is offline   Reply With Quote
