Old 10-03-2010, 10:13 AM   #976
Edgar_P's Avatar
Hello,
waiting for my CH12 with the new FE to arrive
Question for all CH12 owners: Does the IP 5600mah 1s Lipo Race pack fit nicely into CH12 lipo slot?
BMI COPPERHEAD 12
Edgar_P is offline   Reply With Quote
Old 10-03-2010, 10:40 AM   #977
Joost K.'s Avatar
They'd better fit! I ordered two of them but my guessing is that they will fit neatly... If you wait a couple more days I will be able to tell you exactly how they fit the CH12...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 10-03-2010, 11:15 AM   #978
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guy's
No worries they'll fit
Originally Posted by Edgar_P View Post
Hello,
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-03-2010, 11:17 AM   #979
mike ivy's Avatar
Oh snapola Im in big trouble now!!!
Originally Posted by xtrememadness View Post
hey jason would you be making a 12rr tocopperhead conversion with new front end included. or would it be cheaper to buy the entire car? thanx buddy the car looks real good! ivy im comin for ya!
Old 10-03-2010, 12:19 PM   #980
avs
avs's Avatar
with the new front end there is a number of screws thread into the graphite/epoxy parts.
are you tapping the threads on any of these or just threading straight into the bare material?
particularly i was thinking the 8-32 screws for the subplates to chassis connection might be a candidate for precut threads?
Tony Shimko
avs is offline   Reply With Quote
Old 10-03-2010, 12:31 PM   #981
Joost K.'s Avatar
I didn't thread them before I put the screws in... It is however a point of care not to take out the screws too many times I guess... Only if you really have to. Otherwise just let is stay on the chassis... There are not many parts that need dismounting a lot so you'd be safe with that...
Old 10-03-2010, 01:15 PM   #982
I would suggest taping the 8-32 holes. I split one of the mounting plates when I tried it without taping. Taped all the rest of the 8-32 holes and haven't had a problem. Jason pre-assembled the rest so I don't know about the smaller screws.
Old 10-03-2010, 05:38 PM   #983
protc3's Avatar
Very cool today guys. Bite was down as not as many people came out as they did last weekend. I ran the same setup and the car worked great. Had a slight push as the bite was down and i didnt feel like making any changes. I still managed to take TQ by a lap in both WGT and 1/12th. Had no luck in the main as in 1/12th, my sensor wire took a dump and ended my race and in WGT a screw came out as i was leading the race. Guess i got a little too careless. This is what happens when you dont have to spend all that time tweaking and messing around. You forget to check anything Cars were both amazing and super easy to drive. I love this new front end. I ran 1 set of tires each for both WGT and 1/12th. I ran 2 packs for practice,3 heats and a main and didnt even have to rotate them. The car is just so efficient.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-03-2010, 05:45 PM   #984
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
how close are you on completed fr ends,i have 2 bills burning a hole in my pocket and you need them
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-03-2010, 05:46 PM   #985
protc3's Avatar
I will have more 1/12th front ends in stock by wednesday and 1/10th probably friday.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-03-2010, 08:37 PM   #986
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Scooby Horton1 View Post
Yo J,I just tried that new frontend for the first time tonight! Man the car was dialed! I just need to get my carpet legs back! I need the one for the wgt car because there calling me out now! Lol! It is tough also I got in mad crashes and the thing was like whatever!
mad crashes == blow out while on TQ run stuffing your car under the drivers stand -- it was IMPRESSIVE!!
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-04-2010, 04:50 AM   #987
avs
avs's Avatar
thanks guys, couldn't decide so i tried a couple each way.
Tony Shimko
Old 10-04-2010, 06:35 AM   #988
avs
avs's Avatar
Originally Posted by protc3 View Post
Here is the new setup that worked best for me in high bite.
Front: ...
.25mm droop
Rear:
1mm pod droop
1.2mm c/f flex plates mounted long position(soft):
hi Jason, could you clear up a couple of questions?
your recent setups refer to a 1.2 GR/EP rear flex plate, but the website shows the FRG and 1.5mm GR/EP. is thre a third set of plates or is there a typo?
also, regarding droop, i wanted to confirm that you are measuring this by the amount the chassis rises from static?
(as opposed to the difference in pod height front to back at max extension)
thanks for the help, tony
Tony Shimko
Old 10-04-2010, 07:05 AM   #989
protc3's Avatar
I am running 1.2mm carbon fiber flex plates. We have 1.5 fiberglass, 1.5mm carbon fiber and 1.2mm carbon fiber for the rear. I will check the website out and see what is listed
I check the droop front and rear by how much the chassis rises over ride height.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-05-2010, 11:50 AM   #990
protc3's Avatar
Hey guys,
I just got my C/F panels in and i am going to start cutting more components now.Sorry for the delay. The remaining orders will go out this week. Thank you for all of your support.
Jason Breiner
BMI Racing
Team Associated
J Concepts
SEO by vBSEO 3.5.0
