Old 09-07-2010, 10:04 PM   #706
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by whynot View Post
A PITA to handle huh whats that? like a pita sandwich with everything fallen out haha Do you shorten wires when you install electronics. the wires are such a pain in the butt. Do you guys makes sure the car is balanced from side to side perfect?
thanks
PITA= pain in the ass, lol.
And yes my ride is balanced as close as it can be left/right. I'll post pics soon of my car on pegs and you shall see. I must admit my car is 20grams overweight. I attribute that to the SXX (although small in its own right) and the NON-lightweight Speed8 HD, lol...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-08-2010, 02:20 PM   #707
protc3's Avatar
You do want to make sure the car is balanced very good left to right. THis goes for any 1/12th car. Balance is very important.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-08-2010, 02:37 PM   #708
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
blah blah blah, never balanced mine
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-08-2010, 02:42 PM   #709
protc3's Avatar
Thats why your not an omni turner
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-08-2010, 04:02 PM   #710
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
thats why u didnt turn consistent 8's or any for that matter
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 09-08-2010, 05:51 PM   #711
Hey guys, been through this entire thread reading about the new CH12 and I'm looking to pick one up with the revised front end. Sounds like Jason has done his homework and it's quite the setup.
Being about 20yrs removed from 1/12, curious how is the setup/tuning in regards the to CH12? Fairly easy to get setup and running? I saw Jasons setup and looks pretty straight forward.
I've been running 1/8th truggy for about the last 10 years (leccy now) but that 1/12 bug has always been there and I've wanted to get back into it for years. Seems now is as good a time as any.
What's the hot setup now a days? Seems 13.5T seems pretty std. I see lots of LRP power plants in use.
Thanks,
E.
itbvolks is offline   Reply With Quote
Old 09-08-2010, 09:42 PM   #712
skypilot's Avatar
Trader Rating: 14 (100%+)
jaybees balancing act
BMI Racing "Copperhead 12" discussion and support-jaybee-balance.jpg   BMI Racing "Copperhead 12" discussion and support-jaybee-balance-2.jpg   BMI Racing "Copperhead 12" discussion and support-jaybee-balance-3.jpg
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-09-2010, 04:01 AM   #713
20 SMOKE's Avatar
try balancing it with out the pod,thats what i was told
Jamie W
Old 09-09-2010, 02:58 PM   #714
chris moore's Avatar
Trader Rating: 85 (99%+)
Thanks,
E.
It seems that every club does its own thing for motors, someplaces(like here) we run 13.5. Other tracks follow ROAR rules and run 17.5 for their stock class. Same with esc's, I like the Tekin but the BD and LRP are great too. The besst thing to do is hit the local track and see what rules are in place for the class there.
I've tried both ways and did not see any difference in how my cars have balanced in the past
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 09-09-2010, 04:33 PM   #715
Regional Moderator
CarbonJoe's Avatar
Originally Posted by avs View Post
the parma/jaco front wheels are sloppy on the bearings
A quick fix for this is to take some blue painter's tape (or even plain masking tape), put a 1 inch square over the outside bearing hole. Then, take an Xacto knife and slice an X in the tape where the bearing goes. Press the bearing in, and then trim the excess tape around the bearing. The outside bearing hole is the one causing the slop, and this method removes that slop.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-09-2010, 06:45 PM   #716
whynot's Avatar
Trader Rating: 18 (100%+)
Hey guys I have my ride height set and trying to set front droop now. how do you go about doing this? when I start to turn in the droop screw to set droop I am getting the droop screw touching the lower arm bracket and the ride height screw both touching down at the same time Is this bad? I cant seem to find an accurate method to measure this thanks
mike
whynot is offline   Reply With Quote
Old 09-09-2010, 06:51 PM   #717
JayBee's Avatar
Last night went reasonably well with the DB12RR w/d-strut frt. end. Super steering batman!! Didn't really have a lot of time to test and tune but found out a few things that will definitely help out with my next raceday.
The new SXX v.2 performed flawlessly with no hiccups. We run 13.5 w/no boost out here, so really the only thing to fiddle around with is the "feel" (punch). I ran the whole night w/profile #4 but felt the "feel" was a bit too flat off neutral. Moved it to profile #6 for next time...
Anyone out there run a LRP X12 13.5? Have you played with the endbell timing; what was the effect?
I think Jason nailed it with this new front end. No more springs, kingpins, kingpin lubing, and spacers.
* 2 thicknesses of front flexplates w/set screws for ride height & frt end flex.
* 1 setscrew in each lower arm for droop.
* front damper tube
......set it and forget it and everything is slop free.
Btw J....can't wait to try out those BSR's
Old 09-09-2010, 07:22 PM   #718
protc3's Avatar
mike
Your droop screws may just touch the chassis when the car is in your hands, you want to have it sitting on the table and have the car at ride height. From the weight of the car loading the wheels, you may compress the springs a little while at ride height. You want about .5-.75 uptravel over ride height for droop. What you want to do is back the droop screws out. Then set ride height with the set screws in the flex plates. Once this is done, turn the droop screws in just about until they touch the sub plates. At this point you want to start measuring your up travel. I do this by slowly lifting the car with an exacto blad until both front wheels leave the ground at the same time. You want them both to leave the ground about .5-.75mm over your ride height measurement.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-09-2010, 08:51 PM   #719
avs
avs's Avatar
that is a good suggestion.
i tried using a plastic bag, which was not a good idea, it shifted around too much. the weak adhesive of the blue tape would probably be just right.
thanks!
Tony Shimko
avs is online now   Reply With Quote
Old 09-10-2010, 10:31 AM   #720
Joost K.'s Avatar
Mine is being shipped today!!! In 3 - 5 days it will be mine!!!
Jason, THANX!!!
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
