Old 09-02-2010, 11:56 PM   #631
LonnyJ1950's Avatar
Sorry, I could not find a listing for a CH12 kit complete with new front end either. The CH12 is there with the regular front end, and the new front end is there as a separate item, but no complete kit. Of course I could have missed it.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 09-03-2010, 04:56 AM   #632
protc3's Avatar
I will get it up on there today. Sorry guys.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-03-2010, 06:02 AM   #633
pmes's Avatar
Any chance there's a CH12 headed to ND?
On a car with the new front end what's a good wt diff fluid to start out with in the various damper tubes? My Shur Lube is on back order and if the car should arrive first I may need to use diff lube for the time being.
pmes is offline   Reply With Quote
Old 09-03-2010, 06:18 AM   #634
protc3's Avatar
I would try 30k in the front tube and 15k in the rear tubes. I will need to check on the car to ND. I know that i should have all kits shipped out today that were ordered. Finally seeing the bottom of the pile of orders. This is a good problem to have.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-03-2010, 06:34 AM   #635
protc3's Avatar
ok, putting the car w/ front end on the site now. Thanks for pointing that out guys.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-03-2010, 09:34 AM   #636
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by protc3 View Post
Here is my setup.
Front:
3.5mm ride height
2x pink front cut to 1.650 w/ glued side walls
1 degree camber
6 degrees caster(2 shims to rear of arms)
#5 shur lube in front damper tube
.75mm droop
angled servo w/ no bumpsteer
stock roll center
stock flex plates w/ set screw in short position(stiff)
Rear:
Gold center shock spring w/ 50 wt. oil (may try blue)
#3 shur lube in tubes
3.5mm ride height
1mm pod droop
Gray/white(same as jaco orange) cut to 1.700 and glued side walls
1.2mm carbon fiber flex plates(stock will be fine) mounted long
Pod level
172mm track width
Setting my car up now....got to give this a shot
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-03-2010, 10:11 AM   #637
Hey, need a bit of setup help...
We only run asphalt here with 1/12th... So for sightly bumpy track what ride height? and for very bumpy (VERY BUMPY) what set-up changes should I make... Both tracks are flowing tracks with 1 1/2 high speed straights.
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
Old 09-03-2010, 10:26 AM   #638
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i am between 5-6
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-03-2010, 10:37 AM   #639
protc3's Avatar
I would go with 5-6 mm as jamie said and go with lighter oil spring combo such as a silver spring w/ 40 wt. oil in the shock. The .020 linear springs w/ 10k on the kingpins and you may need to run a little more camber to keep the tires wearing good with the high speed track.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-03-2010, 11:04 AM   #640
Thanks Jason and Jamie... Practice this Sunday at next National track here in South Africa... 1/10th Modified all ready so not much practice... but BMI needs some work, gotta get that gearing and set-up right
TOP
SOUTH AFRICA :)
Old 09-03-2010, 02:26 PM   #641
whynot's Avatar
Trader Rating: 18 (100%+)
Jason are there going to be any copperhead 12's at the IIc with the standard or new front ends that you know of?
whynot is offline   Reply With Quote
Old 09-03-2010, 02:28 PM   #642
20 SMOKE's Avatar
I think InspGadgt is
Jamie W
Old 09-03-2010, 03:06 PM   #643
I'm no sponsored driver but I'll be there with the Copperhead 12 with the new front suspension and the Copperhead 10 with the normal front suspension.
Old 09-03-2010, 04:45 PM   #644
whynot's Avatar
Awesome good luck and most of all have fun, I will be on liverc checking to see how your doing, keep us posted on here as to when you will be racing and how everything is going. What is you name so I will know am sure it wont say inspgadgt haha well I register under whynot so I guess its possible haha
mike
Old 09-04-2010, 10:04 AM   #645
JayBee's Avatar
Just completed the build of the 'new' CH12 front end on my RR. Its not as simple OR as frustrating as the AE strut front end, but once I got going I couldn't stop. This thing is a dream to build! Like I already told ya J, I don't know how you came up with the idea, but its awesome brah. I love the 'precise-ness' of everything....the carbon fiber and delrin pieces, the 4set screws for droop/ride height, the absence of kingpins & springs, no 'hand-fitting' whatsoever plus the elimination of SLOP.
Still gotta get myself a newly revised CH12 though....
GREAT JOB BRO & keep up the good work!!!
BTW, what we talked about on the phone....got an idea
