Old 08-30-2010, 09:30 AM   #586
JayBee's Avatar
Trader Rating: 31 (100%+)
Thumbs up
Thanks Jason....can't wait to strap that front-end on
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-30-2010, 12:42 PM   #587
protc3's Avatar
Front end is now available for purchase on the website.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-30-2010, 12:45 PM   #588
Joost K.'s Avatar
Yeah! I saw it and I also read that you have already made some kits ready for shipping?
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 08-30-2010, 01:20 PM   #589
JayBee's Avatar
BMI DB12RR w/lipo conversion......CHECK!
BMI Copperhead 12 (new) front-end......CHECK!!
LRP SXX Competition V.2 esc......CHECK!!!
Cheez'n like a 9yr old after just getting a Red Ryder rifle BB gun......PRICELESS!!!!
Old 08-30-2010, 01:26 PM   #590
Joost K.'s Avatar
LOL...
Old 08-30-2010, 01:29 PM   #591
This may be a noob question, but.... how does the new front end suspension work? What replaces the little springs we used to run...
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
Old 08-30-2010, 01:33 PM   #592
wingracer's Avatar
Trader Rating: 22 (100%+)
Graphite flex plates.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-30-2010, 01:34 PM   #593
Joost K.'s Avatar
The front end now uses two carbon fiber flex-plates as a spring. They can be mounted in 1.5 and 1.8mm thickness. This will act as the "spring" in the front end. They also have two set screws in these plates which along with two set screws in the lower arms will be used to set the ride height and spring tension...
Hope I got this right...
Old 08-30-2010, 01:34 PM   #594
JayBee's Avatar
@ Joost K.- EXACTLY brah
Old 08-30-2010, 01:36 PM   #595
Joost K.'s Avatar
Old 08-30-2010, 03:27 PM   #596
Thanks all... sounds like interesting concept... definitely original
TOP
SOUTH AFRICA :)
Old 08-30-2010, 03:31 PM   #597
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
and a damper tube(small one)
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-30-2010, 03:41 PM   #598
Joost K.'s Avatar
Oopsie, totally forgot the dampertube... Yes, and a dampertube also...
Old 08-30-2010, 07:41 PM   #599
whynot's Avatar
Trader Rating: 18 (100%+)
Hey jason do you know what day I should be getting them kits.
whynot is offline   Reply With Quote
Old 08-31-2010, 12:40 PM   #600
protc3's Avatar
You have a PM bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
SEO by vBSEO 3.5.0
