Old 08-18-2010, 07:16 AM   #511
whynot's Avatar
Trader Rating: 18 (100%+)
Hey Jason just wondering if the ch12 will be coming with the spring,shock oil and damper tube oil that you think will be used with med to high bite carpet, if not could you post what you think we should have ready for the build so we are as close to the right setup, and you mentioned you use thin servo tape under your lipo pack along with tape and just leave the batt in. would the parma servo tape be thin enough for this. thanks
mike
whynot is offline   Reply With Quote
Old 08-18-2010, 08:26 AM   #512
protc3's Avatar
Hey Mike,
I do not supply the lubes with the kit. It is good to have the 6 sure lubes. They are sold at IRS. I use #4 in the front tube and #2 in the sides. 45 wt. AE shock oil works well with the red spring for carpet.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-18-2010, 09:44 AM   #513
pmes's Avatar
Do you mean shur lube from <http://www.windtunnelracingproducts.com/>?
Are there shock springs in the kit?
pmes is offline   Reply With Quote
Old 08-18-2010, 09:55 AM   #514
protc3's Avatar
ahhh,yes, shur lube. The kit comes with a gold center spring which works very well in most conditions. The new front end comes with 1.5mm flex plates and 1.8mm is optional. 1.8mm comes with the front end for the 1/10th front end.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-18-2010, 10:16 AM   #515
Joost K.'s Avatar
Okay, that is nice to know then... Jason, did I get it right? Does the new front end also have a damper tube supplied?
It's getting closer and closer now... Yummieeeeeee
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 08-18-2010, 10:18 AM   #516
protc3's Avatar
Yes, the new front end does come with a damper tube.
Had to edit. Someone was talking to me while i was typing.lol I made no sense. lol
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-18-2010, 10:36 AM   #517
Joost K.'s Avatar
Haha... And still I understood what you were saying
Very nice... I will look around here for some of these lubes then. I don't have them in my pitbox. Is that ShurLube the lube I should get or will any tube lube do the job?
Old 08-18-2010, 12:04 PM   #518
protc3's Avatar
Any tube lube is fine. It is just that all of my set ups will show that being that i use it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-18-2010, 12:42 PM   #519
whynot's Avatar
thank you very much jason need to order this stuff asap
Old 08-18-2010, 02:13 PM   #520
Perhaps you can use your influence to get them to change the bottles they use They keep leaking on me
Old 08-18-2010, 05:00 PM   #521
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey InspGadgt,
Try this, Just poke a hole on top of the tip i've never had any of mine leak that way.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 08-18-2010, 09:53 PM   #522
Yeah I did only use a small hole in the tip. But with travel the bottle are often laying on their side instead of up and down...combine that with the Hawaii heat in the back of my car and yeah...they still leaked. Right now I'm debating if it is going to be worth the time to try and clean them up or just buy a new set.
Old 08-19-2010, 05:21 AM   #523
protc3's Avatar
I will be working on the instructions for the front end starting tonight. Getting very close now.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-19-2010, 05:34 AM   #524
Joost K.'s Avatar
Sounds like music to my ears Jason... Almost there buddy! This will be a big day in RC racing when its done...
Old 08-19-2010, 05:40 AM   #525
protc3's Avatar
Thanks buddy. I am really excited about this release.
Jason Breiner
BMI Racing
Team Associated
J Concepts
