Old 07-19-2010, 01:06 PM   #331
protc3's Avatar
Originally Posted by sportpak View Post
How easy does the new front end setup? Meaning is getting it even side to side a reasonable feat? A little out of wack goes a long way in a 12th scale. Looks very good though. Interested in total cost whenever that's determined.
It is very easy to set up. There is no more reactive caster as it is not a strut front end anymore. The static caster adjusts the same way with just shims on the upper hinge pin. Camber adjustment is the same. You can adjust roll center by simply shimming the cross plate or shimming the outer ball. Ride height is adjusted by just tightening or loosening the screws in the front flex plates. You then remove the excess droop with the droop screws once your ride height is set. Everything pretty much falls into place. It is very smooth, adjustable, and very user friendly. You will be very pleased.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-19-2010, 01:07 PM   #332
protc3's Avatar
Also, if your ride height is off just a little on one side, you adjust it with the set screw in the flex plate. Very simple.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-19-2010, 01:09 PM   #333
protc3's Avatar
I will be making the final changes and taking good clear pics for the press release. I will post them here also.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-19-2010, 01:34 PM   #334
wingracer's Avatar
Trader Rating: 23 (100%+)
I'm sure you know this already but you don't have to have a strut front end to have reactive caster. Angling the arms works just the same way with dual arms. In fact, my 1/8th scale onroad car has a bit of reactive caster in it right now
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-19-2010, 02:08 PM   #335
protc3's Avatar
I didnt want reactive caster in it. Caster angles needed in 4wd vs 2wd cars with double wishsbone style front suspension is completely different. 2wd cars need more. Reducing caster when compressing the suspension(ie sweepers) would not help in the slightest without any roll center change. All it would do is create push.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-19-2010, 02:12 PM   #336
Joost K.'s Avatar
So Jason, basicly what you're saying with a strut front end you should use the 0 deg. caster blocks?
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 07-19-2010, 02:16 PM   #337
protc3's Avatar
I used 0's or 5's. I never bothered with 10's. Too much caster reduction.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-19-2010, 02:17 PM   #338
wingracer's Avatar
Same here. I wasn't saying it needed reactive caster, just that it could be done,
Team Shepherd USA
Old 07-19-2010, 02:18 PM   #339
protc3's Avatar
haha, yeah, i know.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-19-2010, 02:29 PM   #340
Looks like you could also adjust dive/anti-dive by putting shims under the pivots
Old 07-19-2010, 02:32 PM   #341
protc3's Avatar
That is correct I havent tried it yet though. I had a few hours on saturday so far. We have a real nice carpet track opening here in florida so i should be able to complete testing within the next 2 weeks.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-19-2010, 02:36 PM   #342
I'm jealous!
Old 07-19-2010, 03:20 PM   #343
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
sunday,sunday,sunday.you gonna race
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-19-2010, 03:34 PM   #344
wingracer's Avatar
Just out of curiosity, how thick are those lower arms? They look really beefy, which I like.
Team Shepherd USA
Old 07-19-2010, 03:45 PM   #345
chris moore's Avatar
Trader Rating: 87 (99%+)
The new front end looks really nice Jason, kudos.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
