Old 07-12-2010, 08:50 PM   #286
DB1020R is a longer lower pod plate designed for the DB12RR. When put on the DB12R it would lengthen the wheelbase but the DB12RR has a shorter chassis plate so the overall wheelbase stays the same.
Old 07-12-2010, 09:00 PM   #287
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by mike ivy View Post
Hey Jaybee,
I'll Try to answer these as best as i can
Part# DB1030R The difference between this part and the original is that it sets the shock back on the top pod it changes the leverage of the shock. I helps make the car rotate better.
Whats a nice feature on the DB12RR and the new Copper Head12 car is you can position the shock mount forward or back. It changes leverage on the pod and how much traction or less traction you want. So if you want more traction move the mount forward and if you want less traction move it to the rear.
Part# DB1020R This is different than the original this lengthens the car some it basically keeps the car more stable and I think a longer wheel base helps the car carry more corner speed I have to ask Jason on this.
Part# DB1041R this part is for the DB12RR car its pretty much like the original but its made for the DB12RR
Part#DB1053R Is the pod brace for the DB12RR car on this car the pod is a little wider to allow more room for brushless motors.
As for 1c lipo's there's many alot of people are using Thunder Power, Trinity just to name a few.
Hope this helps
Mike
Are the top & lower rear pod plates wider as well, to accommodate for the RED highlighted portion above?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-12-2010, 09:17 PM   #288
Yes
Old 07-13-2010, 12:55 AM   #289
speed-e's Avatar
Trader Rating: 28 (100%+)
Originally Posted by speed-e View Post
So, there will be an option to buy the Copperhead with the new suspension, but the cost will be higher than the Copperhead with the old Associated style front end, correct?
I do not mind paying more for the car . But I have a problem with having to buy two front ends with my kit, when I know I'm not going to use the Associated style front end. I'm confident many others agree with me .
Originally Posted by 20 SMOKE View Post
its because he want a car that is reasonable priced,the front end is just a option part that does not need to be purchased if not needed,but most die hard will buy it,the average beginner may not for a while
Yes that is clear . So I'm a die hard and not the average beginner, why do I have to buy the old front end when I'm willing to pay a little more for a kit with the new front end?
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 07-13-2010, 08:38 AM   #290
protc3's Avatar
I will have 2 options for the car, with the strut front end or our front end. The one with our front end will be more expensive as it cost more to produce. The option is there though. No worries.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-13-2010, 10:21 AM   #291
pmes's Avatar
Originally Posted by protc3 View Post
We do have all of the parts for the new car. I will see why they ae not on the site.
[SNIP]
We do have different plates for the car. THe standard ones are 1.5mm fiberglass, then we have 1.5mm c/f and 1.2mm c/f
Under what conditions would one change the flex plates?
pmes is offline   Reply With Quote
Old 07-13-2010, 10:28 AM   #292
protc3's Avatar
If you want more steering for a real tight track, the carbon fiber ones are a little stiffer and give you the steering if you need it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-13-2010, 05:59 PM   #293
JayBee's Avatar
Hey J
Can you PM me the total ($) for that order today? And btw, thanks for changing that for me
Old 07-14-2010, 02:14 PM   #294
speed-e's Avatar
Sounds like a good plan Jason. I'll be waiting for the kit's release!
Mugen Seiki
MIP
V-Speed Engines
RadioPost
Old 07-14-2010, 02:19 PM   #295
whynot's Avatar
Trader Rating: 18 (100%+)
Jason do you have an idea when the kits will be offered with the new front end, My son and I will be running this car for the carpet season. I think we will be starting next month sometime at the gate cant wait
whynot is offline   Reply With Quote
Old 07-14-2010, 03:36 PM   #296
protc3's Avatar
I would like to start production at the end of this month which would mean a probable release towards the end of august. If i can do better i will
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-14-2010, 03:54 PM   #297
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
how much rebound are most using
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-14-2010, 04:56 PM   #298
Cool...so that means we should see pics of the new front end any day now
Old 07-14-2010, 07:13 PM   #299
-showtime-'s Avatar
If you need any help with your cars when you get them let me know. I usually try to make it out to the gate once a month or so, we'll get you dialed in out there.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 07-14-2010, 07:50 PM   #300
avs
avs's Avatar
hey Eric, does this mean i will be seeing you at TQ soon? there are several fast guys that will give you a good race (not me)
Tony Shimko
avs is offline   Reply With Quote
SEO by vBSEO 3.5.0
