Old 01-27-2012, 09:58 AM   #2416
Originally Posted by protc3 View Post
I will have a flex plate kit with all you listed. The chassis is cut for 3mm screws for the front end. I may just put the complete AE front end in there. Still not sure. The new pod will be an option part which is one of the reasons why it is not on the car. Another reason is that i haven't cut one out yet.
Cool...Just gotta do something about that blue
Old 01-27-2012, 10:14 AM   #2417
protc3's Avatar
Yeah, Im throwing around some ideas. AE sells a complete front end kit but the parts are blue. To strip and re anodize may not be cost effective so i need to figure out a solution.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-27-2012, 10:57 AM   #2418
EricF's Avatar
Jason-
Do the springs touch the chassis (like the SM car) or the links? I'm on my phone and I can't see the photo that well.
Now it looks like I will need 1 conversion and 1 kit.
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 01-27-2012, 11:25 AM   #2419
protc3's Avatar
The springs touch the lower pod plate. I didnt want to put them on the links as it seemed it would tweak easier being that the links pivot back and forth.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-27-2012, 11:34 AM   #2420
Their side shock they sell in black as that is what is on the Exotech F1R...I wonder if they would be willing to do the front end piece in black?
What about the machined once you were messing with that reversed the screws to the outside?
Old 01-27-2012, 11:36 AM   #2421
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jason,
Just pop'in car lookes great!!!! good luck with that
This is where i am so far with the build of the prototype. You can run the battery inline to the left or right and also true inline. You can also run it forward with the electronics in the rear or the conventional rear position. And to top it all off, no tape is needed unless you run the battery in the conventional rearward position. You can also run either flex plates or links and springs. Here i have it with links and springs.
There will be a couple more slight improvements but this is basically what we are releasing.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 01-27-2012, 12:00 PM   #2422
protc3's Avatar
I may just machine the aluminum stuff. I will see if AE offers black first though
Thanks mike
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-27-2012, 07:25 PM   #2423
EricF's Avatar
Cool, that always more since to me, but it took a while before the manuf's that use tweak springs to do it.
What's you estimated time frame for the ch12.1 or 2
E
Old 01-28-2012, 04:42 AM   #2424
protc3's Avatar
I am waiting for the go ahead after Snowbirds to start production. I will let you know when the estimated release will be as i get close.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-28-2012, 07:27 AM   #2425
Just a thought... but you could drill the chassis plate for the L4 front end and then use the off-the-shelf Hyperdrive front bulkhead and mounting slugs.
They make them in silver, black, etc.
JamesL_71 is offline   Reply With Quote
Old 01-28-2012, 08:31 AM   #2426
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Better yet, just make the chassis with 8-32 mount holes, and offer the kit without a front end.
There are a lot of options if you go that route, not to mention a lower initial purchase price.
The SM machined old school front end comes to mind, as well as L4, CRC, and Hyper/AE
For a few extra $$ one could even have copper Hyper/AE bits.....
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-28-2012, 11:51 AM   #2427
Hi Jason, my thoughts.. could you offer as a option the chassis drilled for either a 3mm or a 8-32 front end? This would allow us to choose which style to use. I am excited about the new design, but would not like to have to switch to the new 3mm Assoc. front. As I have several BMI cars with the 8-32 holes and don't want to have to start over again with a new set of spare front end parts.
skidmoremt is offline   Reply With Quote
Old 01-28-2012, 12:10 PM   #2428
From what I recall the Hyperdrive aluminum mounts had some issues with ride height. At one time I wanted to go with the R5 front end because of the aluminum mounts but didn't because of the ride height issue. Running on asphalt we tend to run a bit higher ride heights. Our track is banked and bumpy so we need to be able to maintain a 4.5mm ride height almost down to the rim.
Old 01-28-2012, 02:05 PM   #2429
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
Well I'm pretty sure if Jason was to make the mounts he would take in account for ride hight . But it sounds like the best option to make everyone happy is to make the chassis with holes drilled for 8-32 threads and have Jason machine up the arm mount for the r5 front end. But personally I feel the r5 front end is the best option out of all the strut front ends
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 01-28-2012, 04:11 PM   #2430
I really like the NFE but I gotta get mine fixed before I can use it again. But for a strut type front end I'd like to see something along the lines of the SM Formula front end...a 1 piece CF lower arm but with an upper arm like the AE front end. That way you don't have to deal with the left and right heights being different due to molding errors in plastic. The lower pivot can be like the ones used in the NFE but have the kingpin slide through rather than being threaded.
