Old 12-26-2011, 12:43 PM   #2341
markiemark's Avatar
Trader Rating: 23 (100%+)
Thanks so much ill try them adjustments. I know few fast guys tryed running yellows but they all said they where loosing to much grip around the 5min mark. And some went back to pinks and some to whites.
it is the white paragon cans and track is crc carpet.
~ ~Blue Diamond Park Raceway~~
~~~~D Main Champ~~~~
markiemark is offline   Reply With Quote
Old 12-26-2011, 01:12 PM   #2342
LonnyJ1950's Avatar
Here's another thought,with the FX2 use less. It is a very oily compound and can build up on the tires. This may be causing your traction loss at the 5 minute mark. Try using just a ring of 1 dauber's width around the center of the rear tire and spread it out with your fingers. Too much additive can pick up more dirt as well.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-26-2011, 02:25 PM   #2343
markiemark's Avatar
ok il try that. i have been saucing them heavy letting sit for 20mins then rubbing them off. Then after ever round cleaning them with motor spray on a paper towl let dry then reapply. Pink seem to grip well just the yellow oranges seem to fade off.
Old 12-26-2011, 02:47 PM   #2344
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
At my track when yellows stopped working we would go to magentas front and rear . Then things were good. Other than that we always run blk fronts and yellow rears. But we also use sxt 3.0.
jeff jenkins is offline   Reply With Quote
Old 12-26-2011, 02:57 PM   #2345
markiemark's Avatar
i tryed black fronts and orange rears at our track and it had a awful bad pash and came off track with glazing on all four tires
I think chris is right the car dosnt want to rotate it wants to push around the turn instead of rotating.
Old 12-26-2011, 04:08 PM   #2346
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
To be honest, I'm a bit surprised at the choice of tire sauce.
FXII is generally used as more of a sticky outdoor application.
Most indoor tracks use Paragon GE, SXT or JTG.
I'm not surprised your tires are glazing.
That said, if others at your track are not having the same issues, there is obviously method to the madness
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-26-2011, 05:15 PM   #2347
markiemark's Avatar
Alot of people are havin grip issues. The top 2 guys at the track one guy racing longer then i living and well sponsored and the other almost lives at the track are only to not havin to much trouble. But the chqnge and clean tires every run. They also running white rears which im going order to have and try once i get the car to rotate and carry more corner speed. My car is as fast as theres on straight but the infield there gone and the way there cars rotate around the turns is smooth and fast
Old 12-26-2011, 05:43 PM   #2348
Straight line speed doesn't count for much in club racing, I gear for rip, top speed don't matter.
If they are changing tires every run, so should you.
Bring 3 sets, one for each heat, and one for the main.
Rotate those out, and use em next week.
At the big races when the grip is insane, that's the go.
The tires get too sticky, and it takes time for them to dry out.
Foam tires are sponge like
90% of the setup is tire choice & prep.
Old 12-26-2011, 06:05 PM   #2349
LonnyJ1950's Avatar
I remember racing places where you had to have a set of tires for every run, because after 1 run they were totally gone, worn out.
Lonny
Old 12-26-2011, 09:12 PM   #2350
markiemark's Avatar
Looked at car tonite i got my front width to 167 cant go to 168 cause i dont have low profile wheel nuts . Going try that change first . and reset my front ends toe and camber.
Also going order some more magenta fronts and a pair of white rears to play around with. Also just to add to the info iv been running my tires 42mm front 43mm Rear
Old 12-27-2011, 03:59 AM   #2351
Uga
Uga's Avatar
Just a quick tip - you can flip the wheelnuts the other way around with the nylon ring facing the wheel
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 12-31-2011, 09:22 AM   #2352
protc3's Avatar
Hey guys,
First off, I hope you all have a happy and safe new year.
I want to let you all know that our computer system has been down for about a week and a half at the shop. I got it back up and running but still have a few bugs to work out. All of the orders that have been placed have shipped out but notifications of shipment to your email have not been sent due to these issues. Sorry for the inconvenience. Things should be running back to normal shortly.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-02-2012, 07:26 PM   #2353
MCSEDanny's Avatar
Jason whats the status on the new rear pod? I am using the IRS ride height adjusters and tired of breaking them. Guess I am going back to the associated ones that seem to hold up better but would rather put the money into the new pod.
Team Turtle Trax / Loganville RC Raceway
Mugen MBX6TR / Bonito
Kyosho MP9 TKI3 / Plus 4
Kyosho MP9 TKI3 / Electric / WTF
AE B44.3 / ORCA VXX / D4 7.5
MCSEDanny is offline   Reply With Quote
Old 01-03-2012, 03:06 AM   #2354
protc3's Avatar
I am looking to release the new pod along with other cool new stuff by Snowbirds.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-03-2012, 04:57 AM   #2355
Big Features's Avatar
Jason,
You've got PM
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
