Old 11-29-2011, 09:29 PM   #2281
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
I've been thinking about getting one of thes cars for sometime now. I'm a little confused on how there is no tweak when using the flex plates. Can some explain it to me. I guess I don't really understand how it all works.
sprintcarracer is offline   Reply With Quote
Old 11-29-2011, 09:35 PM   #2282
nf_ekt's Avatar
Trader Rating: 113 (100%+)
It's a matter of getting the electronics, ect. balanced out correctly and that's it. Someone else can probably give a more technical description... but as i understand it the flex plates have the tension they need by design. They always go right back to where they need to be. Get the chassis balanced out and it will always be spot on regardless of what direction it's turning.
nf_ekt is offline   Reply With Quote
Old 11-30-2011, 07:38 AM   #2283
Infinite 12th's Avatar
I think he's actually doing an tweakable version by request
Otherwise like nf_ekt said balance and exact tire size and car should always be tweaked given there is no current damage to car
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-30-2011, 08:40 AM   #2284
chris moore's Avatar
Trader Rating: 87 (99%+)
Jason would be the best to give a technical answer but in laymans terms nf_ekt is correct. The links provide the tension or spring action so the design is free floating and thus will always return to center. How fast thay recenter is dependent on which side link is in use. Now over time the links do wear out just as a spring does so if once in a great while you might notice a tweak from the links changing their rebound rate, simple to replace and your back in business. But other than that or a bent/broken part the rear pod allways stays centered. Hths.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 12-01-2011, 11:44 AM   #2285
MCSEDanny's Avatar
So my CH12 has been working awesome for the past several months on magenta front and rear. Over the past two weeks (which I have not been able to run) the track conditions have changed with about a 20 deg temp drop. Last night I tried grey rear black front and that seemed to work well but was loosing about half a sec per lap. Others were running gray lows and black or purple fronts.
Was that the right direction or no? Should I have tried Pink double pinks? Should be looking at doing anything with the car itself?
Oh the track has no traction at all, I was just spinning out. With magenta front and rears I was able to run my fastest lap times ever in the first 2 minutes and after that could not turn the car at all. I required the whole track and then some just to slowly get the car around. When on the gray black it did ok just not fast enough. For the main I had hoped traction came back and went back to the magenta all round and it would just spin out with absolutely not control so I did not even run the main as I did not want to break anything on the car.
Team Turtle Trax / Loganville RC Raceway
Mugen MBX6TR / Bonito
Kyosho MP9 TKI3 / Plus 4
Kyosho MP9 TKI3 / Electric / WTF
AE B44.3 / ORCA VXX / D4 7.5
MCSEDanny is offline   Reply With Quote
Old 12-01-2011, 12:35 PM   #2286
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
go and run black fronts and yellow rears . that combo works great up here and outside temps have been in the upper 30's at night and we race in an old airplane hanger that has no heat. haha im sure this set-up will work great for you.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 12-01-2011, 12:59 PM   #2287
Post up the setup you have on the car. Jeffs suggestion should work but mabe a setup change is in order also. The track I run at has an indoor dirt track(run dry) five ft away from the carpet, needless to say our grip is usually marginal at best. Because of that I have had success running magenta ft orange rear with a red center spring. Its an odd combo I know but in my unique situation it works.
Sponsered by:
Old 12-01-2011, 01:59 PM   #2288
For_the_win's Avatar
It could be odd, or ugly setup: but if it works then it works..... I mean look at traxxas!
For_the_win is offline   Reply With Quote
Old 12-01-2011, 02:05 PM   #2289
DesertRat's Avatar
It's not so bad anymore. I can run Pink rears now and not have any problems.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-01-2011, 10:57 PM   #2290
Ooxus's Avatar
I first picked up BMI Copperhead12 and became second in the competition of 12 riders with us. Some of them have more than 3 years racing experience. And it really is an incredible machine.
Thank you Jason!
Andrey
Copperhead 12, Ko Propo Eurus, Lrp SXX V2, DCD TimeR
Ooxus is offline   Reply With Quote
Old 12-01-2011, 10:58 PM   #2291
Grats man well done!
Old 12-02-2011, 02:54 AM   #2292
clayrace24's Avatar
Trader Rating: 42 (100%+)
Default Clamp hub screw and new wheel size questions
Can anyone tell me what size the left side clamp hub screw is? Mine is stripped and I had to gut a groove in it to use a flathead screwdriver to get it off - less than ideal.
12th scale is kind of dead in my area, but I look forward to getting this car on the track and having some fun. Been a while since I ran 12th scale. I am quite impressed with the speed that a 1S pack / 17.5 motor with boost can achieve. Painting body today hopefully some track time this weekend.
I was also wondering what is the largest wheel size that you would consider running on asphalt in a practice scenario. I see so many cars in pictures with the wheels shaved nearly to the rim - I hate to do that to a new set of tires.
I took a new set of Jacos down to 42.5 mm tonight - lot of rubber on the floor Seems like a decent starting point.
Thanks for any help on that screw bolt.
Clay
B44.3,Tamiya M05 Mini Cooper and lots of airplanes
clayrace24 is offline   Reply With Quote
Old 12-02-2011, 04:22 AM   #2293
protc3's Avatar
Thank you Jason!
Great to hear buddy. Congrats. Thank you for going with BMI.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-02-2011, 04:25 AM   #2294
protc3's Avatar
Clay
The screw is 3-48. Very odd size. If you need them, i do have them in stock. You do not need to buy a new hub.
On asphalt, if the bite isnt very high, i just run my tires at 1.750 front and 1.800 rear. If the bite is high, i hate to say but you will need to bring them down pretty small.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-02-2011, 05:24 AM   #2295
LonnyJ1950's Avatar
Thank you Jason!
Nice paint, I like it!
Lonny
LonnyJ1950 is offline   Reply With Quote
