Old 10-24-2011, 01:50 PM   #2161
Originally Posted by joejoe View Post
BMI is a great car comes with standard associated front end I think the other front end you are asking about is the double wishbone and it is available now.
I think it is anyway however the car works great out of the box and the quality is second to none!
Good luck.
sorry I see you were asking about the new rear pod.
jason will have to answer that I know he is working on that now but I am not sure of a date?
Joe Sumasky
joejoe is offline   Reply With Quote
Old 10-24-2011, 02:17 PM   #2162
Originally Posted by jubilee View Post
I am on the cusp of buying a new 1/12 kit. Looking at the Speed Merchant, Serpent, and the Copperhead. In fact, I just started researching the copperhead a couple days ago. I like that the kit is designed and mfg here in the states.
Questions: Is the front end (NOT the new one) proprietary BMI or is it another mfg's front end? Approximately when will the new rear end be released....any actual pics?
Thanks!
It comes with the older AE front end...the one that was on the 12L4 not the current one on the 12R5. But the lower arms are replaced with the IRS lower arms which are more level than the old AE ones and are universal left and right so when you break one you don't end up with a lot of 1 side lower arms. BMI's machine ride height spacers for the front end go perfectly with it and make setting ride height a breeze and add a little more strength overall.
No word yet on when the new chassis conversion or new rear pod will be available. Jason is still testing some things out..I just hope I can build my new cars around Christmas
Old 10-24-2011, 02:24 PM   #2163
jake95's Avatar
Trader Rating: 27 (100%+)
i need a start setup for the 1/12 using enneti tires soft rear hard front for a low to meduim grip track
thanks
jake
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 10-27-2011, 09:32 AM   #2164
Trader Rating: 37 (100%+)
A question for you guys:
I'm really liking the rear-end design of the BMI. No springs to mess with. I'm looking to further simplify the front end as well (my testing/tuning time is VERY limited). Will the BMI accept the Speed Merchant "old school" front end as a bolt-on option? Thanks!
"Fermentation may have been a greater discovery than fire."
-David Rains Wallace
jubilee is offline   Reply With Quote
Old 10-27-2011, 09:37 AM   #2165
AOD
AOD's Avatar
Yes.
AOD is offline   Reply With Quote
Old 10-27-2011, 09:46 AM   #2166
Originally Posted by AOD View Post
Yes.
Thanks!
Old 10-30-2011, 03:48 AM   #2167
H I
H I's Avatar
Trader Rating: 18 (100%+)
I won my first State title with BMI this weekend.
Drove half way across country to compete in South Australia state titles. CH12 was very consistent even track grip and temp changed heaps during race weekend.
Got concourse as well so it was very good weekend for me.
BMI Racing "Copperhead 12" discussion and support-sa-titles-bmi.jpgBMI Racing "Copperhead 12" discussion and support-sa-titles-bmi-2.jpg
H I is offline   Reply With Quote
Old 10-30-2011, 04:25 AM   #2168
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
congrats
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-30-2011, 08:31 AM   #2169
LonnyJ1950's Avatar
+1 Way to go!
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 10-30-2011, 09:54 AM   #2170
chris moore's Avatar
Trader Rating: 87 (99%+)
Excelent! congrats on both titles
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 10-30-2011, 10:11 AM   #2171
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
Attachment 827046Attachment 827047
congrats man!! thats awesome news. make sure to post your set-up
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 10-30-2011, 06:59 PM   #2172
H I
H I's Avatar
Thank you all for kind words, base set up was simply very high ride height and soft setup every where for very bumpy track.
Front
BMI NFE
43mm speedmind32 paragon GE half
Thin flex plate with screws in soft position
#3 tube lube
4.5mm~5mm ride height, 0.5mm droop
Kit width & standoff
Center
Thin Carbon flex plates with soft position
Blue spring with 20W shock oil
5mm~5.5mm ride height
Kit droop
Rear
43mm speedmind30 paragon GE full
#3 tube lube
5.5mm~6mm ride height
Others
Body: R8 for low grip and speed8HD light weight for mid grip
ESC: LRP SXX comp v2 with max boost
Motor: SP 5.5 1 cell
Servo: KO 951
Battery: CRC6300
Old 10-31-2011, 08:51 AM   #2173
Any word on the new stuff in the works?
Old 11-03-2011, 08:23 PM   #2174
markiemark's Avatar
Trader Rating: 23 (100%+)
I Just got my CH12 almost ready for indoor and was wondering whats a good starting point for a gearing in 17.5 Blinky for a small indoor track is say 50x75 or so. i wanna kinda be close dont wanna fry a new revtech.
Also i went with magenta rears and dbl pink front on fresh crc carpet do you think im close on tires or should i go with softer rears? Im going use jack the gripper. Wanted try driving it loose and turning down the steering but dont want it to loose for my first time.
~ ~Blue Diamond Park Raceway~~
~~~~D Main Champ~~~~
markiemark is offline   Reply With Quote
Old 11-03-2011, 08:51 PM   #2175
nf_ekt's Avatar
Trader Rating: 113 (100%+)
You going to be comming down to Middle River by any chance? 12th seems to be going strong there, I plan to get the CH 12thy out there soon hopefully.
nf_ekt is offline   Reply With Quote
