Old 10-04-2011, 04:28 PM   #2116
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
GOOD LUCK
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-04-2011, 04:48 PM   #2117
chris moore's Avatar
Trader Rating: 85 (99%+)
Originally Posted by InspGadgt View Post
Well my day started off with a bang as I hit the outside wall on the first turn (sweeper) and mangled the front end of my car. I bent the upper hinge pin mount badly and broke the servo saver and the graphite brace for it. Then the tires for WGT didn't come in until after 10:30 (nice BSRs this year) and I blew the fuse on my tire truer so I didn't quite get my WGT ready in time for the first run. 1/12th is fixed now and the WGT is all ready so hopefully the 2nd run will go well.
Not the start you were hoping for I'm sure; good luck on geting dialed in on the second run. Btw how many BMI cars have you guys seen there?
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 10-04-2011, 05:18 PM   #2118
michael mercer's Avatar
On the copperhead is the battery supposed to sit in the battery tray?
All the 1s batteries I have are aprox 1.5 mm wider than the tray.
michael mercer is offline   Reply With Quote
Old 10-04-2011, 05:37 PM   #2119
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
yes they are supposed to sit in the tray. but its ok if they dont as the tape holds them good enough.
jeff jenkins is offline   Reply With Quote
Old 10-04-2011, 06:09 PM   #2120
cheehtae's Avatar
Trader Rating: 15 (100%+)
Where can I buy the latest kit?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-04-2011, 06:32 PM   #2121
Well finished my round 2 practice runs...feeling a bit rusty but getting the hang of it. Couple of setup changes I want to make should help the car for tomorrow.
Old 10-04-2011, 07:18 PM   #2122
LonnyJ1950's Avatar
Get it here:
http://www.bmiracing.com/webstore/ca...products_id=30
You will like it!
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 10-05-2011, 03:54 AM   #2123
cheehtae's Avatar
Originally Posted by LonnyJ1950 View Post
Is that the newest kit? I thought out has a new transverse chassis and a new front end?
Old 10-05-2011, 04:37 AM   #2124
Big Features's Avatar
Good luck, Burt!
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 10-05-2011, 06:21 AM   #2125
yes that is the latest kit but you also have the option to buy it with the bmi double wishbone front end as well on the same site! Jason is coming out with a conversion kit and a new pod shortly.
Old 10-05-2011, 07:45 PM   #2126
Well I had a mixed day today. The CH10 was working great all day and I got some good runs in there. The CH12 I bent up 2 of the upper suspension mounts for the NFE, switched to the CRC front end I used to run and proceeded to snap a king pin and destroy 2 bearings. The sweeper on this track is very unforgiving. In the last run I had a wheel roll off the front right at the start (due to a bad bearing that didn't look bad), fixed that and got back out on the track. The car was feeling pretty good until I found another board and shifted the motor forward. Fortunately nothing broken and the car felt good so I feel better going into qualifying tomorrow. Had to do a tire change on the front as what I was running was way to aggressive.
Oddly enough the same tire setup that had way too much steering on my car had a lot of push on Frank's car so he is still trying to find a setup that works. He also bent up an upper suspension mount and had to switch back to the stock AE front end.
Robert' car with the NFE is looking pretty good and I think he is seated higher than the rest of us going into the qualifiers.
Eric's car is a tad bit on the aggressive side but it looks like a minor change to tire additive should do the trick.
For those watching on RCLive my cars are both white with red and pink flames...you'll recognize them as the look like ping pong balls on the track
Old 10-05-2011, 08:35 PM   #2127
JayBee's Avatar
Trader Rating: 31 (100%+)
Nice reporting....keep us in the know. Have you been watching that Awesomatic car? (sorry Jason)
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-06-2011, 06:11 AM   #2128
They are pitting on the table right behind me and look way cooler than the pics I've seen...I haven't seen them run yet though.
Old 10-06-2011, 03:11 PM   #2129
Yea Eric's car always looks very aggressive on the track to me, good luck to all the BMI drivers this weekend.
Sponsered by:
Old 10-08-2011, 10:54 AM   #2130
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Hey guys, I have a quick question about the Copperhead. I will be buying a copperhead kit and I was wondering if there are any spare parts i should get? I am buying the kit with the new front end so are there any pieces to that that break? I have a DB12rr already so I have ride hieght adjusters for the pods and such
Thanks in advanced
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
