Old 09-21-2011, 10:26 AM   #2071
Are the Copperhead 12 kits available for order yet?
JamesL_71 is offline   Reply With Quote
Old 09-21-2011, 11:11 AM   #2072
protc3's Avatar
I will have them back on the website tomorrow. I am cutting the carbon fiber now.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-21-2011, 12:37 PM   #2073
How is the new prototype coming?
Old 09-21-2011, 02:24 PM   #2074
protc3's Avatar
Coming along really well. I have some more changes i want to try.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-21-2011, 02:46 PM   #2075
Cool...can't wait for em to come out. I'm pretty jazzed on the thought that I won't have to run my motor wires over the battery
Old 09-21-2011, 03:21 PM   #2076
EricF's Avatar
When do you guys get into Vegas? Hopefully we can pit together or somewhat close.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 09-21-2011, 03:40 PM   #2077
Sunday morning. Wanted to participate in the poker tournament this year since I wasn't able to last year or go to the indoor cart race the year before. Shoot Kraig in the IIC thread a PM and let him know you'd like to pit with the Hawaii group
Old 09-21-2011, 05:52 PM   #2078
markiemark's Avatar
Trader Rating: 23 (100%+)
I was looking on the site at tires and was wondering what tires would be good for fresh crc carpet? I see all theres listed is double pinks fronts so was thinking dbl pink and i guess pink or yellows any help be great. And if anyone has a good fullset up i loved to see it.
~ ~Blue Diamond Park Raceway~~
~~~~D Main Champ~~~~
markiemark is offline   Reply With Quote
Old 09-21-2011, 05:57 PM   #2079
For 17.5 no-boost last year at the IIC I ran lilac front and yellow rear and this year for 13.5 boosted Jason recommended I run magenta all around.
Old 09-21-2011, 06:20 PM   #2080
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
My local track is running on new crc carpet and since we switched to that carpet ,jason's suggestion to run magentas all around has been the best tire combo on that carpet with the CH12.
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 09-21-2011, 06:27 PM   #2081
Default set-up
Here is my current set-up that i am running at the moment and i am really liking it. this set-up uses the bmi front end.
front:
Width-169mm
0 deg toe
-1 deg camber
4mm ride hieght ( track has some bumps and lower than 4mm hits the tape seams)
1mm up-travel
up travel limiters set to just touch arms when suspension is compressed
1.8mm flex plates (stiff position)
20,000 wt oil in dampner tube
full castor
zero washers under arm mount.
flat mounted servo with tall ball studs on the spindles
crc magentas 40mm
jack the gripper 1/3 inside
center & rear:
shock-45 wt oil, stock gold spring
1.2mm hole drilled in shock cap
stock shock position
stock ball stud on antenna mnt.
30,000 wt oil in dampner tubes
1.2mm carbon flex plates soft position
.5mm pod sag
1mm pod droop
4mm ride hieght
width - 170mm
crc magenta tires 42mm
jack the gripper 100%
body: amr-12
Old 09-21-2011, 06:48 PM   #2082
markiemark's Avatar
Thanks jeff now what class is that for? Right now the plan is to run 17.5 blinky.
Old 09-21-2011, 06:56 PM   #2083
that set-up is for 13.5 blinky so should work fine for 17.5 blinky.
Old 09-21-2011, 06:58 PM   #2084
i would suggest running 3.5mm ride hieght tho!
Old 09-21-2011, 06:59 PM   #2085
LonnyJ1950's Avatar
I understand why you might put a hole in the shock cap, but what is the actual effect on the handling?
Lonny
LonnyJ1950 is offline   Reply With Quote
