Old 07-28-2011, 05:00 PM   #1921
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Oops just remembered the red is slightly stiffer, been out of the game too long Well yeah if you try gold then hey would still like to hear back, First carpet race here is still about a month out. I need some BMI decals.
nf_ekt is offline   Reply With Quote
Old 08-04-2011, 11:06 PM   #1922
LonnyJ1950's Avatar
OK, last week one of our guys got an idea (always dangerous) and changed our track layout. Though I like the new layout, we are running on carpet with no line and it's extremely slippery. I tried a few things and got the car a bit better, but I'm in need of much much more rear grip. Current set up:
Copperhead 12 with 12R5 front.
Front track 170mm
springs AE ,020 .020 droop
Green Shurlube on kingpins
10' caster blocks with both shims back
42mm Jaco Lilac Jack about 1/4
0' toe in, 4.5mm clearance
Middle
50wt oil w/ gold spring
Blue Shurlube on tubes
4mm clearance
1.2 CF flex links set long
Back
Rear track 172mm
Clearance 4.5mm
44mm Jaco Orange full Paragon
1mm droop
Trinity Nemesis 13,5 boosted rollout 60.5mm.
Suggestions?
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 08-05-2011, 03:17 AM   #1923
protc3's Avatar
Front track 170mm
Middle
4mm clearance
Back
Rear track 172mm
Clearance 4.5mm
1mm droop
Suggestions?
Try running red shur lube in the tubes and go to Magenta front and pink rear tires. 13.5 boosted is too much motor for synthetic tires. They will fade. I also like to run the car level at 3.5mm ride height. I also would go to 5 degrees of reactive caster but keep it at maximum static caster. If you still have issues, run the pod .5mm higher at the front of the pod over the rear of the pod. I dont think you will need to go that far but use it as a last resort. Hope that helps buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-05-2011, 08:47 AM   #1924
Ray k's Avatar
Trader Rating: 46 (98%+)
Hey Jason , called you this morning about adding that cooperhead 12 rear body mount cross brace to the web site . Still don't see it .
Ray K
Ray k is offline   Reply With Quote
Old 08-05-2011, 09:06 AM   #1925
chris moore's Avatar
Trader Rating: 85 (99%+)
One thing that Lonnie did'nt mention is that we have an indoor off-road track that is run dry five feet from the carpet. So traction is extremely low at all times. Also we have experimented with pink rears with no success on the previous layout, so with that in mind any other ideas?
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 08-05-2011, 09:14 AM   #1926
HarryLeach's Avatar
Send a message via AIM to HarryLeach
With that kind of situation, has anyone tried grooving rear tires, like you would foams on dirt oval?
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 08-05-2011, 09:43 AM   #1927
protc3's Avatar
Hmm, that is tricky. I would try what we do on asphalt, suntan lotion over the traction compound. It keeps dirt from sticking to the tires. Less static caster then also. Try 4 degrees instead of 6.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-05-2011, 04:43 PM   #1928
EricF's Avatar
Lonny,
I;ll have my whip (car) out this sunday. so we'll get something working worked out I'm going to run 17.5 boosted and see how that goes. Hopefully my tire order came in or I may not be able to get my car working with the tires that I currently have.
by the way I like to run my servo flat. I also have the 5 caster blocks.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 08-05-2011, 07:20 PM   #1929
LonnyJ1950's Avatar
Grooved tires have been run, though not by me. Weren't impressive. We will try as many of your suggestions as we have time to test. Thanks all.
Lonny
Old 08-05-2011, 07:31 PM   #1930
You know I've never tried that suntan lotion thing so mabey I'll give it a go just for giggles, whats the procedure?
Sponsered by:
Old 08-05-2011, 07:59 PM   #1931
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Don't know I'd go that route for carpet....but here's how we use it for outdoors.
Normally apply paragon first, let soak for 10 mins, then apply Coppertone 30spf sunblock over that, massage it in, let sit for 5 -10 minutes, wipe off.
Or
Just use spf30 sunblock with no paragon.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-06-2011, 06:17 AM   #1932
H I
H I's Avatar
Trader Rating: 18 (100%+)
Few ways to get more rear traction:
1. Use full size tires. 48mm rear and 46mm front.
2. Narrow down rear track, down to about 169mm
3. Use high down force body. ie. Parma speed8HD
Most likely you will need to stiffen up whole car to make it work with above changes.
Id go Red spring on center, .22 or .24 BMI linear springs for front. Maybe bit of toe out as well.
Pink rear will work on low traction track. Try using them with BSR Team purple front. With traction compound, I wont know what will work on your track as I never been there but something I would try is Trinity tire tweak 2000 soaked over 24hours in sealable plastic container, wipe well before use.
H I is offline   Reply With Quote
Old 08-07-2011, 07:54 PM   #1933
LonnyJ1950's Avatar
Ran the CH again today. And it was vastly improved. Final set up:
Front: Magenta @ 42.5mm 1/4 paragon
.020 AE springs
5' Blocks, Full caster (2 spacers back) 1.5' camber
0' toe in 5mm clearance
Center:50wt oil gold spring 1.2 CF flex plates soft #5 shurlube in tubes
5mm clearance
Rear: Yellow tires @ 45.5mm full Paragon light coat
58.3mm roll out
4.5mm clearance
TQ, 2ND in A main (lost by 9 seconds). Didn't try pinks, no one runs pinks, not enough grip. And since I was a bit short on time, I went with yellows which I knew would work if the rest of the car was right. Still have potential to tap, but generally very pleased. Thanks everyone.
Lonny
Old 08-10-2011, 09:03 AM   #1934
Jeronemo's Avatar
Default Info
Still new to 1/12 and got myself a copperhead after i was very frustrated with another cheap brand. @ Jason must compliment your car , just built it and very impressed with the quality. Wow its awesome.
Need some tyre info , some manufatures list the tyres in shores and CRC , Jaco and Parma in colors. Where can i get info on what shores the diff colors are?. Also why would some tyres be suited for carpet and others for asphalt.
Serpent 411 ERYX , Speed Passion PRO , Trinity D3
BMI 1/12 Copperhead , HW 1 cell , Trinity D3
Futaba 4PKS FASST
Jeronemo is offline   Reply With Quote
Old 08-10-2011, 09:45 AM   #1935
On the BMI website Jason has a list of the colors and the shore rating that each color represents. The firmness; or shore number; and the type of foam determines what works best on each surface. Its not 100% complete as some new compounds have come out recently like orange that is not listed, but it will get you pointed in the right direction. But that can change from track to track as other varibles like how the track is preped and what tire additives are allowed also effect tire choice. If your still unsure post up your track type, type of prep used; like sugar water or soda on asphalt; and class your going to run and Jason will get you sorted out.
Sponsered by:
