Old 07-25-2011, 01:00 PM   #1906
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by JayBee View Post
Marcos......why do you have to tease us like this?!
because some one had to take the reins from me since i went back to offroad
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-25-2011, 05:20 PM   #1907
pmes's Avatar
this aint right, we need pics asap!
pmes is offline   Reply With Quote
Old 07-25-2011, 07:01 PM   #1908
H I
H I's Avatar
Trader Rating: 18 (100%+)
Actually I chipped off my CH12 chassis other day so I got perfect excuses to get new upgrade.
H I is offline   Reply With Quote
Old 07-26-2011, 05:46 AM   #1909
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by nf_ekt View Post
Jason, I would like it if you could give me a good set-up to start with on carpet. Using the dynamic strut front end. 13.5 on a tight track, ozite, track is fairly new. They are using odorless traction additive such as jack the gripper. Looking for something that will be fast but not overly twitchy. Thanks Sir.
Im working on one now with both front ends I should have it done by tonight, Im heading to the track this afternoon
Old 07-26-2011, 10:03 AM   #1910
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Hook it up so it will s**t n' get ...
nf_ekt is offline   Reply With Quote
Old 07-26-2011, 01:04 PM   #1911
Super Moderator
Marcos.J's Avatar
Will do I'm at the track now fat so good I really like the Bmi front end over the ae
Old 07-26-2011, 01:31 PM   #1912
20 SMOKE's Avatar
tire wear in nonexistent with the NFE
Jamie W
Old 07-26-2011, 01:42 PM   #1913
nf_ekt's Avatar
Would like to try the NFE but I guess with a updated car in the near future, I will see what happens there before changing up what I have right now. So I need a good starting point on tight ozite carpet with the AE front.
Old 07-26-2011, 03:28 PM   #1914
Super Moderator
Marcos.J's Avatar
Yes but I need new flex plates I just put the ae front end so I can run for the rest of the night. I need to make a road trip to Bmi to get new ones
Old 07-26-2011, 03:52 PM   #1915
20 SMOKE's Avatar
what happened
Jamie W
Old 07-26-2011, 04:34 PM   #1916
Super Moderator
Marcos.J's Avatar
what happened
One side s a little softer and I cant get the ride height to stay is way too soft
Old 07-26-2011, 07:44 PM   #1917
Super Moderator
Marcos.J's Avatar
Here is what I got so far similar to Jason's base set up
Front:
1.5mm flex plates soft position
caster shims to the rear of arms
1.4 degree camber
10,000 diff lube in damper tube
4 mm ride height
1mm droop
magenta cut 40mm
Rear:
Red center spring w/ 40 wt. oil
medium ballstud on Antenna/shock mount
30,000 diff fluid in damper tubes
1.2mm carbon fiber flex plates mounted long
4 mm ride height
1.5mm pod droop
Pod level at ride height
Magenta cut 41 mm
with the AE front end
4mm ride height
5 degree blocks
shims in rear of arms
1.5 front camber
.20 springs
Old 07-27-2011, 11:48 AM   #1918
nf_ekt's Avatar
Did you try running the gold center spring J? That is what I have tried, although asphalt only so far, and really liked the responsiveness. Think I will start pretty close to what you have, move to the gold if it needs to be a bit faster to turn... our carpet track is tight and technical. Thanks for posting you settings thus far.
Old 07-27-2011, 12:38 PM   #1919
chris moore's Avatar
Trader Rating: 85 (99%+)
I too have found that the gold center spring feels better on our low grip carpet track
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 07-28-2011, 03:22 PM   #1920
Super Moderator
Marcos.J's Avatar
this track has high bite the red works very well , maybe I will try the gold this weekend
