Old 07-23-2011, 11:32 AM   #1891
protc3's Avatar
Originally Posted by EricF View Post
As you've already decided keep the quality high. I'd rather complain and have to save a little longer to buy something once. Since I just bought my car will the new design be a conversion as well a as kit? Nevermind I know the answer (yes).
E
Please understand, I am always testing and trying new things. This does not mean that i am ready to change the car for production. I have tested 2-3 versions already since the release of the CH12. Always looking for the edge and better performance.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-23-2011, 12:18 PM   #1892
EricF's Avatar
I understand, your still testing, not a problem.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 07-23-2011, 07:55 PM   #1893
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Ran about 30 laps today with my CH, had been a long time since wheeling a 12th but it came back to me pretty quickly . Somewhat rough asphalt, OK traction but certainly not a world-class circuit for running a pan car on. Anyways, the car was a blast, I was feeling it for sure. I have run t-bar cars and link/spring type cars before, the CH felt like a mix of the two, it had a lot of the agressivness of the T-car, but with link smoothness. Probably nothing new to hear for most of you guys but I had a lot of fun and had to post my impression. I wish I could get some guys locally to run with me on outdoor asphalt, I love it. Carpet is the deal around here, so that is where the car will live soon.
Anyways, This is the best 12th I've ever driven, just great.
nf_ekt is offline   Reply With Quote
Old 07-24-2011, 05:03 AM   #1894
protc3's Avatar
Thats really cool buddy. Thanks for posting your experience with the car on asphalt. When you get ready to run it on carpet, let me know if you need any help.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-24-2011, 10:41 AM   #1895
I agree...keep the quality where it is. I wonder if much could be saved by not machining the battery rectangle and using some sort of locator instead. I like it better the way it is because a locator will take up some space where the electronics are but it might be something to look at.
Old 07-24-2011, 08:36 PM   #1896
My CH12 felt great today...I turned the fastest lap of the day several times but I am fighting a little bit of a tweak issue and the car would occasionally get loose on left hand turns and I ended up in the boards a few times because of it and ended up losing out to the other CH12 and only other car running today. Yeah disappointingly small turn out But we have more coming soon. I think my tweak is the balance being off...will have to put it back on the balance buttons and see what's up.
Old 07-24-2011, 09:10 PM   #1897
JayBee's Avatar
Trader Rating: 31 (100%+)
Yeah Jason....BMI is synonymous with PRECISION & QUALITY. Can't wait to see the new joint
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-25-2011, 03:14 AM   #1898
protc3's Avatar
Just go through al the screws in the car. It is annoying when this happens but it really is a good thing. It makes us fix the problem instead of hiding it by tweaking a screw and having the real problem get worse.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-25-2011, 03:14 AM   #1899
protc3's Avatar
thanks bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-25-2011, 09:44 AM   #1900
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Wow after seeing it this morning all I can say is , Jason can't wait to see that new car on the track !!! That thing is wicked
Old 07-25-2011, 09:49 AM   #1901
JayBee's Avatar
Marcos......why do you have to tease us like this?!
Old 07-25-2011, 09:57 AM   #1902
MCSEDanny's Avatar
Originally Posted by MCSEDanny View Post
With out looking back 50 pages can someone share the newest setup for the CH12 with new front end? Track is semi bumpy with good traction. Hoping to see my new car tomorrow.
Hey Jason I still need a starting point.
Team Turtle Trax / Loganville RC Raceway
Mugen MBX6TR / Bonito
Kyosho MP9 TKI3 / Plus 4
Kyosho MP9 TKI3 / Electric / WTF
AE B44.3 / ORCA VXX / D4 7.5
MCSEDanny is offline   Reply With Quote
Old 07-25-2011, 11:44 AM   #1903
Super Moderator
Marcos.J's Avatar
Because I can lol but honestly I can lol j/k
Jb the car is wicked that's all i can say!
Old 07-25-2011, 12:22 PM   #1904
protc3's Avatar
Front:
1.5mm flex plates soft position
caster shims to the rear of arms
1 degree camber
#6 shurlube in damper tube
4.5mm ride height
1mm droop
Team purple(Lilac if Jaco) Tires cut to 1.650
Rear:
Gold center spring w/ 40 wt. oil
medium ballstud on Antenna/shock mount
#4 shurlube in damper tubes
1.2mm carbon fiber flex plates mounted long
4.5mm ride height
1.5mm pod droop
Pod level at ride height
Magenta rear tires cut to 1.680
If need be, glue the edge of wheel to stop chuncking of tires.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-25-2011, 12:24 PM   #1905
nf_ekt's Avatar
Jason, I would like it if you could give me a good set-up to start with on carpet. Using the dynamic strut front end. 13.5 on a tight track, ozite, track is fairly new. They are using odorless traction additive such as jack the gripper. Looking for something that will be fast but not overly twitchy. Thanks Sir.
