BMI Racing "Copperhead 12" discussion and support
#1803
I think I came up with a good way to keep the ride height screws on the NFE from losing their setting. I tried Loctite and CA glue and both slipped on me. I don't have another race day until Sunday 6/12 so I won't be able to report if it worked until after then. But until then here's a pic.
I tried the black Tamiya o-rings but they just wouldn't stretch enough. The clear Tamiya o-rings seem to stretch enough. Now just to see if the settings hold
#1804
Awesome it appears to be instock and I need one! Doesn't make sense to order a $10 part and pay $10 to ship it! I thought I would stock up on tires to take advantage of the free shipping .
Looks like you only have one front tire ,Double Pink and it is out of stock! When will they be back instock ? You don't stock any other front compounds?
#1806
Thanks !
#1807
#1809
Got a question for you guys, I noticed that one side of the pod sits lower then the chassis and the other side is higher. The pod has a slight tweak, is there a way to fix that? A lot of the other cars can just adjust the side springs but with the flex plates would I have to shim it? I am having a problem with the back of my car wanting to loop out on me. It dose it more one way then the other, that's why I was thinking the pod being tweaked might have something to do with it.
#1810
I've had that happen.
Loosen the cross brace and the upper pod plate, square everything up and then carefully re-tighten.
Also need to check the ride height adjusters and bearings for any damage, and sometimes I've had a tweak indication due to a slightly cracked body/damper tube mounting plate.
Between those things, I've always been able to get the car back square without shimming the flex plates.
#1811
Thank you, I will give that a try.
#1812
The cross brace on my car is off( broke it) but I did find that when I loosened up the upper pod plate that it fixed the tweak. I finally found a order to tighten down the screws so it didn't come back.
Thakns for the help.
#1813
OK, a few pages back, I complained about the design of the pivots on the CH 12 and got mildly flamed for it. I still would prefer a design that allowed me to adjust the tension and free play. But, I raced the car for the first time on Sunday and was very pleased. It was quick with a basic set up and responded nicely to some adjustments. Missed TQ by 0.2 seconds and was leading the main when I got hammered back to second at the finish. Now all I need is to figure out why I have no speed on the straight. Got run over 3 times at the end of the back chute. Felt like I had the fastest car in the infield.
#1814
Grats man...get your power issue sorted out and they'll be chasin ya instead of running you over
