Old 04-21-2011, 10:25 AM   #1756
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
its quite in here,so i got boarded today and starting goofing off http://flpancars.webs.com/ its a working progress of just fun things
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-21-2011, 01:17 PM   #1757
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
yep definately quiet in here. time to get it back up to the top . now that it is time to gear up for outdoor season anybody got any good set-ups for a med grip parking lot track ? I have not ran my ch12 yet outdoors so i dont have a set-up for ya guys at the moment. but lets see what everyone else uses for there set-ups. get em posted guys.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 04-25-2011, 12:12 PM   #1758
20 SMOKE's Avatar
i run the kit setup outdoors with 35-40wt oil,with magenta's all around
sent a pm Jason
Jamie W
Old 04-25-2011, 02:02 PM   #1759
chris moore's Avatar
Trader Rating: 87 (99%+)
We dont have any asphalt 1/12 here anymore but when we did I ran my 12r out of the box with one step-up on the center spring and dbl pink all round. This track was preped with soda and I was running 1s 13.5.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 04-25-2011, 02:48 PM   #1760
Switching to pink rears and double pink fronts on my CH12 was great in yesterday's practice. I was able to go back up to the gold center spring and had enough grip all around to carry more cornering speed then I was before. Looking forward to the next time I can race it
Old 04-26-2011, 12:03 PM   #1761
thats awesome.. let us know how it goes the next time you run.
Old 04-26-2011, 12:12 PM   #1762
I should mention it is on an asphalt track. Unfortunately our next race that I will be able to go to will not be until late May or early Jun...I have to double check the schedule. We have a between season break coming up to do some track maintenance and a couple holidays interfering with normal race dates.
Old 04-26-2011, 12:24 PM   #1763
AOD
AOD's Avatar
Pizza race this Sunday is the only race in May. I think the next season will start in June. I guess you will have to wait till then to see if you have anything for my db12rr.
AOD is offline   Reply With Quote
Old 04-26-2011, 02:12 PM   #1764
I think I will At least it seems faster in the corners so far. How much of the gap I can close remains to be seen. But based off of how it ran against Bob's car which used to run well against yours...well the June race will be interesting. And Goots got his car running much better too...so it will be up to our two BMIs to fend off the non-BMIs.
Old 04-26-2011, 04:47 PM   #1765
Big Features's Avatar
Figures, just as pan cars take off again, I leave the island.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 05-04-2011, 04:33 PM   #1766
LonnyJ1950's Avatar
Been looking at a CH12 for a friend and his center pivot and one of his side pivots have noticeable play in them. Is this common, are these worn, can it be fixed, ignored or must it be replaced? Personally I would like a two piece cup so play could be eliminated with a bit of sanding or shimming. The rest of the kit seems to be very high quality, so it's a little disappointing.
Lonny
LonnyJ1950 is online now   Reply With Quote
Old 05-04-2011, 06:14 PM   #1767
i would say it is time to replace them. a tiny bit of play is acceptable but if it is excessive play then yes replace them.
Old 05-04-2011, 11:03 PM   #1768
LonnyJ1950's Avatar
What is the correct part number for the link pivot ball assembly? The one in the instructions refers to a 2 piece housing, obviously not the correct part.
Lonny
Old 05-05-2011, 01:20 AM   #1769
here are the part number and descriptions from the site i just copied them on to here.
DB3020 Center Pivot Ball Housing and Ball, Delrin/Alloy
DB3025 Alloy 1/4" Rear Suspension Pivot Balls
DB3029 Flex Plate Pivot Ball Housings Complete
Old 05-05-2011, 03:18 AM   #1770
protc3's Avatar
They can develop a small amount of vertical play. It is not very critical unless it is side to side play. This is not common. A little vertical play will not be noticeable or problematic. There will need to be a small amount of vertical play in order for the ball not to stick when pivoting in the housing. I went away from the adjuster screw because it was too difficult for some people to adjust and when they would over tighten the screws, the car wouldn't work well due to it, and then they sell the car with ill feeling towards the car. The new pivots work extremely well and do not need any tinkering.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
