Old 03-17-2011, 05:41 PM   #1726
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
Originally Posted by JayBee View Post
Carpet....I like the AMR12 or the Speed 8HD LW.
Asphalt...I don't run on asphalt with 1/12th. If we had a class I would....
i like the amr and speed 8 exp never tried the 8hd,hate the speed 12 lw
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-17-2011, 07:50 PM   #1727
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
for carpet my body of choice is the amr-12. will be doing some outdoor soon and will play around with some more bodies and see if the amr-12 is still the fav.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 03-17-2011, 11:11 PM   #1728
chris moore's Avatar
Trader Rating: 85 (99%+)
To me it really depends on the grip levels, I only have access to one carpet track and its next to an indoor off-road track. So the carpet is constently dusty and the grip is low, thus I really like the speed 8hd, second choice is the speed 12, if you have med+ grip levels then the AMR 12 will be good. For asphalt my choice was the speed 12 but no asphalt now so I have'nt been able to try out the AMR.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-19-2011, 12:34 PM   #1729
pmes's Avatar
Originally Posted by 20 SMOKE View Post
you guys arent lucky enough to see what i get to see
pictures pictures pictures!
pmes is offline   Reply With Quote
Old 03-19-2011, 06:41 PM   #1730
protc3's Avatar
Yeah, we are always messing around trying new things. This is how we move forward and continue bringing new innovations to Pan Cars.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-19-2011, 10:58 PM   #1731
20 SMOKE's Avatar
only the ones i see with my eyes are the ones taken
Jamie W
Old 03-20-2011, 12:38 AM   #1732
Serpent project 4x
Old 03-20-2011, 07:23 PM   #1733
dzstr's Avatar
Trader Rating: 20 (100%+)
dzstr is offline   Reply With Quote
Old 03-28-2011, 07:35 PM   #1734
I had a much better race day with my CH12 yesterday I still think I need a tire change to pink rear 2X pink front but the car was very close. It had a tendency to lose grip on a couple of the right hand corners so I need to take another look at the balance. But overall the car was pretty decent. I ran the servo flat and on the left side of the chassis and really liked how much smoother the car felt. I also ended up decreasing the amount of caster I was running and that helped as well. I found an interesting thing with my shock...when getting the car ready I ran out of time to rebuild the shock so I just set the rear droop with the shock as it was. When setting the droop I noticed I had near 3mm of rear droop which I'm sure didn't help handling either. So I removed the washers I use on the threaded part of the shock to set shock length and set the car to the right droop. Then later in the race day I got a chance to rebuild the shock and ended up having to put the washers back in to get the right shock length. The only thing I can think of is that I am not always getting the bottom part of the shock back on the shaft the same way length every time. So just a word to the wise...if you are going to do spring changes or shock rebuilds...make sure your overall shock length hasn't changed!
Also I got to compare running my o-ring mod on the front to not running it. Sometime during my 2nd run the o-ring broke and I didn't even notice. Cut the other o-ring off and ran the rest of the day without them and the car felt the same so it appears there is no detrimental effects that I could detect. As for beneficial effects...well the droop in the front was actual arm movement now instead of play in the pivot balls. I'm not sure if that is worth it or not though. Hopefully I can do some more testing next race.
Old 03-28-2011, 11:11 PM   #1735
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey InspGadet,
Its been awhile since I've been in this thread. for your Front end Mod would you consider making a front sway bar? just a thought.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 03-28-2011, 11:49 PM   #1736
The o-ring mod I did was simply to put tension between the upper and lower arms. The idea behing it is to hold them together tight enough that it takes the play out of the pivot balls so that I can more precisely adjust droop, toe, and camber.
Old 03-30-2011, 07:31 PM   #1737
H I
H I's Avatar
Trader Rating: 18 (100%+)
Hey guys,
We are going to be replacing our hooded sweatshirts with black ones and with the new logo color similar to the new T shirts.
Any news on new sweatshirts?
It's getting bit cold down here.
H I is offline   Reply With Quote
Old 04-01-2011, 10:08 AM   #1738
How much of a gap is everyone running between the uptravel limiters and the lower arm?
Sponsered by:
Old 04-01-2011, 11:46 AM   #1739
20 SMOKE's Avatar
around 1.5mm i did mine to were the chassis doesent hit the ground
Jamie W
Old 04-01-2011, 12:13 PM   #1740
all i have been doing is hold the front end down so the chassis is touching the set-up board then i adjust the limiters till they touch the arms.
Serpent project 4x
SEO by vBSEO 3.5.0
