BMI Racing "Copperhead 12" discussion and support
#1561
Yeah, checked the tightness of the axle at the track the other day, and it was fine.
I did find that one front tire was about .03 smaller in diameter than the other tire.
Car is tight but free, rear axle is free of drag, and the front wheels spin forever.
#1563
Otherwise, the site looks nice.
EDIT: And your team driver application doesn't download, or goes to an error "page not found/no permissions" page.
I do a little web work on the side, first thing I do is check links, so, sorry if this is annoying.
#1565
Looks nice
#1566
what website are you talking about? I looked at the bmi website and it seems to be the same?
#1568
ah ok, i had it safed in my favourites and it went to the original adres with the old website
edit:
If you want an honest oppinion.
The orange letters on the download page indeed need to be changed
I prefer a clean website without too many colors. The buttons that looks like cheap carbon i would also change. The original website really looks clean and tight.. This one looks a little more dark but also busy with different colors and all. The BMI logo is also not really instantly vissible, orange on a black background just doesn't read that easy.. it looks a little cheap or more comic book layout then the original one. Sorry, hope you don't mind
edit:
#1571
Here is the setup i ran yesterday. Car was the best so far.
Front:
1.8mm flex plate in soft position
3mm shims under front hinge pin block
#6 shurlube in center tube
3.5mm ride height
.5mm droop
1.5 degrees camber
6 degrees caster
1.5mm shims per side behind front axles
0 toe
Rear:
Gold center spring w/ 40 wt. oil
shock in short position
1.2mm c/f flex plates in soft position(long mount)
#4 shurlube in tubes
3.5mm ride height
1mm pod droop
172mm rear track width
I ran gray white rears cut to 1.670 and 2x pink cut to 1.620. Glued sidewalls front and rear. Sauce for 10 minutes and wipe off tires 5 minutes before run. I sauced the full rear and 1/3 of the inside of the front.
Front:
3.5mm ride height
.5mm droop
1.5 degrees camber
6 degrees caster
0 toe
Rear:
3.5mm ride height
1mm pod droop
#1573
Hey Jason, had a chance to run again today but this time on a 'green' track (we just got 4 rolls of new CRC carpet), with a new and much larger layout. Showed up with our same set-up but with the thinner c/f 'hockey sticks'. Put Grey frt./White rear shoes on and the car was super easy to drive (15.2-5's), but wanted to try a couple of other compounds. Threw Magentas on the frt and the car was too reactive up frt but averages dropped to 14.7-15's. Had Dbl pinks to try up frt, so I threw them on. Saw an immediate improvement in the cars handling up front. The car felt very balanced and I guess fast for now, LOL. Laptimes improved once again with averages of 14.1-5's. Started with a RO of 102 (w/a Novak 17.5) and ended up with a RO of 105 (w/a Viper 17.5). Gotta order pinions in the 60+ range
So all in all, very good feedback today
#1574
Sorry to spam a bit:
For sale:
CH 12 chassis plate, lower pod plate, flex plates for sale.
5 batteries run, basically new. Make me an offer.
Maybe a new front end kit (new) as well.
PM if interested, will send pictures if needed
Will ship worldwide, except Italy.
For sale:
#1575
Hey Guys,
As you are aware, we have updated our website. We are putting up a photos page for those of you who are really proud of your Copperheads and DB12RR's. If you would like a picture of your car or you and your car, Send me a picture to [email protected]. I will get them on the site as they come in. Thanks for all of your support guys.
Jason
Jason
