Old 12-25-2010, 10:04 AM   #1486
clparsons123's Avatar
EAM (TEAM EA MOTORSPORTS),ORCA, RC AMERICA, XRAY,HUDY,EZ CUSTOMS, RSD (REFLEX RACING) , JEFFS RC STUDIO, RCTVLIVE
Cory parsons
clparsons123 is offline   Reply With Quote
Old 12-31-2010, 07:57 AM   #1487
protc3's Avatar
Have a safe and happy new year everyone. Thank you for all of your support all of these years. May 2011 bring us all good things including what BMI has in store for all of you. Going to be a very innovative year.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-31-2010, 08:13 AM   #1488
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
Happy new year,seeya sunday
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-31-2010, 08:36 AM   #1489
Joost K.'s Avatar
From the Netherlands I would like to wish you all a very happy newyear!!! May 2011 bring you all great results and tight lines
Thanx Jason for making 2010 a great year for me!!!
Season greetings from
Joost.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 01-02-2011, 06:08 AM   #1490
V12
V12's Avatar
Happy new year everybody!
Jason
What´s coming new this year? Something for 1/10?
V12 is offline   Reply With Quote
Old 01-03-2011, 01:16 AM   #1491
speed-e's Avatar
Trader Rating: 28 (100%+)
Originally Posted by protc3 View Post
Thats great news buddy. I am looking into up travel limiters. Just trying to see if i can do it without replacing existing parts. I will keep everyone posted.
Jason,
Have you looked into using longer ball studs for mounting the front dampener? I've also switched to long ball studs and now the dampener has considerably more travel as the suspension moves which has improved my cars' handling.
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 01-03-2011, 01:31 AM   #1492
JayBee's Avatar
Trader Rating: 31 (100%+)
Really? So just replacing with longer ballstuds so the tube sits higher up on the lower arm somehow changes the 'effective movement' of the damper tube producing better handling? Someone please explain this....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-03-2011, 03:54 AM   #1493
Edgar_P's Avatar
The longer the ballstuds the more damper movement with the same amount of movement of lower arm. Effect is the same as thinner lube in damper tube.
BMI COPPERHEAD 12
Edgar_P is offline   Reply With Quote
Old 01-03-2011, 05:17 AM   #1494
Quick couple of questions about the effects of various options on the new front end (basically more / less front end and where in the corner!)
More droop / less droop?
More Castor / Less
More / less Camber
Thinner / thicker oil in damper
Raising the standoffs?
Thanks!
exint2 is offline   Reply With Quote
Old 01-03-2011, 07:19 AM   #1495
protc3's Avatar
More droop / less droop? more: better on bumps but will reduce on power steering. Less:more on power steering but hard to plant front on bumpy tracks.
More Castor / Less More:Will give you more steering. Less: Will reduce steering.
More / less Camber Same as Castor
Thinner / thicker oil in damper Dampening will smooth out the front spring rate. If you increase dampening, you slow the reaction of the spring. This is a nice tuning option as it can help you mellow the car down if it is irratic.
Raising the standoffs? Raising the standoffs will lower your roll center and lowering them raises your roll center. When you lower it, you increase chassis roll and when you raise it, you decrease chassis roll. We have been lowering the roll center because it makes the car more smooth by reducing side bite. When the car rolls, it absorbs the weight instead of transfering the weight to the tires and making them dig harder.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-03-2011, 12:41 PM   #1496
Higher ball studs will make for longer lever arms on the damper...thus more travel on the damper.
Old 01-03-2011, 01:31 PM   #1497
avs
avs's Avatar
the damping is proportional to the square of ball stud length. if you double the length, the travel doubles (increasing the viscous force in the tube, and the tube is acting on longer lever arm, so the damping increases by 4x's
speed-e is a clever fellow..
Tony Shimko
avs is offline   Reply With Quote
Old 01-03-2011, 02:13 PM   #1498
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
BMI would do well to seek out Eric (speed-e) as a Team Driver.
It would be interesting to see what he could do with the full Copperhead, though his R5/BMI is plenty quick as it is...
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-07-2011, 02:02 PM   #1499
Will the lowered pod plates for the DB12 (DB1054 and DB1055) fit the Copperhead?
thalmek is offline   Reply With Quote
Old 01-09-2011, 07:39 PM   #1500
Trader Rating: 96 (100%+)
Any chance someone could pm me a list of parts for the ch12 that are a must have at the track? Thanks.
K.Copeland is offline   Reply With Quote
SEO by vBSEO 3.5.0
